In Yuma.....hydraulic levelers fuse??? solenoid part number that would exchange
12-22-2006, 10:27
Hi group
mom and I are still in Yuma area, sun's out, nice....
Levelers quit (motor, solanoid?) service came out today, still
uncertain if the solenoid is good, went back to shop to get one and
they haven't one and HWH not available to get a crossover number.
Couldn't find where the fuse might be.....anyone able to help me there?
Guess now we have to wait until after Christmas, tho if there is a fuse
I could check as per trouble shooting the motor not coming on....
the blue lights activate without the key being on or in accessory....
when I turn on the switch....didn't do that before.
I damaged the L front leveler a couple weeks ago, (took out a hidden
post (ha!) anyway the other 3 still worked and haven't needed to use
them this last week. The other night tho I could have used one of the
rear ones and that is when I found the blue lights came on with the
switch without the key on and the motor is quiet.....
I thought the problem was crushed hydraulic lines (it was a big solid
low post) anyway those lines are the chassis heat lines next to the
frame under left front. Would there be a problem if I just bypassed,
plugged or ran them back into each other with more hose? We aren't
using the chassis heat. Don't want to take a chance of springing a leak
and loosing coolant on the road.
Have a great holiday
Rose Mary
82 FC 33
JP's White Bird
Yuma
12-22-2006, 14:22
RoseMary:
Fuse or circuit breaker for the pump?
Under the top entry step, it should lift up and you might or might now have to
remove a cover to see it.
Merry Christmas to you
Terrace, B.C. Canada
----- Original Message ----
Sent: Friday, December 22, 2006 2:27:12 PM
Subject: [WanderlodgeForum] In Yuma.....hydraulic levelers fuse??? solenoid part
Hi group
the blue lights activate without the key being on or in accessory... .
when I turn on the switch....didn' t do that before.
Rose Mary
82 FC 33
JP's White Bird
Yuma
Do You Yahoo!?
http://mail.yahoo.com
12-23-2006, 15:38
Bill
I know about the leveler reservoir under the step, there is a hole
there to fill, can't see a fuse anywhere???
thanks
Rose Mary
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> RoseMary:
now have to remove a cover to see it.
> From: Rose Mary
> Hi group
there?
fuse
accessory... .
hidden
use
solid
bypassed,
leak
> Rose Mary
> 82 FC 33
> JP's White Bird
> Yuma
> Do You Yahoo!?
