Unidentified drain hole under 8V92
04-05-2009, 10:11
Found something I hadn't noticed before while working under the coach
today. Just in front of the 8V92's oil pan, there is another
oil-pan-like object with a threaded hole much like the oil pan drain
plug. However, this hole doesn't have a plug screwed into it - it's
just open to the outside world. I took pictures:
http://www.ryanwright.com/tmp/bus1.jpg
http://www.ryanwright.com/tmp/bus1close.jpg
Anyone know what this is? Hopefully it's supposed to be unplugged?
Thank you!
-Ryan
'86 PT-40 8V92
04-05-2009, 11:11
Looks like the drain hole in the bell housing, it lets any oil leaking
out of rear of engine to escape. Leave it open. Elmer in Sebring
86 PT 38
> Thank you!
> -Ryan
> '86 PT-40 8V92
04-05-2009, 11:13
> Thank you!
> Richard Carter here 89WB-40 8V92, I believe your looking at an inspection hole
for your timeing in the tranny. I have the same hole an was told it at some
time had a cover for it. They didn't tell me to cover it.
> -Ryan
> '86 PT-40 8V92
04-05-2009, 11:28
Thanks Richard & Elmer!
-Ryan
'86 PT-40 8V92
>> hole for your timeing in the tranny. I have the same hole an was told it at
>> some time had a cover for it. They didn't tell me to cover it.
