Bluebird storage
09-21-2011, 03:31
Bluebird storage
Mike would like to know how to "kill the DC" so that it doesn't drain down the batteries during storage for a while this winter. Â (We hope to still get to AZ sometime this winter.) Â Our Bird has just been sitting for a month or so and the batteries are dead; we go and run the generator and recharge a bit and the next time they are dead again. Â Therefore, we can't get the Bird to start when we want to move her. Â Any suggestions or tips on how to avoid this issue would be greatly appreciated. Â Thanks.
Mike and Jana Ewart 89 PT40WB Royal Conversion presently in Rapid City SD
Blessed are the people whose God is the Lord. (Psalm 144:15) |
09-21-2011, 03:43
Bluebird storage
The only way I was successful in stopping battery drain was installing complete battery disconnects for both the engine and house batteries. These are 'switches' that physically disconnect the batteries from the coach.
Roger Webb
91 WL
Cedar Rapids, IA
Moorseville, NC
-----Original Message----- From: Jana Ewart To: WanderlodgeForum Sent: Wed, Sep 21, 2011 6:31 am Subject: [WanderlodgeForum] Bluebird storage Mike would like to know how to "kill the DC" so that it doesn't drain down the batteries during storage for a while this winter. (We hope to still get to AZ sometime this winter.) Our Bird has just been sitting for a month or so and the batteries are dead; we go and run the generator and recharge a bit and the next time they are dead again. Therefore, we can't get the Bird to start when we want to move her. Any suggestions or tips on how to avoid this issue would be greatly appreciated. Thanks.
Mike and Jana Ewart
09-21-2011, 03:49
Bluebird storage
Batteries will drain after a few days if you aren't either plugged in so the charger can do its job, or you have them disconnected.
Thanks, Markus ----- Reply message ----- From: "Jana Ewart" Date: Wed, Sep 21, 2011 11:31 am Subject: [WanderlodgeForum] Bluebird storage To: Mike would like to know how to "kill the DC" so that it doesn't drain down the batteries during storage for a while this winter. (We hope to still get to AZ sometime this winter.) Our Bird has just been sitting for a month or so and the batteries are dead; we go and run the generator and recharge a bit and the next time they are dead again. Therefore, we can't get the Bird to start when we want to move her. Any suggestions or tips on how to avoid this issue would be greatly appreciated. Thanks. Mike and Jana Ewart 89 PT40WB Royal Conversion presently in Rapid City SD -- Blessed are the people whose God is the Lord. (Psalm 144:15) |
09-21-2011, 05:11
Bluebird storage
09-21-2011, 05:13
Bluebird storage
09-21-2011, 09:34
Bluebird storage
We just had battery disconnects put on the batteries so it is just a
matter of flipping a couple of switches to fire everything back up. Chuck Somers, 81fcsb, Florida. > Disconnected batteries will still discharge over a long storage time if > you don't assist them with a battery charger. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > > --- On Wed, 9/21/11, markusfmeyer@... > wrote: > > From: markusfmeyer@... > Subject: Re: [WanderlodgeForum] Bluebird storage > To: "Jana Ewart" > Date: Wednesday, September 21, 2011, 10:49 AM > > > > > > > > > > > > > > > > > Ã > > > > > > > > > > Batteries will drain after a few days if you aren't either plugged > in so the charger can do its job, or you have them disconnected. > > Thanks, > Markus > > ----- Reply message ----- > From: "Jana Ewart" > Date: Wed, Sep 21, 2011 11:31 am > Subject: [WanderlodgeForum] Bluebird storage > To: > > Mike would like to know how to "kill the DC" so that it doesn't drain down > the batteries during storage for a while this winter. Ã (We hope to still > get > to AZ sometime this winter.) Ã Our Bird has just been sitting for a month > or > so and the batteries are dead; we go and run the generator and recharge a > bit and the next time they are dead again. Ã Therefore, we can't get the > Bird > to start when we want to move her. Ã Any suggestions or tips on how to > avoid > this issue would be greatly appreciated. Ã Thanks. > > Mike and Jana Ewart > 89 PT40WB Royal Conversion > presently in Rapid City SD > > -- > Blessed are the people whose God is the Lord. (Psalm 144:15) > > > > > > > > > > > > > > > > > > > > > > > > > > |
09-21-2011, 14:04
Bluebird storage
Hi Jana. You have already gotten good responses, the advise about switches and chargers is on target. Here are some additional things to consider... [I presume you have lead-acid type with clean cables]. A lead-acid battery does self-discharge and limits shelf life to about 6 months. After 6 months it wont be dead, but will be pretty unusable until after charging. Only use between 30 and 50% or 50AH max before recharging for every 100 amp-hrs capacity. A battery only has so many discharge cycles in it and deep discharge shortens life. A dead battery is pretty bad news, you don't get very many full discharges before failure. Notice there is no number to hang on cycles, but a well maintained battery should live many years. failure? pretty often one cell refuses to take & retain charge. A simple test is to look for one warm battery amongst a bank of cool ones after charging. Sometimes charging doesn't fully complete in one battery and prevents the others from "filling up". For lead-acid batteries, there is a de-sulfating procedure that you might look up some time. Fully charged good batteries store OK in very cold weather, but dead batteries ice up and crack the case [very very bad]. Your example of "dead in a month" speaks to some load on the battery when you think all is OFF. Refer, hidden light left on, normally some circuit not controlled by the master switch near the entry consumes energy. A disconnect switch at the battery bank is good medicine for unexpected loads. If the battery itself is bad, usually it registers some voltage [not dead] while not under load, maybe 10 volts. But a bad battery will not deliver much current [especially won't start a diesel engine]. Starting batteries and deep discharge batteries are different -- sometimes not OK for both uses. Starting batteries are high current and may be quickly charged [think a couple hours]. Deep cycle batteries are low current and should be charged more slowly [think many hours]. Don't put both types in one battery bank. One battery rated for both duties is often a compromise. Probably the best insurance for long battery life is a "smart" charger over winter. One charger for each battery bank. You probably have a large charger already on board, it might be OK but not best for all winter use. A winter charger is better than trusting the 6 month shelf life, even in warm climates. And they are very low power & it's easy to find an extension cord. OOPS -- too much? Skip On 09/21/2011 11:31 AM, Jana Ewart wrote:
09-22-2011, 04:22
Bluebird storage
I don't know if you are aware that it takes a full 24hrs, at a trickle, to fully
charge a battery. If your battery has gone below 12v it will half life it's holding power. Sounds like your batt's are shot or close to it. In other words they won't hold a charge for any period of time. Harold Prescott 1985 35WLFC North California --- In WanderlodgeForum@yahoogroups.com, Jana Ewart > > Mike would like to know how to "kill the DC" so that it doesn't drain down > the batteries during storage for a while this winter. (We hope to still get > to AZ sometime this winter.) Our Bird has just been sitting for a month or > so and the batteries are dead; we go and run the generator and recharge a > bit and the next time they are dead again. Therefore, we can't get the Bird > to start when we want to move her. Any suggestions or tips on how to avoid > this issue would be greatly appreciated. Thanks. > > Mike and Jana Ewart > 89 PT40WB Royal Conversion > presently in Rapid City SD > > -- > Blessed are the people whose God is the Lord. (Psalm 144:15) > |
