M450 of 30 amp hookup
01-31-2015, 23:18
Have any M450 owners successfully hooked up to 30 amp without popping breakers? if you have, what did you sacrifice?
Tommy "2 Shoes" McCarthy 2006 M450XLI "GoneAway" ![]() Former owner 1995 PT42 WB "Pretty Penny" Gardnerville, NV Near South Lake Tahoe |
02-01-2015, 01:46
(This post was last modified: 02-01-2015 01:47 by dentmac.)
RE: M450 of 30 amp hookup
Hi,
When using 30 amp, the top EMS should show 30 amp. Everything is automatic then. Shunts as required. If batteries are low and both inverters want to go to full bulk charge.. nothing left. I have shut down one inverter until charge goes to float. Ross MacKillop Wiarton Ontario 2006 450 Lxi |
02-01-2015, 04:40
not sure if your inverters works like my one inverter but. I never shut off the inverter in my bus.. however I throw the circuit breaker off that feeds the charger side of the inverter when I am on 30 amps and I then use one Xantrex +40 charger to maintain the batteries.
