Headlight switch
03-02-2008, 06:01
Post: #21
Headlight switch
Yes, anytime Bill. Comes with ear muffs too (actually not too bad).
It has the Allison 4 speed auto behind it & straight exhausts all the way out the rear bumper. Terry Neal Bozeman, MT 82PT40 74FC34 Wilhelmus Schreurs wrote: > Terry: > I sure could use that 74 of yours to run up and down the hills here, > gosh would that be nice LOL. > Can I borrow it for a while . > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > ----- Original Message ---- > From: Terry Neal > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, March 1, 2008 1:11:20 PM > Subject: Re: [WanderlodgeForum] Re: Headlight Switch > > Good stuff Greg. Am going to do head & tail lights on mine as soon as > the snow melts a little. A lot of protection in these upgrades. > >Terry Neal >Bozeman, MT >82PT40 6V92TA >74FC34 6V53T > > > > > Gregory OConnor wrote: > >> >> Often a switch burns out when an appliance it turns on draw too much >> juice. >> >> Setting up a relay to power the lights will route the juice to glow >> the light away from the dash switch. the dash switch will then only >> power or trip the relays. JohnF has an article about a headlight >> relay upgrade some place. >> >> You can use several relays to trip different lights that the switch >> powers. Set the dash switch to trip each relay in parellel. that >> way a fault in one light or length of wire will not darken the >> remaining lights. >> >> The relay also helps supply more juice to the lights and they glow >> brighter B-). >> >> CurtS of this forum built a relay board for my ailing tail lights and >> an independent set of relays for the trailer plug. that way the toad >> or trailer wont effect the bus running lights. >> >> 94pt Taillight relays <http://www.pbase.com/gregoryoc/image/82214174> >> >> http://www.pbase. com/gregoryoc/ image/82214174 >> <http://www.pbase.com/gregoryoc/image/82214174> >> >> GregoryO'Connor >> >> 94ptRomolandCa >> >> >> > > > ------------------------------------------------------------------------ > Ask a question on any topic and get answers from real people. Go to > Yahoo! Answers. <http://ca.answers.yahoo.com> > |
03-02-2008, 16:13
Post: #22
Headlight switch
Terry:
I can handle that, bet it has a lot of giddee up and go though, much more than our 3208T Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada Looking for the perfect gift? Give the gift of Flickr! |
12-03-2008, 12:41
Post: #23
Headlight switch
Guess what? Got in Sunday night after T'gvg all working well ... now
the dash, parking, nor clearance lights will work. Seems to be a section of the headlight switch gone bad. Call Earl at BB or is there another source?? 1991. Steve Enfinger Newton, GA '91 WBSA |
12-03-2008, 14:28
Post: #24
Headlight switch
Steve,
I had my lights go out on the road on night. I removed the light switch and very gently bent the contacts out to get a better connection, seems after 13 years they get a little straightend out. They have worked great for two years now. Hope this helps. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > Guess what? Got in Sunday night after T'gvg all working well ... now > the dash, parking, nor clearance lights will work. Seems to be a > section of the headlight switch gone bad. Call Earl at BB or is there > another source?? 1991. > > Steve Enfinger > Newton, GA > '91 WBSA > |
12-03-2008, 14:28
Post: #25
Headlight switch
Steve,
I had my lights go out on the road one night. I removed the light switch and very gently bent the contacts out to get a better connection, seems after 13 years they get a little straightend out. They have worked great for two years now. Hope this helps. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > Guess what? Got in Sunday night after T'gvg all working well ... now > the dash, parking, nor clearance lights will work. Seems to be a > section of the headlight switch gone bad. Call Earl at BB or is there > another source?? 1991. > > Steve Enfinger > Newton, GA > '91 WBSA > |
12-04-2008, 01:39
Post: #26
Headlight switch
Steve
If yours is like mine I just went through that. Mine wasn't working & I put a new switch in. It worked a few times then it quit again I found that moving wires in the front of the dash it would come on. I finally figured it was a wire in one of my cannon plugs. It seem to be working good now. Don Spithaler 89 SP 36' Butler, PA On Wed, Dec 3, 2008 at 9:28 PM, Kurt Horvath <"kguns@hughes.net"> wrote:
12-04-2008, 02:46
Post: #27
Headlight switch
The headlight switches are a weak spot (mine is 'out' for now, too).
My temporary workaround was to wire in a switch that supplies power to the appropriate relays that turn on the clearance, dash, and parking lights. You can order a new switch from BB or from one of the BB school bus distributors. There may be another source as the switch is from a third party, but I haven't identified it. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Williams, AZ "gateway to the Grand Canyon." On Dec 3, 2008, at 5:41 PM, Steve & Kathy Enfinger wrote: > Guess what? Got in Sunday night after T'gvg all working well ... now > the dash, parking, nor clearance lights will work. Seems to be a > section of the headlight switch gone bad. Call Earl at BB or is there > another source?? 1991. > > Steve Enfinger > Newton, GA > '91 WBSA > |
12-05-2008, 07:12
Post: #28
Headlight switch
wrote: > > The headlight switches are a weak spot (mine is 'out' for now, too). > My temporary workaround was to wire in a switch that supplies power > to the appropriate relays that turn on the clearance, dash, and > parking lights. > > You can order a new switch from BB or from one of the BB school bus > distributors. There may be another source as the switch is from a > third party, but I haven't identified it. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Williams, AZ "gateway to the Grand Canyon." > > > > On Dec 3, 2008, at 5:41 PM, Steve & Kathy Enfinger wrote: > > > Guess what? Got in Sunday night after T'gvg all working well ... now > > the dash, parking, nor clearance lights will work. Seems to be a > > section of the headlight switch gone bad. Call Earl at BB or is there > > another source?? 1991. > > > > Steve Enfinger > > Newton, GA > > '91 WBSA > > > I had this happen to me last year and I was able to get a new switch at NAPA. It is a stock item for them. Craig Hovda Bigfork Mt 90 WBWL |
12-05-2008, 07:34
Post: #29
Headlight switch
Any idea of the stock number?
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Williams, AZ On Dec 5, 2008, at 12:12 PM, ingamar2 wrote: >> >> <snip> > I had this happen to me last year and I was able to get a new > switch at NAPA. It is a stock item for them. > |
