water problem
05-29-2005, 06:24
water problem
I had the same thing happen. Thought it was the sporlan valve- ordered some
from Stephen Birtles-- prompt service- Ernie-83PT40 in Texas [Non-text portions of this message have been removed] |
05-29-2005, 08:03
water problem
Not sure about your rig setup for water but on mine I have to flip the
switch to allow water to flow into tank. When the tank is full I have to flip the switch off or the water pumps will not pump water out of the tank. Rob Robinson 1994 WLWB Victoria, BC -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of mortyheller Sent: Sunday, May 29, 2005 4:53 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] water problem i hooked up to city water and had the fill switch off and the water ran into the tank. when i turn the pump on with the tank full the pump works but i don't get any water. any idears what can be wrong?? morty heller 87 pt 40 jax. fl in ohio ---------------------------------------------------------------------------- -- Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.322 / Virus Database: 267.2.0 - Release Date: 5/27/2005 [Non-text portions of this message have been removed] |
05-29-2005, 09:53
water problem
ran into the tank. when i turn the pump on with the tank full the pump works but i don't get any water. any idears what can be wrong?? morty heller 87 pt 40 jax. fl in ohio |
05-29-2005, 10:12
water problem
Sporlan valve stuck open. You can try turning the fill switch on with
water flowing from the hose, see if a piece of debris is holding the valve open, usually need to replace the diaphragm (rebuild kit). - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "mortyheller" <mortyheller@y...> wrote: > i hooked up to city water and had the fill switch off and the water > ran into the tank. when i turn the pump on with the tank full the pump > works but i don't get any water. any idears what can be wrong?? > > morty heller 87 pt 40 jax. fl in ohio |
05-30-2005, 00:05
water problem
Hi Morty,
Make sure that your air purge switch is off and that the hot water tank fill/drain switch is in the proper position. If these two items are OK, then it probably is one of the sporlan valves acting up. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "mortyheller" <mortyheller@y...> wrote: > i hooked up to city water and had the fill switch off and the water > ran into the tank. when i turn the pump on with the tank full the pump > works but i don't get any water. any idears what can be wrong?? > > morty heller 87 pt 40 jax. fl in ohio |
