location of oil sending unit
11-27-2006, 08:50
Can anyone tell me where the oil sending unit on a 8V92 in a 1994
coach.
Thanks
Nelson Slinkman
Westminster, Md
11-27-2006, 10:15
Nelson:
I can tell you where mine is and that will get you started.
Approx 2 feet in front of the rear bumper on the right hand side is a sender
about 2" in diameter, gold annodized with a single wire. It screws into a
small brass fitting mounted to the frame. Easy change. Hope this helps.
Leroy Eckert
1990 WB-40 "Smoke N Mirrors"
Niceville, FL
Sent: Monday, November 27, 2006 2:50 PM
Subject: [WanderlodgeForum] location of oil sending unit
coach.
Thanks
Nelson Slinkman
Westminster, Md
