1987 PT40 Grease and Zerk Fittings
05-21-2007, 07:32
Hi all,
Do I need to use a special lube for my brake Zerk fittings? I could not
locate the "Stopmaster" NLG1 grade #1 type. These are self adjusting
type brakes.
Also, what is the recommended lube for the other bus Zerk fitting? Or
does it matter so long as it is grade NLG1 grade #2? Nappa has like ten
types of this stuff and they recommended simply using the plane lithium
type.
Thanks for the help,
Don Duncan
1987 PT40
Beaverton, Oregon
05-21-2007, 09:42
just use the same good grease You use on the rest of the coach
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "worktohobby"
> Hi all,
> type brakes.
> type.
> Don Duncan
> 1987 PT40
> Beaverton, Oregon
