ATTENTION ALL PT-42 OWNERS!!!!!!!!!!!!!!!
10-01-2008, 07:31
Post: #21
Kurt, thanks for all your efforts
Ernie Ekberg 83PT40 currently in North Platte, Nebraska Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators. |
10-07-2008, 14:35
Post: #22
I would like one Jim Riordan 851 Johnson av Suite 100 Stuart, fl 34994 772 260 1328 Kurt Horvath
10-08-2008, 13:54
Post: #23
Has anyone determined if these are in any way germane to older PT's, even partially? If so, I would like one as well.
Thanx
Dick Hayden - '87 PT 38'
11709 122nd St N.E.
Lake Stevens, WA 98258
10-09-2008, 01:58
Post: #24
Kurt,
I've tried emailing you 3 times over the last couple of weeks, and I continually get a Mailer-Demon notice that it failed. Anyways, I definitely would love a CD if you still have some available. I will gladly help you offset cost anyway you need. Corey Graham 3367 Preston Hills Circle Prosper, TX 75078 Corey@... Thanks so much for this effort! Corey and Jenni Graham 1996 PT42 Series60 Prosper, TX/ Osage Beach, MO --- In WanderlodgeForum@yahoogroups.com, jim riordan > > I would like one > > Jim Riordan > 851 Johnson av > Suite 100 > Stuart, fl 34994 > 772 260 1328 > > > Kurt Horvath > > I sent out 23 disks today. I have burnt 50 disks. Who Wants one? > > In my zeal to get this done I neglected to index the files. When you > open the disk you will see lots of PDF's and TIFF files. I have > compiled an index that will direct you to what your searching for. I > didn't realize it until after I mailed the disks and was looking at > some files did I realize that you have to open each file and look at > the legend to tell what the heck you've opened. A poor way to search > at best. This index is not perfect but it will facilitate your search > of the files. The Index is pasted below. > > BAD SCANS are incomplete scans that are viewable, an edge or a side > wasn't scanned. There will be several duplicates. Some are duplicates > some are revisions or updates. One important revision is the one > addressing the Jake Brake / Engine Brake Modification. Look at scan > 501, 502 , there may be another but it's eluding me at the moment. > > I have had many offers to help deter the cost of this project. A few > are exempt from any obligation due to their help, donation and > participation in this project, specifically Wallace and Bruce. I have > forwarded a disk to all three web sites and will send a few out to > our BIRD GURU'S. I have one offer to host this inf. free of charge, > available to all who have an interest, we'll see how this progresses > and another forum member with a complete set of diagrams that when > time allows will cross check these diagrams against his to fill in > any gaps. If you are compelled to help with the cost of this project > I would appreciate it. I have over 60 hours and $'S in it and this > entire week was devoted to it. KNOWLEDGE IS POWER!!!!! > __________________________________________________ > __________________________________________________ > __________________________________________________ > > INDEX OF 1995 -1996 PT 42 & some 1997 PT 43 FILES > > 16 pgs. Ref. - Wire Reference -From - To - Color - # > > SCAN NUMBERS 439 to 527 > > 439 Diagram Asst., Plumbing, Fresh Water, bad scan > 440 1729813EEEDiagram, WRG. Chassis, DDEC III, End BRK 4203WL bad > scan > 441 6083778 Diagram, Wiring, Load Center, Lower Front > 442 6083729 Diagram Wiring, Charging Circuit > 444 6080956 Diagram, Installation, Aquahot > 445 6083729 Diagram, Wiring, Charging Circuit > 446 6088652 bad scan > 447 1782267A 2 of 2 bad scan > 449 1782259 1 of 