air chuck from engine air compressor
10-11-2008, 01:06
Am getting tired of waiting in line at truck stops to air up the
tires. I think I remember someone pointing out an air chuck coming
from the engine air compressor but I'm not sure where it would be. Is
there an air chuck coming from the engine air compressor on the 2000
LXI? If so, does it have sufficient 'torque', like the truck stop
compressors, to quickly air up the tires?
Yup, we do have the 110 vt auxilliary compresser but it doesn't have
the 'torque' when you are talking 95 to 115 psi.
Ron 'n Ruth, still in MN in 2000 LXI
10-11-2008, 03:20
My coach has an air outlet in the road-side compartment just in front
of the water/sewer connection compartment. It has a standard fitting
to accept a air hose.
Does it have the oomph to bring the tires from (say) 95 to 115 psi in
a reasonable time? Not in my experience. It's capable of delivering
120 psi (the limit of the air system), but it's fairly slow and the
engine must be running. Probably adequate for an emergency. (When I
was in the Army, a zillion years ago, we had similar connectors on
all our trucks -- those could add a few lbs. of air to a tire in a
pretty decent time...) I don't know what plumbing the air outlet has
behind it that might reduce the volume of air present.
I carry a 'contractor's type' air compressor with us to do my tires.
(150 PSI max, 4 gallon twin tank, Ridgid brand from Home Depot.)
Pete Masterson
aeonix1@...
On the road near Lancaster, PA
10-11-2008, 04:19
CFM cubic feet per minute is the rating that show the speed a
compressor will inflate. On the bus several of the many limiting
factors that restrict the high psi that is avaliable from the Detroit
compressor is the ;friction of a small id line ;small id protection
valve and small quick chuck fitting sets. the valve on the tire is
the final limiting factor but little high volumn air makes it to
there. when the tire pressure gets higher the small 110v compressors
may slow down a bit but they still pack close of the same volumn of
air into the tire. that volumn is what increase the psi.
if you put a connection point to the large hose off the compressor
and maintain a large id from there on, tire fill will be quick. but
that will require a large id protestion valve$$ and hose etc. the
best trick is to get a valve chuck with a clip that holds its self to
the tire valve. there are two types one that require the removal of
the schrader valve guts and onr that pushes the valve tounge in.
about $15. Napa.
Tire shops often remove the shrader valve guts from the tire to limit
the restriction and speed the inflate.
I had a coil of hose plugged into a quick chuck on my dump truck when
I got pulled over for a surprise (trap) inspection and received a
$240. fine and fix it ticket. the California CHP teach maintenance
respect with their ticket book. Pisses me off at the same time makes
me feel secure that all operators are reviewed with this scrutinity.
These guys would have a field day with a motorhome/bus.
Greg94ptCa
front
fitting
in
delivering
I
has
tires.
> Pete Masterson
> aeonix1@...
coming
be. Is
2000
have
10-11-2008, 04:48
Ronn Ruth..You are really concerned about volumn and pressure, not torque...My 1991 WBWL has air in the 3rd bay on the roadside and is more than sufficent to fill the tires..Jim Barone
-----Original Message-----
Sent: Sat, 11 Oct 2008 8:06 am
Subject: [WanderlodgeForum] air chuck from engine air compressor
10-11-2008, 04:53
Having the very old style Bird (gas), I dont have to worry about a
compressor. To top off my tires, I bought a 20 pound C02 tank with
a (Fixed) 150psi regulator. It works well, and tops the tires off in
good time. (It is the 'Big Brother" of the 5# tank I carry in the
Jeep to air up the tires after a days run through the desert, where I
drop them to 6 or 8 psi, and need 28psi for the asphalt).
The whole 20# rig cost just over $100 with hose & all. You carry
the C02 tank around to the tires and don't get the nasty looks as you
would if you fired up the trusty Diesel at the break of dawn.
Jack Smith
1973FC31
Bankrupt Arnold-Land.
front
fitting
in
delivering
I
has
tires.
> Pete Masterson
> aeonix1@...
coming
be. Is
2000
have
10-11-2008, 11:54
Thanks for all the replies guys. I don't know what we'd do without
these forums. So much is learned here. It would be nice if we had
another high 'torque' compressor but alas, no room. Back to the truck
stops.
Ron & Ruth in MN in 2000 LXI
Branson by next weekend.
10-12-2008, 04:54
One thought ... if you're losing more than a couple psi per month,
you may have slow leak.
I've had trouble with my tire valves leaking. I've solved this
problem by (1) getting a bunch of high quality valve cores (online)
and (2) getting a similar quantity of metal valve caps. After
checking the tires for air pressure, I always check for a leak from
the valve. Just the act of disturbing the valve with the air pressure
gauge is sometimes enough to set off a slow leak. If I see that the
valve is leaking, I replace it with a new valve core. (After doing
this a few times, you get pretty quick at it.) I also carefully
inspect the valve cap to insure that there is a good (undamaged)
rubber seal inside the metal cap -- then I tighten the cap firmly on
the valve. This has made my tire pressures quite stable. I check the
tires regularly, but rarely notice a drop of more than 2 or 3 psi in
30 days.
If the valves are it good condition, you may just possibly have a
"slow leak" -- which is inevitably a small puncture that should be
repaired. Slow leaks often progress to be faster leaks where the loss
of air becomes very obvious. Recently, our toad showed signs of a
"slow leak" ... and a trip to a tire store found a small screw had
worked its way into the tire. It had barely punctured, but over time
that puncture would have become rather larger as the head of the
screw worked its way in...
Pete Masterson
aeonix1@...
> stops.
10-12-2008, 13:32
We have a 12v compressor from Viair.
It was recommended by Livingston of Good Sam Club.
They have several models, 110 or 12v. We have the 12v model and it
pumps up our 120 psi tires nooo problem.
Google them and see if it will work for you.
Bob Lawrence
84 PT36
Branson, Mo
10-12-2008, 14:18
What interests me is why you have such a need to air up often. I seem to be able to air up about once a year, with the pressure pro installed all tires deem to hold their pressure. Do you have leaks in your valves or what is going on?
jim riordan
truck
stops.
10-13-2008, 03:35
I am a little confused. I have an air chuck in the left roadside bay forward of the drive wheel. I use it to fill the tires when needed. I say when needed only because I changed to dually valves and have not added air in months. Perhaps the new bird does not have this chuck. The engine driven or twin piston aux air pump supplies the air, my choice through the aux air system.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
--- On Sun, 10/12/08, Bob Lawrence wrote:
Subject: [WanderlodgeForum] Re: air chuck from engine air compressor
Date: Sunday, October 12, 2008, 9:32 PM
Bob Lawrence
84 PT36
Branson, Mo
