Randy's Dinette & Corian Project
12-20-2005, 01:48
Thanks to John Finn we now have some photos of Randy's completed project. This
project consisted of constructing a new dinette, a small storage cupboard and a
half dozen Corian surfaces. Since I was fairly inexperienced with laminate work
this became Randy's department and before long he figured out how best to put
the stuff on. Thank goodness for the heat gun that was loaned to us. The stuff
really doesn't like to go around corners without a little thermo persuasion.
Corian (actually Formica brand) was another story. This stuff was new to both
of us. We checked out the internet and found the stuff cuts and shapes pretty
much like wood with a few exceptions. While I was cutting and shaping Randy was
teaching himself how to polish the stuff. His automotive tools and polishing
compounds did the trick. He sanded each piece with 320 and then buffed the hell
out of them with various abrasive grits and polishes. The results speak for
themselves. All in all it was a great project and we learned a lot. If I did it
again I'd make sure I had a router table. The red-neck router table that was
cobbled together scared the hell out of me. But that's another story LOL.
Here's the link John Finn has provided for the
pics........http://www.pbase.com/rdupree1/image/53732134
Rob, Sue & Merlin
94 WLWB
12-20-2005, 02:16
Very nice and quite impressive!
What is the material used for the chair back (left
foreground in picture) and is it the laminate that was
shaped with the heat gun to what appears to be a 30-40
degree vertical bend?
John Suter
> Rob, Sue & Merlin
> 94 WLWB
Do You Yahoo!?
http://mail.yahoo.com
12-20-2005, 02:23
> Very nice! Great job Rob and all.
Safe travels,
12-20-2005, 02:39
Hi John. If by 'chair back' you mean the dinette cushion(s) they were covered
by a local upholsterer with Ultra leather. The laminate was Formica brand and
had to be special ordered. Yes we had to heat the Formica for the corners and
were very surprised at how much heat it could take without deforming. The
Formica would take and hold a curved shape if you provided enough heat. A few
test pieces showed us we could put a 180 degree bend in the stuff with about a
three inch radius.
Rob, Sue & Merlin
94 WLWB
Quoting John Suter :
> John Suter
> > Rob, Sue & Merlin
> > 94 WLWB
> Do You Yahoo!?
> YAHOO! GROUPS LINKS
> Visit your group "WanderlodgeForum" on the web.
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
12-20-2005, 02:43
John I went back and took a look at the pics. Were you asking about the
material covering the passenger front seat? If you were then I'm sorry I can't
be sure if the copilot seat is covered in leather or something like it. It felt
like leather to me but I never took a close look at it. They are both Flexsteel
I believe.
Rob, Sue & Merlin
94 WLWB
> John Suter
> > Rob, Sue & Merlin
> > 94 WLWB
> Do You Yahoo!?
> YAHOO! GROUPS LINKS
12-20-2005, 04:25
Rob,
Below is a good URL link to the photos on Randy's photo web site, in
the future when adding links to a message, be sure to separate them
from the message itself, with nothing in between, I usually put them
on a separate line by itself with a extra space in between, such as;
"REMEMBER SEPTEMBER 11, 2001"
John Finn
'82 35FCRB
BLUEBIRD WANDERLODGE
TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE
GO TO;
http://www.pbase.com/image/24977457
'66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE"
SEE THE OLD COACH AT:
http://www.pbase.com/image/26052733
HOPKINS, SOUTH CAROLINA
--- In WanderlodgeForum@yahoogroups.com, Rob Robinson
project. This
cupboard and a
laminate work
best to put
us. The stuff
persuasion.
new to both
shapes pretty
shaping Randy was
polishing
buffed the hell
speak for
If I did it
that was
story LOL.
> Rob, Sue & Merlin
> 94 WLWB
12-20-2005, 08:21
Thanks Rob, but no, not the cushions. It's very
hard to tell from the photo which may be "old timey"
formica, which is corian (although I assume the
tabletop surface), and which is laminate.
My question was about the grey/white, left
foreground product, which forms the outer shell
surface of the "chair back" and has a very uniform
roll - could be described as the outside of what
"hugs" one's shoulders. What is its exact product
name, and did you fellows make that "roll;" if so,
how?
A separate question is about the surface that is
shown just above the drawer face and may be the same
product. There appears to be a 2-3" vertical seam
across its face leading me to wonder if that joint is
really the seam between two dissimilar products or one
purchased as rolled, and the other flat like formica
stock?? Might you have some more pictures from
different angles?
> The
Can you better describe/point out which surface is
and which is not laminate?
Thanks,
John
> (left
> was
> 30-40
> > John Suter
> a
> he
> that
> a
> story.
> was
> with
> and we
> > > Rob, Sue & Merlin
> > > 94 WLWB
> > Do You Yahoo!?
> protection around
> > YAHOO! GROUPS LINKS
> to:
Do You Yahoo!?
12-20-2005, 09:27
Hi John. The Corian is black and everything you see as off-white is Formic
laminate. We put the Formica on flat and curved surfaces. Many of the dinette
corners were rounded (approx 2" radius). Randy had a source for the rounded
corners. Essentially it was a pre-made moulding that accepted 3/4" plywood at
ninety degrees. It wasn't a perfect fit as we all know that 3/4" plywood isn't
3/4". This is where Randy's Mark V eyeball and DA sander came into play. As for
the vertical seam this is a boo boo that will be fixed later by Luke Scanlon.
Before we learned to bend the Formica properly we cracked it and had to join it
in this area. Luke has the means of hiding these screwups.
Rob, Sue & Merlin
94 WLWB
> how?
> different angles?
> > The
>   Thanks,
> John
> > (left
> > was
> > 30-40
> > > John Suter
> > a
> > he
> > that
> > a
> > story.
> > was
> > with
> > and we
> > > > Rob, Sue & Merlin
> > > > 94 WLWB
> > > Do You Yahoo!?
> > protection around
> > >   YAHOO! GROUPS LINKS
> > to:
> Do You Yahoo!?
> YAHOO! GROUPS LINKS
12-20-2005, 10:42
Well done. I assume you used post forming grade of formica. What
adhesive did you use?
project. This
cupboard and a
laminate work
best to put
us. The stuff
persuasion.
new to both
shapes pretty
shaping Randy was
polishing
buffed the hell
speak for
lot. If I did it
table that was
story LOL.
> Rob, Sue & Merlin
> 94 WLWB
12-20-2005, 13:06
Used contact cement. Not sure what 'post forming' means. Like I said earlier,
my experience with laminates is limited.
Rob, Sue & Merlin
94 WLWB
Quoting ronmarabito2002 :
> project. This
> cupboard and a
> laminate work
> best to put
> us. The stuff
> persuasion.
> new to both
> shapes pretty
> shaping Randy was
> polishing
> buffed the hell
> speak for
> lot. If I did it
> table that was
> story LOL.
> > Rob, Sue & Merlin
> > 94 WLWB
> YAHOO! GROUPS LINKS
