					Kubota/Powertech Genny
					08-20-2014, 08:16
				 Post: #1 | |||
					All: Last week was service time for oil changes, filters, etc on my 'bird and Kubota/Powertech genny. Found my oil pressure sender was leaking and I had a new one installed. The sender was difficult to remove/replace without first removing the starter. Starter was pulled and I was shocked to see that the "business end" of the starter was caked with thick, oil-soaked dust. The opening where the starter is connected to the engine block was likewise caked with thick, oil soaked dust. I am amazed this condition had not caused my starter to stall. Those with Kubota/Powertech gennies might consider removing the starter and checking for a similar condition, if yours is configured like mine. I was advised the engine in the front - generator in the back configuration "encouraged" dirt, grime, dust and oil to enter the starter assembly. Further told the more recent configuration - generator in the front - engine in the back minimized such a condition. Tommy Rountree, AKA RetDA Still a Newbie 1994 WB | |||
					08-20-2014, 09:42
				 Post: #2 | |||
| RE: Kubota/Powertech Genny (08-20-2014 08:16)RetDA Wrote: All: Tommy, Got a source and part number? Is it the older style large bullet shaped one about 3" long and 2" around with the wire attaching to a stud on the end? Thanks. Mike Bulriss 2001 LXi43 DS San Antonio, TX | |||
					08-20-2014, 09:45
(This post was last modified: 08-20-2014 10:11 by RetDA.)
				 Post: #3 | |||
| RE: Kubota/Powertech Genny (08-20-2014 09:42)mikebulriss Wrote:(08-20-2014 08:16)RetDA Wrote: All: Mike, I'll have to go out to my bird and check the invoice. I'll get back later. Tommy (08-20-2014 09:45)RetDA Wrote:(08-20-2014 09:42)mikebulriss Wrote:(08-20-2014 08:16)RetDA Wrote: All: Michael: The sender/shutdown switch is a Powertech part - #PTS-05SO2P-2 Pole Oil Pressure Shutdown Switch. Hope this answers your question. Tommy Tommy Rountree, AKA RetDA Still a Newbie 1994 WB | |||
					08-20-2014, 10:40
				 Post: #4 | |||
					Thanks Tommy.  That should help.   I pulled mine off and walked into the Kubota dealer a couple of mles away.  I knew I was wasting my time when the parts guy's first words were: "What's that?"  I told him and he said "I've never seen one of those before.  If you have a part number or tractor model maybe I can look it up."  I  thanked him and left.  I put it back on until I can get by a REAL parts house - not a "What vehicle?" AutoZone, NAPA, etc.   I remember the old days when the counter guy would have just looked and said "that 4 ohm or 8 ohm" and pulled the part. That's why I needed a part number. Mike Bulriss 2001 LXi43 DS San Antonio, TX | |||
					08-20-2014, 12:19
(This post was last modified: 08-20-2014 12:32 by RetDA.)
				 Post: #5 | |||
| RE: Kubota/Powertech Genny (08-20-2014 10:40)mikebulriss Wrote: Thanks Tommy. That should help. I pulled mine off and walked into the Kubota dealer a couple of mles away. I knew I was wasting my time when the parts guy's first words were: "What's that?" I told him and he said "I've never seen one of those before. If you have a part number or tractor model maybe I can look it up." I thanked him and left. I put it back on until I can get by a REAL parts house - not a "What vehicle?" AutoZone, NAPA, etc. I remember the old days when the counter guy would have just looked and said "that 4 ohm or 8 ohm" and pulled the part. (08-20-2014 10:40)mikebulriss Wrote: I remember the old days when the counter guy would have just looked and said "that 4 ohm or 8 ohm" and pulled the part. Michael: We have a big Kubota Dealer here in Oneonta. I've asked about getting parts and service on my Kubota engine (generator). The response has be "Uh....its in a motorhome? I wonder....how rare is a 4 cylinder Kubota Diesel like we have in our 'birds? PowerTech says they have a full line of Kubota parts. I called in the morning for the pressure sender, they looked the part number and I had it the next morning. Tommy Tommy Rountree, AKA RetDA Still a Newbie 1994 WB | |||
					08-20-2014, 17:49
				 Post: #6 | |||
					Tommy, The V2203 kubota we have is used in tons of stuff. It's all over the place. They're almost like seed ticks in the spring!  Mike, The kubota oil sender number may be a 554018. That's what comes up for a V2203, unless there's a power tech specific variant. John Mace 06 450LXi bigger bird living in the wild hinterlands of the north free to roam without the man getting me down | |||
					08-20-2014, 18:55
				 Post: #7 | |||
					could be there is a sender for psi reading at the Kubota gauge  and a switch for the powertec Murphy type shutdown system.  switch is a switch but a sender must match the reader (gauge device). Switch is a switch is a bit simplistic because there is a set psi point when it either opens or closes depending on the engineered signal.
				 Gregory O'Connor 2001 LXi43ss Romoland California 92585 951-830-5997 Rainbowrv.com | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