2 Diagram, Dual, Air Brake, > 448 Bad Scan > 450 Bad Scan > 451 Bad Scan > 452 Bad Scan > 455 1729813EEE Diagram, WAG, Chassis, DDEC III, Eng. Brake. BS > 456 Bad Scan > 457 Diagram Fresh Water System Legend not scanned > 458 6083711 Diagram Electrical System bad scan > 459 6051999 Diagram Assy, Electrical Component Panel, Rear, 12V > 460 6080956 Diagram, Installation, Aquahot > 461 6080956 Same As Above > 462 6053227 Diagram Assy, Electrical Component Panel, Overhead Front > 463 6068670 Diagram, L.P. Gas Piping, State > 464 6053227 Diagram Assy, Electrical Component Panel, Overhead Front > 465 6046422 Diagram Wiring, Charging Circuit > 466 6068670 Diagram, L.P. Gas Piping, State > 467 6046445 Diagram, Electrical Systems top edge bad scan > 468 6083729 Diagram Charging Circuit, Bad Scan > 469 6049100 1 of 11Diagram Harness, Wiring, 12VDC. RH > 470 2 of 11 > 471 3 of 11 > 472 4 of 11 > 473 5 of 11 > 474 6 of 11 > 475 7 of 11 > 476 8 of 11 > 477 9 of 11 > 478 10 of 11 > 479 11 of 11 > 480 Copy 5 of 11 > 481 Copy 5 of 11 > 482 6049076 2 of 3 Harness, Wiring 120VAC, LH > 483 3 of 3 > 484 1 of 3 > 485 2 of 3 > 486 3 of 3 > 487 3 of 3 > 488 6049092 1 of 14 Harness, Wiring, 12VDC, LH > 489 2 of 14 > 490 3 of 14 > 491 4 of 14 > 492 5 of 14 > 493 6 of 14 > 494 7 of 14 > 495 8 of 14 > 496 9 of 14 > 497 10 of 14 > 498 11 of 14 > 499 6049100 7 of 11 Harness, Wiring, 12VDC, RH > 500 " " 6 of 11 > 501 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake > 502 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake > 503 6051981 Diagram, Assy, Electrical Component Panel, Overhead Front > 504 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake > 505 6083778 Diagram, Wiring, Load Center, Lower Front - Superseded by > # 6087878 > 506 Same As Above > 507 6083075 Diagram, Assy, Plumbing, Fresh Water > 508 6080956 Diagram, Installation, Aquahot > 509 6083729 Diagram, Wiring, Charging Circuit > 510 1782259 Diagram, Dual Air Brake, Sheet 1 of 2 > 511 6083711 Diagram, Electrical Systems > 512 6053227 Diagram, Assy, Electrical, Overhead Front > 513 6083711 Diagram, Electrical Systems > 514 1782259 Diagram, Dual Air Brake, Sheet 1 of 2 > 515 6053227 Diagram, Assy, Electrical Component Panel, Overhead Front > 516 1782267 Diagram, Dual Air Brake, Sheet 2 of 2 > 517 6068670 Diagram, L.P. Gas Piping, State > 518 Unknown Diagram, Electrical Systems 120/220????? > 519 6083729 Diagram, Wiring, Charging Circuit > 520 6053227 Diagram, Assy, Electrical Component Panel, Overhead Front > 521 6046122 Diagram, Wiring, Charging Circuit > 522 6083075 Diagram, Assy, Plumbing, Fresh Water > 523 6051999 Diagram Assy, Electrical Component Panel, Rear, 12VDC > 524 6080956 Diagram Installation, Aquahot > 525 6080956 Duplicate Print > 526 6068670 Diagram, L.P. Gas Piping, State > 527 6053227 Diagram Assy, Electrical Component Panel, Overhead Front > > TIFF FILES ARE NUMBERED THE SAME AS THE PDF FILES. > > Kurt Horvath > 95 PT 42 WLWB > 10AC > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > > > > David, > > > > I need an address. By the way Chris Miller @ Prevost in Nashville > sez > > Hello. > > > > Kurt Horvath > > 95 PT 42 > > 10AC > 0 > |
10-09-2008, 04:01
Post: #25
Corey,
