1988 PT 40 height
10-15-2013, 16:47
1988 PT 40 height
Hello,
Does anyone know the actual height/clearance of a 1988 pt40 WB? We are trying to see if it will fit in storage that has a door opening of 11.5ft. Thanks Teri Rahn Kalispell MT |
10-15-2013, 17:15
RE: 1988 PT 40 height
Teri,
They're all different enough, the measurements from one won't truly tell you what yours is. You'll have to measure it to be sure. Though most of the WB's are 12' plus, so you'll probably NOT fit through an 11'5" door. At least not until the SECOND time!
1 user Likes Arcticdude's post |
10-15-2013, 19:40
Mine is 12'6", as measured at the RATS one year. That is with the suspension aired up. Even aired down, It will not it will fit.
10-16-2013, 11:22
Teri,
I am 12'4" bags up........FWIW I cannot recall anyone with a pusher who could do 11.5............that said, the ole memory ain't what it used to be so the best thing is get on the roof or ladder by the side and measure your bird as each one of these things is "custom".............
10-16-2013, 15:12
I have a older PT and it still measures 12'4'' to the highest point.
John Pletcher 82 PT40 Lancaster, PA john@pletcherfire.com |
10-16-2013, 23:21
I have a satellite dome. I guess that's where the 2" comes in, or maybe "Jus Chillin" is prouder cause she's purple and stands up taller
10-17-2013, 15:13
Thanks. Looks like it will not fit. Thanks for all your replies.
