pdi converters etc.
06-07-2006, 06:06
pdi converters etc.
I found the web site. What do I need to replace the old battery
chargers???
How many amps??
Thanks.
Hank Hannigan
80FC31
06-07-2006, 07:29
pdi converters etc.
I ordered two of the PD9155R 55 AMP ELECTRONIC POWER CONVERTER with the
CHARGE WIZARDS. PDI was out of stock so they sent me the 60 amp
chargers. I would buy two of the 55 amp if you are replacing two old
chargers and buy two of the Charge Wizard.
> chargers???
> How many amps??
> Thanks.
> Hank Hannigan
> 80FC31
06-07-2006, 07:57
pdi converters etc.
I replaced the original chargers with (2) 55 Amp models. I
purchased Iota Brand, very simular circuitry, if not functionally
identical, to the PDI units.
My bank is 480 Amp Hours.
If you plan on using lead-acid cells, it makes no sense to exceed
27% of the banks total Amp Hour rating with charging Amps. This is
because of the internal resistance of lead-acid cells. They simply
will not accept the additional amperage.
The internal resistance specs of AGM cells is a different story.
They have much lower resistance, and therefore, will accept a much
greater kick in the pants ... but that's another story for another
day.
James
78FC33SB "Old School" -- but charges "Smartly" .. LOL
Tunica, MS
