Brake line question?
01-12-2006, 11:17
I have a 85 Pt40, the right rear dual tire air line to the brake is
leaking air at the fitting where the rubber hose goes into the brake assembly. I was able to put a hose clamp on it to get it home but now I have to fix it. I was wondering before I tear into this job: how is the line connected? is it a permanent fitting, a compresion or what? and how is the best way to get it off? Do I have to take the entire line off? any insight would be greatly appreciated. I am sure there are many here that have had the same problem. Thanks. John Mann 85 pt40 Granbury Tx. |
01-12-2006, 12:43
John,
The ends are permanently attached to the hose. One end of the hose should have a swivel fitting. Take that off first, then the other end. Take the hose with you to a heavy-duty truck dealership or parts store, and with that and about $5 you can get a new one. David Hollis Springfield,IL Still 'birdless --- In WanderlodgeForum@yahoogroups.com, "tracyt3" wrote: > > I have a 85 Pt40, the right rear dual tire air line to the brake is > leaking air at the fitting where the rubber hose goes into the brake > assembly. I was able to put a hose clamp on it to get it home but now > I have to fix it. I was wondering before I tear into this job: how is > the line connected? is it a permanent fitting, a compresion or what? > and how is the best way to get it off? Do I have to take the entire > line off? any insight would be greatly appreciated. I am sure there > are many here that have had the same problem. Thanks. > > John Mann > 85 pt40 > Granbury Tx. > |
01-19-2006, 15:22
Hello Tracyt3.
Have you fiqured out or has someone answered your question. I had a break line blow on me on the freeway and feel i learned alot bout the braking system on the coach. Chris 78FC33 --- tracyt3 > I have a 85 Pt40, the right rear dual tire air line > to the brake is > leaking air at the fitting where the rubber hose > goes into the brake > assembly. I was able to put a hose clamp on it to > get it home but now > I have to fix it. I was wondering before I tear into > this job: how is > the line connected? is it a permanent fitting, a > compresion or what? > and how is the best way to get it off? Do I have to > take the entire > line off? any insight would be greatly appreciated. > I am sure there > are many here that have had the same problem. > Thanks. > > John Mann > 85 pt40 > Granbury Tx. > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
01-20-2006, 08:53
--- In WanderlodgeForum@yahoogroups.com, Mr Chris Valdes
> > Hello Tracyt3. > > Have you fiqured out or has someone answered your > question. > I had a break line blow on me on the freeway and feel > i learned alot bout the braking system on the coach. > > Chris 78FC33 > > --- tracyt3 > > > I have a 85 Pt40, the right rear dual tire air line > > to the brake is > > leaking air at the fitting where the rubber hose > > goes into the brake > > assembly. I was able to put a hose clamp on it to > > get it home but now > > I have to fix it. I was wondering before I tear into > > this job: how is > > the line connected? is it a permanent fitting, a > > compresion or what? > > and how is the best way to get it off? Do I have to > > take the entire > > line off? any insight would be greatly appreciated. > > I am sure there > > are many here that have had the same problem. > > Thanks. > > > > John Mann > > 85 pt40 > > Granbury Tx. > > > > > > Thanks,I appreciate your responses I have been unable to tackle the problem yet due to work but I will let you know how it turns out thanks again. John Mann > > 85 pt40 > > Granbury Tx > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
01-21-2006, 12:34
> > Hello Tracyt3. > > Have you fiqured out or has someone answered your > question. > I had a break line blow on me on the freeway and feel > i learned alot bout the braking system on the coach. > > Chris 78FC33 > > --- tracyt3 > > > I have a 85 Pt40, the right rear dual tire air line > > to the brake is > > leaking air at the fitting where the rubber hose > > goes into the brake > > assembly. I was able to put a hose clamp on it to > > get it home but now > > I have to fix it. I was wondering before I tear into > > this job: how is > > the line connected? is it a permanent fitting, a > > compresion or what? > > and how is the best way to get it off? Do I have to > > take the entire > > line off? any insight would be greatly appreciated. > > I am sure there > > are many here that have had the same problem. > > Thanks. > > > > John Mann > > 85 pt40 > > Granbury Tx. > > > > if its arubber line it unscrews on each end,take it with you to the parts house and get it matched up,buy two while your at it,so you can replace the other one too,and,make sure they are the same length,it makes a differance. randy dupree 93wb > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
01-30-2006, 11:24
David,Chris and Randy Thanks for the replys
I put the new brake line on today works great also got a spare, thanks for the input. Other than alot of grease and a few crawls under the Coach it was real easy. John Mann 85 pt40 Granbury Tx.--- In WanderlodgeForum@yahoogroups.com, "randydupree2000" > > --- In WanderlodgeForum@yahoogroups.com, Mr Chris Valdes > > > > > Hello Tracyt3. > > > > Have you fiqured out or has someone answered your > > question. > > I had a break line blow on me on the freeway and feel > > i learned alot bout the braking system on the coach. > > > > Chris 78FC33 > > > > --- tracyt3 > > > > > I have a 85 Pt40, the right rear dual tire air line > > > to the brake is > > > leaking air at the fitting where the rubber hose > > > goes into the brake > > > assembly. I was able to put a hose clamp on it to > > > get it home but now > > > I have to fix it. I was wondering before I tear into > > > this job: how is > > > the line connected? is it a permanent fitting, a > > > compresion or what? > > > and how is the best way to get it off? Do I have to > > > take the entire > > > line off? any insight would be greatly appreciated. > > > I am sure there > > > are many here that have had the same problem. > > > Thanks. > > > > > > John Mann > > > 85 pt40 > > > Granbury Tx. > > > > > > if its arubber line it unscrews on each end,take it with you to > the parts house and get it matched up,buy two while your at it,so > you can replace the other one too,and,make sure they are the same > length,it makes a differance. > randy dupree 93wb > > > > > > > > > > > > __________________________________________________ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail.yahoo.com > > > |
