sporlan valve
02-17-2007, 10:16
Post: #21
sporlan valve
Hi Guys:
Actually the switch in turn operates a two pole relay. The summer valve is
powered whenever the switch is in the "off" position, and the winter valve is
powered whenever the switch is in the "on" position.
Bill
84FC35SB
Terry Neal wrote:
Hi Curt,
Are you saying the housing of the valve stays warm? If so, I'd check
the power going to the valve solenoid with a tester. Sounds like maybe
your dash switch isn't working correctly to open the circuit when you
switch it to off.
One switch controls the "Summer/Winter" valve for all of the "chassis"
heaters in the coach & the other switch controls the front passenger
heater line valve. At least that's the way my 82 is set up.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
Curt Sprenger wrote:
> There are two Sporlan valves at the back of the coach. I assume they
> control the chassis heat water flow. One stays very warm with all
> switches set to off. Any ideas? Thanks.
> Curt Sprenger
> 1987 PT38 8V92 "MacAttack Racing"
> Anaheim Hills, Calif.
Terrace, B.C. Canada
Share your photos with the people who matter at Yahoo! Canada Photos
02-17-2007, 10:29
Post: #22
sporlan valve
Thanks Bill for your clarification. You're right. I was trying to go
from my memory (dangerous at any time) on my PT. I remember now that
one of them is always energized depending upon which position the switch
is in.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
Wilhelmus Schreurs wrote:
> Hi Guys:
> valve is powered whenever the switch is in the "off" position, and the
> winter valve is powered whenever the switch is in the "on" position.
> Bill
> 84FC35SB
> Terry Neal > > wrote:
> Hi Curt,
> switch it to off.
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> > Curt Sprenger
02-18-2007, 04:45
Post: #23
sporlan valve
Our 'Bird has one switch. It's either set to winter or to summer. There
is no off position.
Curt Sprenger
Terry Neal wrote:
> Hi Curt,
> switch it to off.
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> > Curt Sprenger
02-18-2007, 05:40
Post: #24
sporlan valve
True you are Curt.
When it is in the summer position, it is actually in the off position.
----- Original Message ----
Sent: Sunday, February 18, 2007 8:45:42 AM
Subject: Re: [WanderlodgeForum] Sporlan Valve
is no off position.
Curt Sprenger
Terry Neal wrote:
> Hi Curt,
> switch it to off.
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> > Curt Sprenger
Do You Yahoo!?
http://mail.yahoo.com
02-18-2007, 05:56
Post: #25
sporlan valve
Curt,
Mine works exactly the same as yours. Makes me wonder why have the valve if it
is always "normally" open?
Sent: Sunday, February 18, 2007 8:45 AM
is no off position.
Curt Sprenger
Terry Neal wrote:
> Hi Curt,
> switch it to off.
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> > Curt Sprenger
02-18-2007, 06:35
Post: #26
sporlan valve
Bill, Dick,
Dick, I agree, why have the valve. Could be there are wires in our dash
for that valve and they have not been attached to a switch? If that is
true, a three way switch Winter/Off/Summer in place of the Winter/Summer
switch would give us full control.
Bill, I look forward to viewing your drawings.
Curt Sprenger
Richard Hayden wrote:
> Curt,
> valve if it is always "normally" open?
> From: Curt Sprenger > >
com
> is no off position.
> Curt Sprenger
> Terry Neal wrote:
> > Hi Curt,
> > switch it to off.
> > Terry Neal
> > Bozeman, MT
> > 82PT40 6V92TA
> > 74FC34 6V53T
> > > Curt Sprenger
07-05-2010, 03:49
Post: #27
sporlan valve
My coach has a hot cockpit unless I turn off the hot water supply at
the engine. I ordered sporlan valve rebuild kits but they are not
for the valve I have. There is a medium sized solenoid valve in
the front center of the coach which appears to be the culprit.
As I said, the valve rebuild kits I ordered were for valve bodies
about 1/2 the diameter of mine.
Any help would be appreciated.
William C. (Chuck) Harrison
Akron, Ohio
90 sp36
07-05-2010, 07:38
Post: #28
sporlan valve
I had the same problem with my 96 PT42, the front heat control has a temp. control knob like a car that allows you toajust the air from the ventsto range from cool tohot. This heat control knob has a cable attached that goes down to a valve in theheater hosefor the front heat exchangers, and whenthe dash knob is turned all to cool it closes a flapper in the valve on the heater hose. The problem is that that the valve, even when totally shut, stillallows some of the heated coolant (antifreeze) to flow past and that keeps the front heat exchangers warm so the driver and co-pilot get warm air coming from the front vents.
I clamped off a section of the heater hose that the valve is in with 2 vise grips and I cut the hose between thevise gripsand put in a manualy operated 3/4" brass ball valve.Iput ribbed brass fittings in each end of the ball valve that adapted to my heater hosesize and tightened with hose clamps. With the heater hose clamped off with 2 vise grips andcuting my hose between them, I only lost a small amount of antifreezeand that was absored into the rag I had put down under my hose.
Now if it's warm out, I shut the ball valve offwhich completly stops the flow of warm antifreeze to the front heat exchangerseliminating the problem of warm air coming from the front heat ducts, this also greatly improves the performance of the front air conditioning, when it gets cool out again I open the ball vale and the system works as it did before. On my coach there is a hinged access panel on the botom of the dash in front of the co-pilots seat that gives easy access to thefront heater hose, you would have to find a easy access place to locate the valve into the heater hose on your coach. Theball valve could be located in the supply or return heater hose to the front heat and it would work the same.
Wayne
96PT42
Sent: Mon, July 5, 2010 10:49:09 AM
Subject: [WanderlodgeForum] Sporlan valve
Akron, Ohio
90 sp36
07-07-2010, 10:13
Post: #29
sporlan valve
> control knob like a car that allows you to ajust the air from the vents to
range
> from cool to hot. This heat control knob has a cable attached that goes down
to
> a valve in the heater hose for the front heat exchangers, and when the dash
knob
> problem is that that the valve, even when totally shut, still allows some of
> vents.
> grips and I cut the hose between the vise grips and put in a manualy
operated
> 3/4" brass ball valve. I put ribbed brass fittings in each end of the ball
valve
> that adapted to my heater hose size and tightened with hose clamps. With the
> heater hose clamped off with 2 vise grips and cuting my hose between them, I
> only lost a small amount of antifreeze and that was absored into the rag I
had
> Now if it's warm out, I shut the ball valve off which completly stops the
flow
> of warm antifreeze to the front heat exchangers eliminating the problem of
warm
performance
vale
> access to the front heater hose, you would have to find a easy access place
to
> locate the valve into the heater hose on your coach. The ball valve could be
work
> the same.
> Wayne
> 96PT42Â Â Â
> From: williamcharrison
> Â
> Akron, Ohio
> 90 sp36
10-02-2010, 03:54
Post: #30
sporlan valve
Does a Sporlan Valve either work or not? Can one get weak? Mine will not
transfer from tank fill to city water without me turning off the water. I guess
the water pressure is stronger than the valves closing mechanism?