There's one on the way. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "coreyg67" > > Kurt, > > I've tried emailing you 3 times over the last couple of weeks, and I continually get a > Mailer-Demon notice that it failed. > > Anyways, > > I definitely would love a CD if you still have some available. I will gladly help you offset > cost anyway you need. > > Corey Graham > 3367 Preston Hills Circle > Prosper, TX 75078 > Corey@... > > Thanks so much for this effort! > > Corey and Jenni Graham > 1996 PT42 Series60 > Prosper, TX/ Osage Beach, MO > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > > > I would like one > > > > Jim Riordan > > 851 Johnson av > > Suite 100 > > Stuart, fl 34994 > > 772 260 1328 > > > > > > Kurt Horvath > > > > I sent out 23 disks today. I have burnt 50 disks. Who Wants one? > > > > In my zeal to get this done I neglected to index the files. When you > > open the disk you will see lots of PDF's and TIFF files. I have > > compiled an index that will direct you to what your searching for. I > > didn't realize it until after I mailed the disks and was looking at > > some files did I realize that you have to open each file and look at > > the legend to tell what the heck you've opened. A poor way to search > > at best. This index is not perfect but it will facilitate your search > > of the files. The Index is pasted below. > > > > BAD SCANS are incomplete scans that are viewable, an edge or a side > > wasn't scanned. There will be several duplicates. Some are duplicates > > some are revisions or updates. One important revision is the one > > addressing the Jake Brake / Engine Brake Modification. Look at scan > > 501, 502 , there may be another but it's eluding me at the moment. > > > > I have had many offers to help deter the cost of this project. A few > > are exempt from any obligation due to their help, donation and > > participation in this project, specifically Wallace and Bruce. I have > > forwarded a disk to all three web sites and will send a few out to > > our BIRD GURU'S. I have one offer to host this inf. free of charge, > > available to all who have an interest, we'll see how this progresses > > and another forum member with a complete set of diagrams that when > > time allows will cross check these diagrams against his to fill in > > any gaps. If you are compelled to help with the cost of this project > > I would appreciate it. I have over 60 hours and $'S in it and this > > entire week was devoted to it. KNOWLEDGE IS POWER!!!!! > > __________________________________________________ > > __________________________________________________ > > __________________________________________________ > > > > INDEX OF 1995 -1996 PT 42 & some 1997 PT 43 FILES > > > > 16 pgs. Ref. - Wire Reference -From - To - Color - # > > > > SCAN NUMBERS 439 to 527 > > > > 439 Diagram Asst., Plumbing, Fresh Water, bad scan > > 440 1729813EEEDiagram, WRG. Chassis, DDEC III, End BRK 4203WL bad > > scan > > 441 6083778 Diagram, Wiring, Load Center, Lower Front > > 442 6083729 Diagram Wiring, Charging Circuit > > 444 6080956 Diagram, Installation, Aquahot > > 445 6083729 Diagram, Wiring, Charging Circuit > > 446 6088652 bad scan > > 447 1782267A 2 of 2 bad scan > > 449 1782259 1 of 2 Diagram, Dual, Air Brake, > > 448 Bad Scan > > 450 Bad Scan > > 451 Bad Scan > > 452 Bad Scan > > 455 1729813EEE Diagram, WAG, Chassis, DDEC III, Eng. Brake. BS > > 456 Bad Scan > > 457 Diagram Fresh Water System Legend not scanned > > 458 6083711 Diagram Electrical System bad scan > > 459 6051999 Diagram Assy, Electrical Component Panel, Rear, 12V > > 460 6080956 Diagram, Installation, Aquahot > > 461 6080956 Same As Above > > 462 6053227 Diagram Assy, Electrical Component Panel, Overhead Front > > 463 6068670 Diagram, L.P. Gas Piping, State > > 464 6053227 Diagram Assy, Electrical Component Panel, Overhead Front > > 465 6046422 Diagram Wiring, Charging Circuit > > 466 6068670 Diagram, L.P. Gas Piping, State > > 467 6046445 