Height of a 1995 42' bird
05-16-2009, 01:14
Goodmorning all----Need the height of a 95 bird with the suspension aired up.
(top of ac) Also, with with the suspension dumped can you still pull forward
without tire rub. Thanks, Bob birdless in Illinois
05-16-2009, 04:03
Should be about 12'-6" when aired up. You can move forward with suspension
down, but you can't turn.
R.E. (ron) Marabito, Dallas, TX 92WB40
--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`"
05-16-2009, 05:34
Be careful of non-stock items on the roof. I have a satellite TV antenna dome -- sticks way above the ACs, usually the highest item. Puts me juuuust under 13'. Dealer I bought it from said the coach cleared 12-6 with the suspension down (how they got it in the door to their shop).
Moving with the suspension dumped requires going super-slow in a straight line.
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
On May 16, 2009, at 9:03 AM, ronmarabito2002 wrote:
Should be about 12'-6" when aired up. You can move forward with suspension down, but you can't turn.
--- In "WanderlodgeForum@yahoogroups.com", "Bob & Carol Howald`" wrote:
Goodmorning all----Need the height of a 95 bird with the suspension aired up. (top of ac) Also, with with the suspension dumped can you still pull forward without tire rub. Thanks, Bob birdless in Illinois
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
"WanderlodgeForum-digest@yahoogroups.com"
"WanderlodgeForum-fullfeatured@yahoogroups.com"
"WanderlodgeForum-unsubscribe@yahoogroups.com"
05-18-2009, 13:41
HMMMM. With suspension dumped, how are the brakes affected?
Liz
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 Wanderlodge WB40
D'Hanis, TX
Buena Vista, CO
05-18-2009, 23:17
it in a straight line and still have brakes. Ernie-83PT40 in Texas, currently in
Cornelius, NC
> Liz
> Regards,
> Jack and Liz Pearce
> D'Hanis, TX
> Buena Vista, CO
05-20-2009, 06:38
Bob,
As Ernie ahs stated, you can pull STRAIGHT forward, but you can not turn if the
suspension is dumped. My 96 is 12'8 or 9" to the top of the a/c's with the
suspension up. But the antennas stick up more than that. I typically use 13'
as my go/no go point.
John
--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" wrote:
> drive it in a straight line and still have brakes. Ernie-83PT40 in Texas,
currently in Cornelius, NC
> > Liz
> > Regards,
> > Jack and Liz Pearce
> > D'Hanis, TX
> > Buena Vista, CO
05-21-2009, 08:38
My 96' is 12' 5" to the top of the air conditioners when aired up. I used a
board with a level on it and measured to the ground. (I needed 5 hands to
measure that.)
Eric Perplies
96 42' WBWL
