HWH Active Air
10-30-2013, 17:45
(This post was last modified: 10-30-2013 20:36 by davidbrady.)
HWH Active Air
Six and a half years ago I posted this to the yahoo:groups:wanderlodgeForum; I wonder if there have been any recent developments in HWH's Active Air program:
I spoke with an HWH engineer today regarding their Active Air suspension. For the uninitiated, Active Air provides dynamic suspension height adjustment. Enter a turn or change a lane and the outboard airbags are inflated and the inboard bags deflated to maintain a level chassis attitude. HWH uses their own technology: high flow air valves, electronic height control sensors, and computer mother boards. They link it all together with a CAN, J1939, bus known as RV-CAN, and have been active in the standards committees to formalize the RV protocol. The system consists of three height control sensors, pressure sensors for each air bag, high flow air manifolds with solenoids, a transmission speed sensor, an accelerometer, and a steering wheel angle sensor, along with associated wiring and plumbing. Integrated within the Active Air is an Air Leveling System. Control is also provided to the operator to allow raising the coach at each end to clear obstacles and to allow lowering the coach to clear obstacles. While en route the operator can raise or lower sides or ends of the coach to low, medium, or high to suit his needs; i.e, crowned roads, side wind, or front wind, etc. Air bag inflation takes time. While on a cloverleaf HWH instrumentation can show an increase in outboard air bag pressure of 20 to 30 psi and a reduction of inboard air pressure of 30 to 40 psi. The high flow valves use orifices of .25 inch and hoses can range from 1/2 inch to 5/8 inch. The required pressure changes may require 0.5s or more to attain. To help eliminate delays, HWH uses the accelerometer, vehicle speed, and steering wheel angle to "anticipate" changes in direction and to get a head start on inducing bag pressure changes. When pressed, I was unable to pin HWH down on actual air bag response rates, but the engineer did cite and improvement in ride and handling of from 30 to 50%. The test mule at HWH is an 1988 BB PT40 and is available for test drives. The system comes with monitoring and diagnostics tools and air bag pressure displays. There are 2 modes of operation plus disabled. Below 15 mph the air in an axle's air bags are pressure equalized and the system is disabled, above 15 mph the system can be in "economy" mode or "active" mode. In economy mode the bus is leveled and the system is basically put in standby, this eliminates load on the air compressor and is said to improve fuel mileage. In "active" mode, the system is sensing air bag pressure, accelerometer, steering, and speed inputs, and is poised to dynamically pulse air into airbags as needed. The overall goal in "active" mode is to keep the coach level. This is done by anticipating roll and acting quickly to circumvent it. A perfectly level coach under all circumstances is the goal of the "active" mode. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
10-30-2013, 18:14
RE: HWH Active Air
David,
My previous 2000 LXi was equipped with probably HWH’s precursor to the active air system. The bus could be leveled with the hyd jacks or by the air springs. Although it was not able to actively keep the bus level while moving; it would allow the driver to raise or lower the front or rear air springs to clear objects while moving. I don't remember if side to side lowering or raising was possible. I believe it only worked at speeds below 15 mph. I used it many times to lower the front and raise the rear of the bus to keep the rear of the bus from dragging on the pavement during the transition from the street to the inclined driveway. Obviously, the bag inflation on the rear was limited to the height above the ride height but the front would drop a good three inches. I presume the rear bags would also deflate to the bump stops also although I never tried that as I always parked the bus forward in the garage. I’d guess that HWH engineers are using that system as a base for the new “Active Air” system Chuck Chuck & Tela Millsap 2003 Prevost Marathon XLII 2000 LXi #2 S/S (Sold) 2004 M380 D/S (Sold) 2000 LXi #1 N/S (Sold |
10-30-2013, 19:59
RE: HWH Active Air
If I remember correctly, Ernie's new coach has that system. Paul talked about that system several times as he was a"spirited" driver, and wanted the coach to behave like a sports car.
10-31-2013, 00:34
RE: HWH Active Air
Isn't this more or less what Monaco's do?
Mike and Tracy - near Edmonton, Alberta, Canada 1999 43 LXI, "Maddy" - 60 Series Detroit 2006 Jeep Liberty CRD (Diesel) or Jeep Rubicon 4 Down Toad http://www.challengerwest.com
10-31-2013, 19:06
RE: HWH Active Air
When I called several years ago, they asked about my coach, when I said it was a Blue Bird, they said they will not install a system on a Blue Bird, period. I clarified that my model was an LXi and didn't have an law suit peril, but they were very firm on not selling and installing on any model Blue Bird.
Maybe things have changed by now. Morey Zuber 99LXi41 |
11-07-2013, 18:41
RE: HWH Active Air
Just got off the phone with Jeff at HWH. He took my phone call right away and we spent quite a bit of time talking. They will install Active Air on Wanderlodges. They do weigh the coach first and if it isn't within it's GAWR-ings then they'll re-evaluate an install. The cost is $9400 and it takes a week. They have openings for installation this Fall.
11-07-2013, 19:42
RE: HWH Active Air
I guess I do have active air. I'm not a spirited driver, though.
11-07-2013, 19:46
(This post was last modified: 11-07-2013 19:47 by davidbrady.)
RE: HWH Active Air
Ernie,
What kind of suspension air bag pressures do you see on your Active Air LCD display? david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
11-08-2013, 09:19
RE: HWH Active Air
I don't recall a display. I wonder if I have that? I wonder if Paul forgot to give me that?
11-08-2013, 10:33
RE: HWH Active Air
HWH sets pressure at the install. It can be changed.
I think my drives are at 90 psi and tag and steer at 70 psi. Charlie Vaughn 1999 LXi |
