1989 Silver ED.
11-06-2008, 03:28
1989 Silver ED.
Hi, all Richard here from big Decatur, Il. I have brought a Bluebird
about three months ago, looking for some place to take it to for a full
body look over an repair. Anyone know of the good place to take it?
11-06-2008, 03:33
1989 Silver ED.
Hi, all, Richard here from the big city of Decatur, Il. I brought my
coach about three months ago, looking for a place to take it to get a
full look over an repair. Have gone about as far as I can by myself.
Want to restore an need help!! Looking for a good place to go with it,
all help is welcome.
11-06-2008, 04:50
1989 Silver ED.
I don't personally know of a place in IL familiar with BB's. There is the BB factory in Fort Valley, GA and Coachcraft by MacDonald in Columbus, GA. I have used Coachcraft which is a certified repair station for BB's. Their work was excellent.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
--- On Thu, 11/6/08, dctrcarter wrote:
Subject: [WanderlodgeForum] 1989 Silver ED.
Date: Thursday, November 6, 2008, 10:33 AM
11-06-2008, 10:33
1989 Silver ED.
Hi Richard,
Welcome to the forum. Jay Darst and I have both had engine work done
by Coile's Diesel in Saybrook, IL. They were terrific and pricing was
extremely fair. They are very familiar with the screamin' Jimmys and
should be able to handle any engine issues for you. It'll probably be
tough to find one shop that is thoroughly qualified to look at all
facets of your coach- but try
{http://www.funroads.com/coachcare/normal/} They should have the staff
on-hand to look at the genny, jacks, suspension and drivetrain. We
have a branch of the Coach Care network locally and they have always
treated me fairly.
Shane Fedeli
85PT40
Hershey, PA
--- In WanderlodgeForum@yahoogroups.com, "dctrcarter"
11-06-2008, 15:31
1989 Silver ED.
Columbus, GA.. I have used Coachcraft which is a certified repair
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: dctrcarter
> Thanks for the tips, Still have trouble with the wireing on the
lites, think its a ground on the groung bar on front drivers side, a
million wires are going in an out from that point.
Il. I brought my
a
myself.
it,
11-06-2008, 15:35
1989 Silver ED.
--- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...>
> Hi Richard,
done
was
be
staff
> treated me fairly.
> Shane Fedeli
> 85PT40
> Hershey, PA
Bluebird
a full
it?
Thanks for the tip, I know J, talked to him about going to his place,
an he could lead me to the right people to get this baeutly on the
road.
11-07-2008, 02:13
1989 Silver ED.
I do not know if you have drawings or what group of problems you are having. It is extremely important that the coach have total ground integrity. Some easy things to check and clean are as follows as located on my coach. Yours should be similar.
Main battery ground-It is a gang ground located at the rear curb side attached to the jumper start bar. It runs street to curb near the rear bumper below the bulk oil fill switch. Take it apart clean all connections, use electrical grease and reassemble.
Secondary ground-On the curb side about half way up the engine bay front wall above the batteries is another ground to the frame. Disassemble it, clean and reassemble.
Engine to frame ground-Clean it up
There should be one for the tranny also. Do the same. If necessary you can run additional ground straps from the engine and tranny to the frame.
In the
front lower load center where all the relays are located you should find a ground bus bar 6"-8" long and a couple inches wide.and 4? fuse centers along with about 40 relays. Check out the integrity of the ground connections there. There may be a gang location at this ground bus bar for several smaller 16 gauge wires.
I have never had any problems with my lights but some folks have. It may be necessary to use relays to make them work properly. It is also possible there is corrosion in one or more or the cannon plugs out front forward of the driver. Unscrew them and check for a burned pin or corrosion.
Always disconnect grounds first and install them last. All of this assumes your coach is similar to mine.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Subject: [WanderlodgeForum] Re: 1989 Silver ED.
Date: Thursday, November 6, 2008, 10:31 PM
--- In "WanderlodgeForum%40yahoogroups.com", Leroy Eckert
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: dctrcarter
Il. I brought my
a
myself.
it,
11-10-2008, 06:15
1989 Silver ED.
Richard, I am not a techie guy and do not have any knowledge of the systems on my coach I have Holland Motor Coach in Holland MI do ALL of my work. I am treated fair and have been taken care of by them since I purchased my Coach. The Service manager is Mike Mulenberg 800-221-7197
Sent: Thursday, November 06, 2008 10:43 AM
11-10-2008, 06:17
1989 Silver ED.
Still having trouble with air lights on front of coach, ground bar
I found in front driver side under steering column, thousand wire are
coming an going here, how about the grounding bar in the generator
side above the cooling fan, is their a wire to the lights ? Have some
drawning to this 1989 WB, Body #f82081,40',tag, Silver Ed. This coach
set four five years, would love to get it traveling again.
are having.. It is extremely important that the coach have total
the frame.
> In the front lower load center where all the relays are located you
pin or corrosion.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: dctrcarter
> --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert
There
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
> > From: dctrcarter
> > To: WanderlodgeForum@ yahoogroups. com
a
> Il. I brought my
get
> a
> myself.
with
> it,
11-10-2008, 06:39
1989 Silver ED.
AIR LIGHTS?? are you refering to the driving lights that drop down or
the lights that are associated with the low air pressure or the
lights associated with the air suspension system?
Jim Riordan
Stuart, Fl. 34994
are
some
coach
> the frame.
you
this
> pin or corrosion.
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
> > From: dctrcarter
Eckert
> There
in
> > > Leroy Eckert
> > > Dahlonega, GA
> > > Royale Conversion
> > > From: dctrcarter
> a
> > Il. I brought my
> get
> > a
> > myself.
> with
> > it,
