Inverter Wiring
10-20-2008, 12:42
Inverter Wiring
Guys---I want to set a small freezer in one my outside bays. There is
a plug there but how do I wire it to run off the inverter while going
down the road? How would I know if it will run off a 1500 W inverter?
Thanks
Don Spithaler
89 SP 36'
Butler, PA
10-20-2008, 13:05
Inverter Wiring
unplug the bus from shore and turn the inverter on.Any hot receptical
found must thenbe inverter powered. ( I have one bb installed bay
receptical that is inverter hot). run a new receptical close to the
new fridge from there.
Watts devided by voltes = amps. W/V=A .1500/120=12.5. 1500 watt
inverter gives 120 volts @12.5 amps max. I bet the fridge has a watt
or amp value advertised.
I found the biggest amp/watt hog appliance is a coffee pot.
Greg94ptCa
--- In WanderlodgeForum@yahoogroups.com, "Don Spithaler"
> Thanks
> Don Spithaler
> 89 SP 36'
> Butler, PA
10-20-2008, 13:45
Inverter Wiring
Greg
A toaster is a hog to. My coffee pot & toaster can't be on at the same time with the 1500 W
On Mon, Oct 20, 2008 at 9:05 PM, Gregory OConnor <"Gregoryoc@aol.com"> wrote:
Greg94ptCa
--- In "WanderlodgeForum%40yahoogroups.com", "Don Spithaler"
> Thanks
> Don Spithaler
> 89 SP 36'
> Butler, PA
10-20-2008, 14:18
Inverter Wiring
Yep - the toaster and the coffee pot takes a lot and so does the vacuum - my heart stops when my wife vacuums the bus and I watch the battery meters...
Sent: Monday, October 20, 2008 6:45 PM
Subject: Re: [WanderlodgeForum] Re: Inverter Wiring
Greg
Greg94ptCa
> Thanks
> Don Spithaler
> 89 SP 36'
> Butler, PA
10-21-2008, 02:52
Inverter Wiring
The inverters in a BB are set up with their own distribution wiring
(separate from the main 120 vac panel). So, follow the output wires
from the inverter and you should find a distribution system (possibly
with circuit breakers) somewhere nearby. You can 'join' a new wire
there (or set up an additional circuit breaker) to run to the
location of the freezer.
Load: you first need to determine what the general load on the
inverter is at present. What devices are attached and how many are
used at the same time? It may be that all the available load is
(potentially) used up by the existing appliances.
Appliances almost always have watt or amp ratings on them (usually on
a tag by the manufacturer's name on the back). To ease calculations,
convert all ratings to either watts or amps. (Amps x volts (120) =
watts or Watts divided by volts (120) = amps) So, a 1500 watt
inverter can handle about 12.5 amps in total. You should leave a
couple hundred watts (2 amps or so) "free" to allow for calculation
errors and electrical efficiency. Motors (which don't "like" certain
types of inverters) prefer "true sine wave" power -- something an
older inverter may not provide. Motors (the freezer compressor) also
draw as much at 50 more power at start up than their rating, so
allowance must be made for that, as well.
In all probability, the inverter on your coach is already wired up to
use most of its maximum rated power for the appliances already
attached. I expect, depending on the size of the freezer, that you
will find that it draws anywhere from 6 to 8 amps up to around 10
amps. (Remember to add for the brief overload for motor start up.)
So, the solution(s) are (1) upgrade the existing inverter from a 1500
watt unit to a 2500 watt, true sine wave unit or (2) add a second
inverter of about 1000-1500 watts (depending on the size of your
freezer) to handle only the freezer circuit.
Keep in mind that the additional 'juice' required for the inverter
will come at the expense of the batteries. If you only use the
freezer/inverter while on the road, the engine alternator should be
replenishing the house batteries to offset the load, but while
parked, the house batteries will need to provide the inverter power,
and I know from personal experience (I have a home-style 22 cu ft
side-by-side refrigerator-freezer) that refrigeration can draw down
batteries rather quickly. You may need to consider adding additional
house batteries (or otherwise increasing the available amp-hours) to
compensate for the additional demand.
Pete Masterson
aeonix1@...
On the road at Edinburg, VA
> Thanks
> Don Spithaler
> 89 SP 36'
> Butler, PA
10-21-2008, 04:53
Inverter Wiring
Pete, there is a group of switches that stand between the 120V
electric panel and the receptical/appliance. when you power on the
inverter I believe the inverter sends 12volts to the On On switch
and removes shore/gen 120v (what ever the transfer switch is sending)
and paths the power from the inverter.ON1= shore/gen ON2=inverter.
If the switch fails one of the inverterpowered paths wont switch
between the two choices
Wierd thing is I cant seem to understand how the
receptical/appliance is then protected. The power no longer rus thru
the houshhold style pandnel breaker box but goes directly from the
inverter total output source. I guess any leg once powered by
inverter then has the ability to draw 12.5 amps (or 30 amps if the
individual inverter is a 3600watt). would be good to understand the
protection of circuit wires when you add a larger inverter and more
demand.
Greg94ptCa
wiring
wires
(possibly
wire
are
on
calculations,
calculation
certain
also
to
you
1500
inverter
be
power,
down
additional
to
> Pete Masterson
> aeonix1@...
There is
going
inverter?
> > Thanks
> > Don Spithaler
> > 89 SP 36'
> > Butler, PA
10-21-2008, 07:10
Inverter Wiring
Don, with my house type refer, I can and do drive 4 hours and when I stop for lunch, start the generator, run that for an hour and all is well till I stop for the nite. Worked like that for 3 years, now.
83PT40
Weatherford, Texas
10-21-2008, 07:42
Inverter Wiring
since I don't have an inverter, that was my solution
83PT40
Weatherford, Texas
10-21-2008, 11:02
Inverter Wiring
Pete
The freezer that I'm looking at is small. It is 115V / 95W so it would be drawing under 1 amp. Is that right? I would be only using the inverter while going down the road. We don't dry camp any. On the road the only thing on the inverter would be the TV & my laptop. I'm not ready to upgrade the inverter at this time & I don't want to get into that unless I have to.
Don Spithaler
89 SP 36'
Butler, PA
Pete Masterson
"aeonix1%40mac.com"
> Thanks
> Don Spithaler
> 89 SP 36'
> Butler, PA
10-21-2008, 11:30
Inverter Wiring
Ernie
That what I'll be doing too. I run the genny at night.
Don Spithaler
89 SP 36'
Butler, PA
83PT40
Weatherford, Texas
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News more. Try it out!
User(s) browsing this thread: 17 Guest(s)
