1990 W-B40 CHARGING SYSTEM
02-15-2011, 11:56
HELLO ALL
QUICK QUESTION DOSE ANYONE KNOW ANYTHING ABOUT THE BATTERY CHARGING FROM THE
INVERTER THERE IS TWO WIRES THAT GO FROM THE STARTER SOLENOID BOTH HAVE DIODES
IN THEM DOSE ANYONE KNOW WHAT THEY DO?? AND IF ANYONE HAS A PICTURE OF THIS
PLEASE EMAIL THEM TO ME JAMIEJBRANDT@...
I REMOVED ONE WIRE NOT KNOWING THE DIODE WAS THERE AND I REDID THE WIRE AND IM
NOT SURE WHICH WAY THE DIODE GOES
THE WIRES WERE DRY AND BRITAL
IT SEEMS LIKE IM NOT GETTING A CHARGE FROM THE BATTERY CHARGER
JAMIE BRANDT
1990 WB-40
FLORIDA
02-17-2011, 14:42
Jamie, need more info to help you... which bay do you need picts. of.. I had
charging problems for 2 years with my PD9155's(2). long story short the chargers
were bad. Replaced them with a 9280(1). No more charging prob..
Ed Gardels 89SP
Arlington Tx
--- In WanderlodgeForum@yahoogroups.com, "jamiejbrandt"
> HELLO ALL
> JAMIE BRANDT
> 1990 WB-40
> FLORIDA
02-18-2011, 05:13
Ed,
I have “overhauled” all three
of the furnaces in our 82 so if you need any help or information give me a
call. I can’t tell you how to get the furnace our of a SP but can say to
look real carefully. I started to tale the cabinet apart to remove one of ours
only to discover that all the parts around the furnace was held in place by magnets.
I all of ours the case stayed in place. There were two screws in front, then
I had to remove the gas line and the screw through the exhaust and the “works”
slid out.
Chuck Wheeler-
1982 FCSB Fort Worth
TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of wl89spman
Sent: Thursday, February 17, 2011
8:42 PM
Subject: [WanderlodgeForum] Re:
chargers were bad. Replaced them with a 9280(1). No more charging prob..
Ed Gardels 89SP
Arlington Tx
--- In "WanderlodgeForum%40yahoogroups.com",
"jamiejbrandt" wrote:
> HELLO ALL
THE INVERTER THERE IS TWO WIRES THAT GO FROM THE STARTER SOLENOID BOTH HAVE
DIODES IN THEM DOSE ANYONE KNOW WHAT THEY DO?? AND IF ANYONE HAS A PICTURE OF
THIS PLEASE EMAIL THEM TO ME JAMIEJBRANDT@...
AND IM NOT SURE WHICH WAY THE DIODE GOES
CHARGER
> JAMIE BRANDT
> 1990 WB-40
> FLORIDA
02-18-2011, 15:40
For what it is worth, I abandoned chargers. I put in two highly regulated switching supplies set to .3VDC lower than the max voltage of my batteries. I let the engine alternator do any max equalize and float up. The supplies cough up all the power the bus needs and can recover the batteries at an alarming 100 amps of initial inrush charge. I just no longer believe in all this hocus pocus charger special set up jazz. Sure as batteries change temperature the "float voltage" can change but the point of the .3 volt shortfall takes care of that. I wind up with batteries charged to 90% at all times on average and even if you look at the temperature curves of freezing cold to engine compartment hot, the numbers are right on the money.
gary
85pt40
--- On Fri, 2/18/11, Chuck Wheeler wrote:
Subject: RE: [WanderlodgeForum] Re: 1990 W-B40 CHARGING SYSTEM
Date: Friday, February 18, 2011, 12:13 PM
Ed,
I have “overhauled” all three of the furnaces in our 82 so if you need any help or information give me a call. I can’t tell you how to get the furnace our of a SP but can say to look real carefully. I started to tale the cabinet apart to remove one of ours only to discover that all the parts around the furnace was held in place by magnets. I all of ours the case stayed in place. There were two screws in front, then I had to remove the gas line and the screw through the exhaust and the “works” slid out.
- Chuck Wheeler-
- 1982 FCSB Fort Worth TX -
From: WanderlodgeForum@yahoogroups.com [mailto: WanderlodgeForum@yahoogroups.com ] On Behalf Of wl89spman
Sent: Thursday, February 17, 2011 8:42 PM
Subject: [WanderlodgeForum] Re: 1990 W-B40 CHARGING SYSTEM
Jamie, need more info to help you... which bay do you need picts. of.. I had charging problems for 2 years with my PD9155's(2). long story short the chargers were bad. Replaced them with a 9280(1). No more charging prob..
Ed Gardels 89SP
Arlington Tx
--- In WanderlodgeForum@yahoogroups.com, "jamiejbrandt" wrote:
> HELLO ALL
> QUICK QUESTION DOSE ANYONE KNOW ANYTHING ABOUT THE BATTERY CHARGING FROM THE INVERTER THERE IS TWO WIRES THAT GO FROM THE STARTER SOLENOID BOTH HAVE DIODES IN THEM DOSE ANYONE KNOW WHAT THEY DO?? AND IF ANYONE HAS A PICTURE OF THIS PLEASE EMAIL THEM TO ME JAMIEJBRANDT@...
THERE AND I REDID THE WIRE AND IM NOT SURE WHICH WAY THE DIODE GOES
> JAMIE BRANDT
> 1990 WB-40
> FLORIDA
02-20-2011, 01:53
CHARGING SYSTEM FOR MOTOR IS WHERE I SEE THE PROBLEM IT WORK FINE WHEN RUNNING
JAMIE BRANDT
1990 WB40
> Ed Gardels 89SP
> Arlington Tx
> > HELLO ALL
> > JAMIE BRANDT
> > 1990 WB-40
> > FLORIDA
