					LXi and WideBody PTO/Pump Splines
					05-28-2013, 13:21
(This post was last modified: 05-28-2013 13:44 by pgchin.)
				RE: LXi and WideBody PTO/Pump Splines
				(05-28-2013 12:41)davidmbrady Wrote: Wow Pete! BTDT! David, First , if you did that job twice on an LXI by yourself and removed and installed the pump and PTO as one assembly.... you ARE Hercules!!!!!!!    I have chicken wings for arms and a Bird chest!!!!!!  Now you know why I own a bird!!!!!!![]() As for the fan and controller, I had a new fan motor installed in 2007, seeping seal....... on the 95, 96, and not sure about 97, we have the DDEC III, you have IV. Anyway with DDEC III you only have 2 speeds on the fan......low and high and you can hear the difference, we are not variable like you.....that's another reason, as you stated in previous posts, LXI's DDECIV's get better mileage than us and your fan speed is variable, but yes I keep an eye on the controller and did make sure the fan worked in both modes! Thanks for the tips and reminding me to mention this as that is why I road tested it to get it up to temp for the low/ high fan check and to work out any remaining air bubbles in the system. Also for those of you with DDECC IV / LXI, please look at David's suggestion about fan speed. Since you have variable, check the motor and controller. You DO NOT want to do this job only to loose the engine to a bad fan motor or controller!!!!! Very IMPORTANT. thanks David for mentioning it for our LXI owners! Tips/ clues here is loss of mileage and an s60 that runs warm....... IF that occurs, then the photo tachomoeter deal would be a good thing to do as David mentioned! Many things can affect mileage but tuned up s60's usually hold strong so just be aware of the signs as David mentioned! Yes, and nothing like doing that job and the old bird comes online smoothly!!!!!! What a FABULOUS feeling, you are 100% correct! Hummm since I saved the labor cost on this job, I guess I am entitled to by a new toy or some bling!
				Pete and Donna Chin 95 42' WLWB On The Road Always! :-) " We'll raise up our glasses against evil forces singing, Whiskey for my men, and beer for my horses!"-Toby Keith & Willie Nelson - The bridge from Toby Keith's title album track "beer for my horses"  |
					05-28-2013, 14:31
				(05-28-2013 13:21)pgchin Wrote: First , if you did that job twice on an LXI by yourself and removed and installed the pump and PTO as one assembly.... you ARE Hercules!!!!!!! It was pure adrenaline Pete!
				david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right"  |
					05-29-2013, 18:11
					is there a way to inspect as to whether you have a wet system on the PTO . I would love to think this conversion has been done . If it is not done , any recommendations .
al perna 2000 LXI ormond beach fla  |
					05-29-2013, 19:03
(This post was last modified: 05-29-2013 19:06 by davidbrady.)
					Al,
There's at a minimum one pressure line coming from the transmission and terminating at the Chelsea PTO. This line supplies transmission lubricant to the PTO gears. If you have a wet spline kit then you'll have a second line that Tees off the transmission line at the PTO and terminates at the PTO/Pump cavity - hose 329057 in the attached pic. This line supplies pressurized fluid to the splines. So, a wet spline has an extra pressure line and a Tee. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right"  |
					05-29-2013, 22:14
					David
I will cross my fingers and check it in the morning , thanks for the drawing . al perna 2000 LXI ormond beach fla  |
					05-30-2013, 09:47
					Al,
If you have the wet spline kit, you will see the "tee" David talks about at the bottom of the transmission, back of the coach, curb side. You can see it without crawling under right by where the tranny filters are. If you see a "tee" and 2 lines, you got it, 1 line, you have grease. Pete and Donna Chin 95 42' WLWB On The Road Always! :-) " We'll raise up our glasses against evil forces singing, Whiskey for my men, and beer for my horses!"-Toby Keith & Willie Nelson - The bridge from Toby Keith's title album track "beer for my horses"  |
					06-06-2013, 17:40
					While my bus is in the repair shop, they checked the condition of my PTO and said it was abnormally noisy. I have asked them to try to determine if it is the pump or the looseness in the PTO spline. Anyway, I decided it is a good time to upgrade the PTO, so I added that to the list. I am having it upgraded to the wet spline I" shaft & pump.
On another subject regarding the slide top trim rail. The repair shop has a good body repair shop on site so they are repairing the trim piece. They called HWH for a replacement part and was told the HWH does not carry the part anymore. and they have been unable to duplicate elsewhere. So, they are going to reuse to broken trim piece and ure Sikaflex 221 and flat headed rivits to secure it in place. Chuck & Tela Millsap 2003 Prevost Marathon XLII 2000 LXi #2 S/S (Sold) 2004 M380 D/S (Sold) 2000 LXi #1 N/S (Sold  |
					06-07-2013, 00:08
					Thanks for the update Chuck. I think you're doing the right thing with the Pump/PTO. When upgrading to the 1" shaft it's my opinion that it's plenty strong enough to wet spline - no fears of excessive wear and metal shavings landing in the transmission. I'd do the same.
					06-26-2013, 20:28
(This post was last modified: 06-26-2013 20:42 by cmillsap.)
				(05-28-2013 12:41)davidmbrady Wrote: Wow Pete! BTDT! They had the same problem with my u-line but they did get it loosened. The couplings may have "locking taper threads" on one side which are very difficult to loosen once tightened and not disturbed for a few years. I'm posting a few pics below to show folks that the 7/8" PTO can be rebuilt as a 1" greasable or wet splined PTO. I am sure that the cost is much less than a new PTO, but at this time I do not have all the invoices to say exactly what the cost is. It includes the -129 Kit, 3 new larger bearings, end cap to receive the 1" pump & an end cap to replace the cap with the grease fitting. More to come Chuck & Tela Millsap 2003 Prevost Marathon XLII 2000 LXi #2 S/S (Sold) 2004 M380 D/S (Sold) 2000 LXi #1 N/S (Sold  |
					06-28-2013, 21:49
					Sometimes it just easier to replace the rigid U-Line pipe with all new hose.