Diagram, Electrical Systems top edge bad scan > > 468 6083729 Diagram Charging Circuit, Bad Scan > > 469 6049100 1 of 11Diagram Harness, Wiring, 12VDC. RH > > 470 2 of 11 > > 471 3 of 11 > > 472 4 of 11 > > 473 5 of 11 > > 474 6 of 11 > > 475 7 of 11 > > 476 8 of 11 > > 477 9 of 11 > > 478 10 of 11 > > 479 11 of 11 > > 480 Copy 5 of 11 > > 481 Copy 5 of 11 > > 482 6049076 2 of 3 Harness, Wiring 120VAC, LH > > 483 3 of 3 > > 484 1 of 3 > > 485 2 of 3 > > 486 3 of 3 > > 487 3 of 3 > > 488 6049092 1 of 14 Harness, Wiring, 12VDC, LH > > 489 2 of 14 > > 490 3 of 14 > > 491 4 of 14 > > 492 5 of 14 > > 493 6 of 14 > > 494 7 of 14 > > 495 8 of 14 > > 496 9 of 14 > > 497 10 of 14 > > 498 11 of 14 > > 499 6049100 7 of 11 Harness, Wiring, 12VDC, RH > > 500 " " 6 of 11 > > 501 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake > > 502 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake > > 503 6051981 Diagram, Assy, Electrical Component Panel, Overhead Front > > 504 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake > > 505 6083778 Diagram, Wiring, Load Center, Lower Front - Superseded by > > # 6087878 > > 506 Same As Above > > 507 6083075 Diagram, Assy, Plumbing, Fresh Water > > 508 6080956 Diagram, Installation, Aquahot > > 509 6083729 Diagram, Wiring, Charging Circuit > > 510 1782259 Diagram, Dual Air Brake, Sheet 1 of 2 > > 511 6083711 Diagram, Electrical Systems > > 512 6053227 Diagram, Assy, Electrical, Overhead Front > > 513 6083711 Diagram, Electrical Systems > > 514 1782259 Diagram, Dual Air Brake, Sheet 1 of 2 > > 515 6053227 Diagram, Assy, Electrical Component Panel, Overhead Front > > 516 1782267 Diagram, Dual Air Brake, Sheet 2 of 2 > > 517 6068670 Diagram, L.P. Gas Piping, State > > 518 Unknown Diagram, Electrical Systems 120/220????? > > 519 6083729 Diagram, Wiring, Charging Circuit > > 520 6053227 Diagram, Assy, Electrical Component Panel, Overhead Front > > 521 6046122 Diagram, Wiring, Charging Circuit > > 522 6083075 Diagram, Assy, Plumbing, Fresh Water > > 523 6051999 Diagram Assy, Electrical Component Panel, Rear, 12VDC > > 524 6080956 Diagram Installation, Aquahot > > 525 6080956 Duplicate Print > > 526 6068670 Diagram, L.P. Gas Piping, State > > 527 6053227 Diagram Assy, Electrical Component Panel, Overhead Front > > > > TIFF FILES ARE NUMBERED THE SAME AS THE PDF FILES. > > > > Kurt Horvath > > 95 PT 42 WLWB > > 10AC > > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > > > > > > > David, > > > > > > I need an address. By the way Chris Miller @ Prevost in Nashville > > sez > > > Hello. > > > > > > Kurt Horvath > > > 95 PT 42 > > > 10AC > > 0 > > > |
10-09-2008, 04:27
Post: #26
I have 7 CD's left over from the 50 I made and packaged for mailing.
If you would like one I need your mailing address. My e-mail is KGUNS@... Or you can post it here. Most everyone has asked if they can help out with the cost. I have let you set the cost, the folks that have just gone ahead and sent a little help has averaged $20.00. You are under no obligation to contribute. The little lady didn't quit understand why I did this. I did it because I could, and if you've ever been up to your ass in Alligators, you need to know where the red #8 wire in the front of the coach ends up in the back of the coach, and your feed up with paying to teach these techs how to work on your coach then you'll understand my madness. You'll understand why this web site and the others are PRICLESS!!! Knowledge is Power! Kurt Horvath 95 PT 42 10AC |
08-18-2012, 05:25
Post: #27
great job did you send me disk.. Wallace & Faye Craig 95 WLWB 42 Azle, Texas
