Has anyone every used one of these to start a bird?
11-12-2008, 05:27
Gary, when I had my coach on a consignment lot, they never had it on shore power. Thus the batteries were dead. I attached jumper cables to the generator battery and started the generator. In just a short time, I was up and running and left that facility.
83PT40
Weatherford, Texas
11-12-2008, 09:27
I had to crawl under the coach
83PT40
Weatherford, Texas
11-12-2008, 10:19
I'm still in search of an economical way to ABSOLUTELY quickly get
started after dry camping.
I'm a little paranoid because we accidently turned on the security
lights one night and had to wait the entire next day for a jump.
Couldn't get the genset to charge the batteries enough within a few
hours.
Has anyone ever used something like either of these two items to
start a bird?
http://www.harborfreight.com/cpi/ctaf/di...mber=46944
http://www.harborfreight.com/cpi/ctaf/di...mber=47449
I used to have one like the first item to start my tractors after
sitting for a week or two but am curious if they would provide a
nearly immediate start as long as the genset came alive.
If you take the time to read the manual of the second item, it could
be rigged up to autostart the genset with a minimum of trouble.
Movin on,
GPSGary
1984FC35
11-12-2008, 13:35
If the bird is asleep, how do you get to the generator battery to get
jumper cables on it? My gen tray won't come out without air up.
I can start the generator but it takes a long time to get the
batteries to where the Cat will purr.
Regards,
GPSGary
1984FC35
on shore
the generator
and running
> Ernie Ekberg
> 83PT40
> Weatherford, Texas
> **************Get the Moviefone Toolbar. Showtimes, theaters, movie
news &
> more!
(http://pr.atwola.com/promoclk/100000075x...12037/aol?
redir=htt
> p://toolbar.aol.com/moviefone/download.html?
ncid=emlcntusdown00000001)
11-12-2008, 13:41
I carry a 200 AMP booster that plugs into AC, makes it easy to use any available AC
to soup up the batteries quick and it can delivery 400 amps for 30 seconds to help
start the engine.
Dorn Hetzel
77FC35
Hogansville, GA
Regards,
GPSGary
1984FC35
on shore
the generator
and running
> Ernie Ekberg
> 83PT40
> Weatherford, Texas
news &
> more!
redir=htt
11-12-2008, 13:55
What make? Where'd you get it?
How much?
Regards,
GPSGary
11-12-2008, 14:09
Mine has an external power plug. Simple and easy if you have the other side of the plug. It is similar to the external power attachment on aircraft but not as large.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
--- On Wed, 11/12/08, hippieforever3 wrote:
Subject: [WanderlodgeForum] Re: Has anyone every used one of these to start a bird?
Date: Wednesday, November 12, 2008, 8:35 PM
Regards,
GPSGary
1984FC35
on shore
the generator
and running
> Ernie Ekberg
> 83PT40
> Weatherford, Texas
> ************ **Get the Moviefone Toolbar. Showtimes, theaters, movie
news &
> more!
(http://pr.atwola. com/promoclk/ 100000075x121277 4565x1200812037/ aol?
redir=htt
> p://toolbar. aol.com/moviefon e/download. html?
ncid=emlcntusdown00 000001)
11-12-2008, 14:10
I've had mine like 15 years and everything that tells who made it has long since worn off,
but here is a similar example I found for around $125 at northern tool:
http://www.northerntool.com/webapp/wcs/s..._200332525
Regards,
Dorn Hetzel
77FC35
How much?
Regards,
GPSGary
11-12-2008, 14:17
Gary,
If you are dry camping how do you get AC? A good generator battery is the answer to your problem. I should not take all day to charge the engine batteries off the generator if your chargers are working properly.
Chet Geist
1981 FC33, Austin, Texas
-----Original Message-----
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of hippieforever3
Sent: Wednesday, November 12, 2008 7:55 PM
How much?
Regards,
GPSGary
11-12-2008, 14:46
Gary,
I maybe a little confused, you want to have a charger on the coach so that you can charge the coach while dry camping?? run the generator, for a while press the parrell switch and hopefully the big engine will kick over
jim riordan
88 WBWL XXV
stuart, fl
hours.
start a bird?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46944
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47449
trouble.
Movin on,
GPSGary
1984FC35
