Generator
10-14-2008, 12:38
Post: #21
Generator
Richard here, quit upday on my yanmar 12.5Kvw. Still looking for bad
wire#5, that comes out of the top of the starter solenoid, know that
it is in the wires that go behind the motor then connects with a big
set of wires that come down an out on the left side, go back around
the back of the gen. set, thinking them wires go to the right side
the controller wires are their, an the harness of wires from the
controller. I have a dead wire 0n #5, have jumper that wire to the 5
terminal in the controller, lets me start the gen, an runs great.
Asking if I'm on the right track here?
04-03-2010, 23:04
Post: #22
Generator
My generator will not move when I press the in and out
button. We can Hear the motor running but nothing happens. I assume there is a
gear or shaft that is the problem.
Bill
83 PT 35’wanderlodge 92TDD silver
PCFL
04-04-2010, 04:02
Post: #23
Generator
Have you checked the level of the hydraulic tank under your steps?
That's why mine wouldn't move.
Art Weatherly
Riverside Ca
'85 PT36
--- In WanderlodgeForum@yahoogroups.com, "Bill Jowers" <bgjowers@...> wrote:
> My generator will not move when I press the in and out button. We can Hear
> the motor running but nothing happens. I assume there is a gear or shaft
> Bill
> 83 PT 35'wanderlodge 92TDD silver
> PCFL
04-04-2010, 05:09
Post: #24
Generator
The genset tray on the 83PT moves in and out courtesy of a hydraulic ram
cylinder. It operates off the same hydraulic motor and oil supply (under the
front entry steps) as the leveling jacks. If the hydraulic motor is running, as
you state, then you are either low on oil (as Art stated) or there is a seal
leak on the cylinder. If you are low on hydraulic fluid, the leveling jacks
should not operate properly either. Is there a puddle of hydraulic oil under
the genset tray? If so, let us know and I'll post how to repair the hydraulic
ram cylinder seals.
1991 WB40 "Texas Minivan"
> Bill
> PCFL
04-04-2010, 05:14
Post: #25
Generator
BTW, BB recommended Dexron ATF in the hydraulic system for that year. Check to
make sure the existing fluid looks red like ATF.
ram cylinder seals.
> Mike Bulriss
> San Antonio, TX
> > Bill
> > PCFL
04-04-2010, 05:21
Post: #26
Generator
Use Caution
check to see what kind of fluid this pump uses. some used 30 weight only. some used tranny or hydraulic fluid only or it will eat the seals
--- On Sun, 4/4/10, artw wrote:
Subject: [WanderlodgeForum] Re: Generator
Date: Sunday, April 4, 2010, 12:02 PM
Art Weatherly
Riverside Ca
'85 PT36
--- In WanderlodgeForum@ yahoogroups. com, "Bill Jowers" <bgjowers@.. .> wrote:
> Bill
> PCFL
04-04-2010, 06:13
Post: #27
Generator
Mike,
I'd like the directions for an 85 PT40. Mine seems to be leaking and I haven't had the time to tackle it yet. But, I need to get my bottom in gear and get it fixed. I appreciate the help.
Jerry
85 PT40
Sent: Sun, April 4, 2010 10:09:58 AM
The genset tray on the 83PT moves in and out courtesy of a hydraulic ram cylinder. It operates off the same hydraulic motor and oil supply (under the front entry steps) as the leveling jacks. If the hydraulic motor is running, as you state, then you are either low on oil (as Art stated) or there is a seal leak on the cylinder. If you are low on hydraulic fluid, the leveling jacks should not operate properly either. Is there a puddle of hydraulic oil under the genset tray? If so, let us know and I'll post how to repair the hydraulic ram cylinder seals.
--- In "WanderlodgeForum%40yahoogroups.com", "Bill Jowers" <bgjowers@.. .> wrote:
> the motor
> Bill
> PCFL
