squealing suburban heater
11-29-2006, 16:09
Another question comes to mind, 2 of our suburban heaters are
squealing, is there a way to lubricate them? Where? how?
Rose Mary
82 FC Side bath
in Nevada
11-29-2006, 22:52
Hi Rosemary,
All of mine used to squeal- it is the blower fan bearings. If you
can pull the furnaces out of your coach and remove the motors- drill
a small 1/16" hole in the fan housings beside the shafts (one comes
out the front and one comes out the rear) on the motor. This will
allow you to put some 3-in-1 electric motor oil into the sealed
bearing. Usually, it will not run down the shaft past the seals, so
you cannot just lube the shaft, you have to drill the holes too.
This is a pretty advanced opearation for the shadetree mechanic.
The whole back end of the furnace has to be disassembled in order to
remove the fan motor and you have to be very careful not to damage
any of the gaskets that prevent CO from getting into the coach from
the exhaust side of the furnace. You may also consider just replacing
the unit with a newer, more efficient one from camping world. They
should last 10 years or so with no squealing.
If anyone else is having this problem, we could do a Removal and
Repair workshop at the Maxton, NC rally this spring.
Shane Fedeli
85PT40
Hershey, PA
--- In WanderlodgeForum@yahoogroups.com, "Rose Mary"
> Rose Mary
> 82 FC Side bath
> in Nevada
11-30-2006, 01:37
And here is the rest of the story as some old fellow always says
(what IS his name??). Here is all of the manuals you will probably
need to service your appliances in the coach.
http://www.bryantrv.com/sitemap.html
The one for your furnace I believe is a NT-16SW which is in my 1985
PT40. http://bryantrv.com/docs2/docs/ntseries.pdf
tom warner
vernon center,ny
1985 PT 40
At 05:52 AM 11/30/2006, you wrote:
>Hi Rosemary,
>Shane Fedeli
>85PT40
>Hershey, PA
> > Rose Mary
> > 82 FC Side bath
> > in Nevada
>Yahoo! Groups Links
11-30-2006, 04:08
Thanks Shane
that sounds like more than I want to tackle. Guess for now we'll
live with the squeal, maybe we won't need the squeaky ones when we
get to Arizona Smile
thanks
Rose Mary
82 FC
Sunny tho cold Nevada
--- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...>
> Hi Rosemary,
you
drill
comes
so
mechanic.
to
from
replacing
> Shane Fedeli
> 85PT40
> Hershey, PA
> > Rose Mary
> > 82 FC Side bath
> > in Nevada
12-01-2006, 01:42
Tom, Great find, Thanks Much.
Bob Janes, Greenville, SC
> tom warner
> vernon center,ny
> 1985 PT 40
> >Hi Rosemary,
you
drill
mechanic.
to
replacing
> >Shane Fedeli
> >85PT40
> >Hershey, PA
> > > Rose Mary
> > > 82 FC Side bath
> > > in Nevada
> >Yahoo! Groups Links
