headlight upgrade problem
07-06-2006, 08:57
I was in the middle of some repairs and had to use the coach for a
medi-vac type thing. Hence I did the headlamp upgrade very quickly. I used one relay for the low beams and one for the high beams. Brand new circuit breakers for both of them. Everything seemed fine. We left right before dusk for a 700 mile trip (one way). When I turned the headlights on at dusk, the drivers side light was cutting in and out randomly. Since I wasn't in a position to stop and check the connections, we just keep going. After about two hours, it came on steady and has stayed on consistantly. Originally I thought maybe I didn't have the relay grounded that well ( I still think I'll re-do that ). But if that was the problem, wouldn't both lights have been cutting in and out? Any thoughts? Tom Sorrentino Bedford Hills, NY 1978 fc 33' |
07-06-2006, 09:51
Tom,
Test that headlight and socket to see if you can duplicate the problem. Be sure the socket wires are all clean/tight and the socket fits snug to the headlight. I have new sockets if you need them. I don't like things that FIX themselves...scary. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. thomas_sorrentino wrote: > I was in the middle of some repairs and had to use the coach for a > medi-vac type thing. Hence I did the headlamp upgrade very quickly. I > used one relay for the low beams and one for the high beams. Brand new > circuit breakers for both of them. Everything seemed fine. We left > right before dusk for a 700 mile trip (one way). When I turned the > headlights on at dusk, the drivers side light was cutting in and out > randomly. Since I wasn't in a position to stop and check the > connections, we just keep going. After about two hours, it came on > steady and has stayed on consistantly. Originally I thought maybe I > didn't have the relay grounded that well ( I still think I'll re-do > that ). But if that was the problem, wouldn't both lights have been > cutting in and out? Any thoughts? > > Tom Sorrentino > Bedford Hills, NY > 1978 fc 33' > > |
07-06-2006, 14:21
Tom,
Don't know why only one would flicker, but I doubt it is the ground. When I did my upgrade, my ground worked loose, and it resulted in the relay burning up with considerable smoke and horrible odor. Had to drive home on park lights & driving lights. You problem sounds like it is probably down stream of the relay. Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > I was in the middle of some repairs and had to use the coach for a > medi-vac type thing. Hence I did the headlamp upgrade very quickly. I > used one relay for the low beams and one for the high beams. Brand new > circuit breakers for both of them. Everything seemed fine. We left > right before dusk for a 700 mile trip (one way). When I turned the > headlights on at dusk, the drivers side light was cutting in and out > randomly. Since I wasn't in a position to stop and check the > connections, we just keep going. After about two hours, it came on > steady and has stayed on consistantly. Originally I thought maybe I > didn't have the relay grounded that well ( I still think I'll re-do > that ). But if that was the problem, wouldn't both lights have been > cutting in and out? Any thoughts? > > Tom Sorrentino > Bedford Hills, NY > 1978 fc 33' > |
