Troubleshooting help
09-11-2007, 04:07
I have a new issue I would like to enlist the help of this esteemed
knowledge base. During our last trip, our suspension light stayed lit
even after the coach was ready to drive. My air gauges for tag axle
and front/rear suspension are operating normally. Tax axle pressure
shows 60 psi, and the front/rear suspension gauges show 115psi,
however my suspension warning light stays on (it actually stays
flashing). Also, on visual inspection all of the airbags appear to be
operating normally and the suspension airs up and dumps properly. Any
cause I could troubleshoot myself?
Thanks in advance for your help.
Drew May
88WLWB40
09-11-2007, 04:18
Hi Drew:
On the drivers side front of the Coach, under the bumper and back a little,
there should be a module there with 1/4 inch black plastic lines going to
it, be sure it is not by passing air, there will be wires attached to it
and those wires should be going to your suspension dump light.
Safe travels,
84FC35
Duncan, Oklahoma
>Drew May
>88WLWB40
Safe travels,
84FC35
Duncan, Oklahoma
09-11-2007, 04:34
I can't help with the problem, but thought that it should be noted that you do
NOT have a gauge for the front/rear suspension unless yours is unusual. That
gauge is for front/rear brakes, and is separate from the suspension. To test
that this is true, watch the gauge when you dump your suspension.
>Drew May
>88WLWB40
