Radio static
02-04-2010, 12:16
Radio static
My radio in the front had static in it from the florescent lights. I installed a
new one because I wanted a HD radio & it still has static in it. The old radio in the bedroom which is original equipment. Is there a suppressor for static some where up front that went bad? Don Spithaler 89 SP 36' Butler, PA New Port Richey, FL for the winter |
02-04-2010, 12:21
Radio static
02-04-2010, 14:44
Radio static
The box you describe is the 12 volt "filter" for the power. It contains 3 large capacitors (be careful, short one and it'll knock you on your rear -- big time). While capacitors can "go bad" -- it isn't likely.
Part of the 12 volt system is "filtered" (passing though the filter) and part is not. It is vital to make sure that the radio is wired into the filtered electrical system. Also, make sure that there isn't something wired in that crosses between the filtered and non filtered power source. (This is a matter of tracing out wires to ensure they're where they're supposed to be.) However, fluorescent lights (particularly ballasts) can generate RF signals that directly interfere with the radio signal. This is more frequent as the ballasts degrade over time. So you may need to "do" something about the fluorescent lights directly rather than a filtering problem. A radio shop may have a filter for the antenna wire -- or shielding -- that might solve the problem.
Pete Masterson (former) '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 4, 2010, at 4:21 PM, Ernie Ekberg wrote:
02-05-2010, 02:00
Radio static
Thanks   Ernie & Pete  I'll see what I can find.
Don Spithaler 89 SP 36' Butler, PA Â -----Â New Port Richey, FLÂ Â Â Â On Thu, Feb 4, 2010 at 9:44 PM, Pete Masterson <"aeonix1@mac.com"> wrote:
02-05-2010, 03:26
Radio static
I have an "Accessory" switch on the left hand side of the driversarea that has to be turned on to have sound from the televison come through the speakers in the front of the coach. There is no static or humming when the switch is off and the radio is playing. When theswitch is turned on to hear the televison there is an annoying humming sound. Does the filter talked about in the previous post have anything to do with this? I have considered buying a couple of speakers and hooking the tv straight into them and bypassing the accessory switch. I don't care about surround sound. I just want to get rid of the humming noise.
Any suggestions?
Randy Merrill
2003 LX
Ocala, FL
02-05-2010, 13:35
Radio static
Likely you're hearing 60-cycle hum. That's caused by circuits in the TV passing unwanted interference through to the 12vdc based sound system. There should be simple filters that will knock that out. Visit a knowledgeable mobile audio dealer and have a technician check out the system (to make sure my guess is correct) and/or to recommend a device you can wire into the speaker circuit yourself.
Pete Masterson (former) '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 5, 2010, at 7:26 AM, "randymerri@aol.com" wrote:
02-06-2010, 02:11
Radio static
Thanks Pete,
I will give it a try.
Randy Merrill
2003 LX
Ocala, FL
