Road Conditions, North AZ to South UT
04-02-2006, 16:48
Folks,
Can anyone advise on highway 89 road conditions
from Flagstaff AZ to Page AZ and into southern Utah
intersecting with Interstate 15? Am I likely to see road
closures due to snow? Are there excessive ascents or descents?
I'll be heading north out of Sedona AZ and into Utah.
I'd also be happy to hear about any campground experiences.
TIA,
David Brady
'02 Bluebird LXi, Smokey
Va
04-03-2006, 07:04
David:
Overall, US 89 is a good road. After leaving Flag, it is four lanes and
eventually goes to two lanes approx 10 miles north of Flag. Speed limit
is 65 MPH, well marked pavement with passing lanes on grades. Steepest
climb is after passing Bitter Springs (US 89 and US 89A split at this
point - stay to the right to remain on US 89. The climb is approximately
3 miles - 6% with curves. Page is about 25 miles north of this junction.
You can get fuel at Page at a Shell truck stop on the right as you enter
the 45 MPH speed zone about a mile past Highway 98. Watch the 25 MPH
zone crossing Glen Canyon Dam bridge - they mean it. You'll find the
Utah portion of 89 not as well marked although fairly smooth. About 40
miles west of Page you'll come across a posted Deer Warning area - it's
for real. I assume you will not be going through Zion national Park -
with that assumption, you would then turn left (south) at Kanab, UT and
continue to Fredonia, AZ. At that point, turn west on AZ 389. It becomes
UT 59 at the border at Colorado City/Hillsdale. Be cautious on the
downgrade into Hurricane, UT. It is well-posted - it's 6-8% and many
curves. Jake brake well suited for this grade.
Although I have not been on this road since October, I feel confident
that it is free of any snow/ice - temperatures have been moderating.
Flagstaff is 7000' elevation, Page approximately 4800' and Kanab 4600'
(average). Can't help you on good info regarding RV parks except that
you might check on the Lake Powell (Wahweap) RV Park just north of Glen
Canyon Dam. Also, in St. George, there is Temple View which is within a
mile of I-15 exit 6.
I full-timed in 1998 and 1999. I drive a tour bus about 7 months each
year and have driven this route many times over. With a '02 Lxi, you
should not be challenged with regard to grades or narrow roads. If I
have not answered all of your concerns, let me know.
Regards,
Joe (Pappy) Hagan, St. George, UT
Wannabe
In WanderlodgeForum@yahoogroups.com, David Brady wrote:
> Folks,
> TIA,
> David Brady
> Va
04-03-2006, 15:13
Thank you Pappy, you more than answered my questions and
I will follow your route without modification. (hope you don't
mind my calling you Pappy?) We're looking forward to our
travels thru northern AZ and into UT. I heard that there's a train
ride on the north rim of the Grand Canyon that shouldn't be
missed. We'll let the group know how it works out.
Take Care,
David and Suzana Brady
'02 LXi, Smokey
Va
Joe Hagan wrote:
> David:
04-03-2006, 15:34
David
The Grand Canyon Railway is on the south side of the G.C.
It is at Williams,about 20 miles west of Flagstaff.
If you have time I recommend you go.
Regarding the North Rim,I recall it is closed for winter from mid October
to mid May,
the road might be open sooner,but no one will be there.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WB41
04-03-2006, 15:35
David:
The train ride is between Williams, AZ and the South Rim (Grand Canyon
Railway). I would advise against taking your Lxi to the North Rim, very,
very tight. I go in there wth 40' and 45' coaches. There is parking for
tour/charter buses at the Lodge and Visitors Center- have not seen any
high-end RV's on NR. NR elevation at the entry gate is 8600'. It usually
doesn't reopen until April 15th, sometimes later depending on the snow
depth.
Have a good trip. Yep, Pappy is fine - been my moniker since my days
with Continental Trailways (50's and 60's).
Joe (Pappy) Hagan/St. George, UT
Wannabe
> Take Care,
> '02 LXi, Smokey
> Va
> Joe Hagan wrote:
> > David:
limit
Steepest
this
approximately
junction.
04-03-2006, 17:12
Hope this helps as well,
http://www.utah.com/campgrounds/utahcampgrounds.php
http://www.stateparks.utah.gov/visiting/visiting.htm
http://www.bauersrv.com/
http://www.zionriverresort.com/
http://www.eskimo.com/~noir/southwest/sutah/index.html
Ron, No. Ca.
85PT36 (Camper special)
--- In WanderlodgeForum@yahoogroups.com, David Brady wrote:
> Thank you Pappy,
