89sp telescoping steering stuck
05-11-2006, 05:24
When I first bought this rig last year, Itried the telescoping wheel
and it worked(dont remember if I moved it up or down). I havent been
able to move it since. I removed the two blake covers around the
coulmn but still cant get it to budge either up or down. I know about
loosening the hub, counterclockwise to adjust, and clockwise to tighten
any help will be welcomed
Thanks
Ed Gardels 89sp
Arlington Texas
05-11-2006, 07:27
Pry off the top of the steering wheel center (the part with the horn
button in the middle, leaving the indented-black knob surround), you
will see the mechanism beneath it. It is possible that the nut came
loose and the lock mechanism stop somehow got rotated out of position.
The wheel center should turn freely when in the loose/telescope
position.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "ED GARDELS"
wheel
tighten
> Thanks
> Ed Gardels 89sp
> Arlington Texas
05-11-2006, 09:17
Hi ED,
In addition to Jeff's suggestion,
Be careful with the yellow horn wire, It is very short, the push on
wire tab connector is easily bent,
Then the horn blows making left/ right turns.
We and especially other drivers, did not like this intermittent horn.
Bill 88 FC
wheel
about
tighten
> Thanks
> Ed Gardels 89sp
> Arlington Texas
05-13-2006, 08:45
>Thanks for the response Jeff, I just came in after fixing my
steering wheel... your fix was right on.. nut was loose..
Many thanks
Ed Gardels 89sp
Arlington Texas
horn
you
came
position.
> position.
> - Jeff Miller
> in Holland, MI
> wheel
been
about
> tighten
> > Thanks
> > Ed Gardels 89sp
> > Arlington Texas
05-13-2006, 08:48
> Thanks Bill for the help.. I did run across the shorting of the
horn wire.. I fixed it by a little liquid electric tape..
Thanks
Ed Gardels 89sp
Arlington Texas
> Hi ED,
on
horn.
> Bill 88 FC
> wheel
been
> about
> tighten
> > Thanks
> > Ed Gardels 89sp
> > Arlington Texas
