Dead Batteries
05-31-2005, 06:47
Dead Batteries
Went to storage to start bus & generator after three weeks of sitting.
Left 12 Volt master on and all the batteries were totally dead. Jumped
the gen to start it. Let it run for 1 1/2 hours. Bus still would not
start. Turned off gen. Volt meter read batteries charged to 10 volts.
Went back today to start gen and charge batteries some more. Gen
battery dead. House batteries totally dead. Checked charge to
batteries yesterday: 12 volts. Did I ruin all batteries, house and
gen? They were all replaced 5 months ago.
Yeah, I know, I had another senior moment leaving the switch on.
Mark
88 PT40
San Diego 75 & sunny
05-31-2005, 07:16
Dead Batteries
Had the same thing happen once in a remote location,
after all was said and done I found out that a relay
that need to trip for the generator to charge house
and engine batteries must have en excess of 10 volts.
I learned later that all I would have had to do was
jump the engine batteries off my tow vehicle or
another vehicle to get a jump on the batteries long
enough to trip the relay so the engine batteries could
be charged. My coach was also a 40 ft. with the
8V92.......
> weeks of sitting.
> Bus still would not
> some more. Gen
> Checked charge to
> the switch on.
> Mark
> 88 PT40
__________________________________
Do you Yahoo!?
Yahoo! Mail - Helps protect you from nasty viruses.
http://promotions.yahoo.com/new_mail
11-15-2006, 16:02
Dead Batteries
Just went out to the bird for the first time in about 2 weeks and the
batteries are stone dead..... I did notice when I plugged it in 2
weeks ago that the polarity little lights in the electrical cord door
compartment ,,only 1 of the 2 lights lit up... I also can tell that the
charger is not working cause I could always hear it running ..
I have a freedom inverter charger...... I,m thinking a breaker or
something has tripped ,,but that is just a guess. need some help here
from those that know the electrical stuff....... thanks DAN
92 WLWB 40ft.
Summerfield Fl./epere Wi.
11-16-2006, 01:29
Dead Batteries
Dan:
Is it possible that one leg is lost.Check the overhead volt guages for power.
(120 volt legs) My coach inverter/charger uses leg 1. Check the main breakers,
mine are above the bed.
Leroy Eckert
1990 WB-40 "Smoke N Mirrors"
Niceville, FL
Sent: Wednesday, November 15, 2006 10:02 PM
Subject: [WanderlodgeForum] dead batteries
92 WLWB 40ft.
11-16-2006, 04:41
Dead Batteries
> Dan:
for power. (120 volt legs) My coach inverter/charger uses leg 1.
Check the main breakers, mine are above the bed.
> Leroy Eckert
> Niceville, FL
>. Leroy.... Checked the main breaker and it is ok....My overhead
gauges are for my generator only I believe....I am going to buy a
meter to check if I,ve lost a leg cause there is 0 nothing notta no
power anywhere in my coach> ... Dan
> 92 WLWB 40ft.
11-16-2006, 06:39
Dead Batteries
Dan
I had a problem very similar to this in mid October when I took my coach to
FL. Generator powered all circuits but like you nothing from shore power,
surge protector would not let any thing through on 50, 30 or 20 amps. I
just put it off to bad wiring at the camp ground, dropped it off at
Parliament Coach in St. Petersburg and flew home. I got a call from them a
week later that they could not get shore power to work either. They were
going to check from the plug back to the surge protector and see if the
problem was in the cord / plug / connections before the surge protector,
don't know what they found but I'll follow up today and let you know.
On the gauges mine read for both shore power and the generator.
Steve Quandt
Iron Mountain, MI
1993-PT40
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Dan Saari
Sent: Thursday, November 16, 2006 10:42 AM
Subject: [WanderlodgeForum] Re: dead batteries
> Dan:
> Leroy Eckert
> Niceville, FL
> 92 WLWB 40ft.
11-16-2006, 07:18
Dead Batteries
Hey Guys ,, thanks for the help ... I got it figured out with a
meter checking it back from the plug... It was the 40 amp breaker
that went bad on 1 leg and because the charger was,nt working ,,
killed the batteries dead dead... so I,m hoping They hav,nt been hurt
by being run down to nothing......... thanks again... this is the
place to ask the question
1992 WLWB 40 ft.
Summerfield Fl.// Depere wi.
--- In WanderlodgeForum@yahoogroups.com, "smquandt"
> Dan
coach to
power,
amps. I
from them a
They were
protector,
know.
> Steve Quandt
> Iron Mountain, MI
> 1993-PT40
> _____
> > Dan:
guages
> > Leroy Eckert
> > Niceville, FL
> > 92 WLWB 40ft.
11-16-2006, 07:47
Dead Batteries
Dan
Pleading ignorance here, the 40 amp breaker is located where???
Steve Quandt
Iron Mountain, Mi
1993-PT40
_____
Sent: Thursday, November 16, 2006 1:19 PM
1992 WLWB 40 ft.
> Dan
coach to
power,
amps. I
from them a
They were
protector,
know.
> Steve Quandt
> Iron Mountain, MI
> 1993-PT40
> _____
yahoogroups.com
yahoogroups.com
> > Dan:
guages
> > Leroy Eckert
> > Niceville, FL
> > 92 WLWB 40ft.
11-17-2006, 01:12
Dead Batteries
TWWO WEEKS, YOU HAVE A LONELY BIRD!
Assuming the you have a 50A and two 30a conex and the you are feedinf
with 15a have you tried to plug the wire in the other 30a connex?
jqrjr
--- In WanderlodgeForum@yahoogroups.com, "Dan Saari"
here
> 92 WLWB 40ft.
11-17-2006, 04:40
Dead Batteries
Steve, I think the 40AmpB is not on the coach, it's on the supply to
the coach. Sounds like one of the two legs of power never got to the
shore receptical. If you notice a 220, 240 breaker has two flip
switches tied together , sounds like one of the two switches went
bad and the other never switched off. that may be why he had only one
green polarity light. ????
If I have to let my bus stand for several days away from 50 amps, I
plug one of two chargers directly into an extension cord then off to
a docking receptical. I often thought of running a jump from that
mini shore location (charger bay) to the refrigerator (IceBox) for
the low amp docking of refrig and one charger. During the hookup
there would be less danger that use of Electric in the bus will
overload and trip the mini shore breaker.
GregoryO'Connor
94PtRomolandCa
> Dan
> Steve Quandt
> Iron Mountain, Mi
> 1993-PT40
> _____
hurt
> 1992 WLWB 40 ft.
> > Dan
my
> coach to
shore
> power,
> amps. I
at
> from them a
> They were
if
> the
> protector,
> know.
> > Steve Quandt
> > Iron Mountain, MI
> > 1993-PT40
> > _____
> > From: WanderlodgeForum@ 40yahoogroups.com>
> yahoogroups.com
> > [mailto:WanderlodgeForum@ 40yahoogroups.com>
> yahoogroups.com
> > --- In WanderlodgeForum@ 40yahoogroups.com>
> > wrote:
> > > Dan:
> guages
> > > Leroy Eckert
> > > Niceville, FL
no
> > > 92 WLWB 40ft.
