Wellnut Fastners
09-16-2007, 02:24
Wellnut Fastners
Discovered that a branch pulled the front of my main awning loose,upon
inspection I found a device or what was left of it called a Wellnut.
Apparently the Stainless steel machine screw goes through the awning
flange and is threaded into this fastener and somehow when it is
thightened holds the awning flange in place. is this the best fastener
for this application? the regular window awnings are all fastened with
stainless screws but this main awning seems to use these Wellnuts for
the entire length of awning flange. Would appreciate suggestions.
Donald Brown 2000 LX-40 Palmetto,Florida
09-16-2007, 02:48
Wellnut Fastners
Donald,
Wellnuts are the most secure way to attach the awning. You drill a hole place
the wellnut insert into the hole then when you screw in the bolt it expands the
insert
making for a very secure fit.
Howard Truitt, Camilla, Ga. 86 PT40
Sent: Sunday, September 16, 2007 10:24 AM
Subject: [WanderlodgeForum] Wellnut Fastners
Internal Virus Database is out-of-date.
Checked by AVG Free Edition.
Version: 7.5.485 / Virus Database: 269.13.10/995 - Release Date: 9/8/2007 1:24
PM
09-16-2007, 02:56
Wellnut Fastners
Thank you, I'll call Bluebird in the morning order enough for the repair
Donald Brown, 2000 LX-40 Palmetto,Florida
"Howard O. Truitt" wrote:
Donald,
insert
1:24 PM
Building a website is a piece of cake.
Yahoo! Small Business gives you all the tools to get online.
09-16-2007, 03:15
Wellnut Fastners
Donald,
Check your Yellow Pages for Fasteners - Industrial & Construction. listings up
here are chains, Fastenal Company and Ricco Fasteners Inc.. This would give you
a chance to compare and ask questions about installation. Good luck.
Sent: Sunday, September 16, 2007 10:56 AM
Subject: Re: [WanderlodgeForum] Wellnut Fastners
"Howard O. Truitt" wrote: Donald,
insert
PM
PM
09-16-2007, 04:54
Wellnut Fastners
--- In WanderlodgeForum@yahoogroups.com, "rvdependent"
Goole wellnuts.You will find location near you.
Bob Loomas 1985 PT 36
loose,upon
fastener
with
