Water in fuel sensor
01-11-2008, 03:18
Howard, Bill and others,
I just uploaded a .pdf schematic of the water in fuel sensor to the
"files" section of the site. It's called "Water in fuel sensor
schematic". I can't remember where I bought it- maybe B Bird Parts??
Anyhow, there is a Cooper Wiring Devices website with links to
dealers. The sending unit is a Model 913 Coolant level sensor that has
both normally open and normally closed pins. You'll also need the
Packard connector that fits the waterproof :-) plug on the sensor. I
think that Bluebird wired our coaches with 2 wires to the sending
unit, so you'll need to adapt the 4-wire Packard pigtail by only
connecting the signal and ground to the correct wires. It's a good
feature to have- My coach came complete with a rusted out fuel tank
thanks to a faulty sensor. When I cut out the bad section, it was full
of rust and water. Since then, I make it a point to drain a gallon or
so regularly from the bottom of the tank.
Shane Fedeli
85PT40
Hershey, PA
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Shane,
> Please send me the part number for the sending unit and the site you
found it at.
> Howard Truit, Camilla, Ga.
> 86 PT40
01-11-2008, 03:43
Thanks again Shane,
Here is the Cooper Standard automotive web site.
http://www.cooperstandard.com/us/en/heav...operSpecs.
asp
Click on Heavy truck sensor specs
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...>
has
full
or
> Shane Fedeli
> 85PT40
> Hershey, PA
> > Shane,
you
> found it at.
> > 86 PT40
