Work finished, Refrigerator & Muffler Fix & Replace
09-28-2008, 17:03
Well most of this go around for upgrades/fixes are done. Lil_Stankes are in and working, some new rocker switches, relocate wiring for VMSpc Silverleaf & upgrade new 2.4 software, it has a new engine file for the Series 60 @ 470 HP, I'm wondering how that will compare to the 500hp setting they told me use. New water pumps and plumbing, new water outlet on curb side, Gay water tank overflow plumbimg, Fresh water system sanitized, cleaned out behind Splendid 2000 washer/dryer, disassemble, clean, polish & reassemble air horns. Fixed air purge fresh water flush system and rerouted airlines into pump bay for easy access. Quick coupler for LP Gas replaced and copper pipe cut and a inserted union for future disassembly. Jake Brake troubleshooting. Checked Cannon plug for burnt pins and found none. I used a 10X loupe to examine the pins and then photographed them from both sides at 3264 X 2176 resolution and magnified them on the computer and found no burnt or discoloration on the Cannon plugs male or female sides, gave them a good shot of electronic contact cleaner and some di-electric grease and reassembled. I'll have the spare DDEC IV scanned and checked for the Jake program then installed to see if that solves the Jake Brake problem, The present DDEC may have been deactivated by previous owners. Anyway I need to try out the spare to make sure it will work when I really need it. If you need or think you'll need a DDEC ECM look on e-bay, good used and refurbished unit at much less than you'll pay at D.D.. I got one Mfg in '07 it was used as test unit for a few months and programmed to my engine for under $600. D.D. want $2500plus for a reman and $'s for programming. I still have a problem with the refrigerator not cooling well while underway. Some of you have tested your coaches with ribbons taped on and around the sides of the coach and radiator area and have discovered that there are unique air patterns around the body. Notably the lack of air flowing into the radiator. I would surmise that this is true on the roof as well. I'm thinking that this applies to the refrigerator exhaust vent on the roof and it's relationship to the vent on the side of the body. I have installed 5 - 130cfm computer fans in the exhaust vent they will draw 650 CFM. So I think that would overcome any adverse air flow caused by the effects of air passing across the coach. Well it still isn't functioning well while underway, Works great while parked. I'm at a loss as to where to go from here. Any ideas would be helpful. The next major task is replacing the muffler. While installing the Lil-Stanker powered tank vents I stopped to look at the exhaust stack and reached down to give it a little shake and the chromes elbow is only held on by the mounting clamp. It's hollow inside, the baffels are gone it's just a tube. I have one ordered, they are hard to get. Cummins has a 45 to 60 day back order on the Donaldson/Nelson/Fleetgaurd muffler part # 86610M. Found one from Fleetpride, under $250 delivered to the farm. BB wanted $900 + I would like to insulate the muffler and or the muffler tunnel. I don't really have a heat issue . But since I'm there doing it anyway might as well improve it if practical. There is only about 1" clearance on each side, the tunnel measures 13" X 13.5 on my coach and the muffler is 11.10 in diameter so you can see there isn't much clearance to do much of anything. I am considering Thermo Tec exhaust insulating wrap. It is rated at 2000 degrees continuos use and 3000 degrees intermittent use. It comes in 6" wide rolls and shouldn't be too hard to install, it's only 1/16th of an inch thick so clearance isn't a problem. Paint the pipe with some sort of high temp paint/coating to slow down corrosion. I've read that the first few runs will cause some smoke/smell but once it's "cured" that will stop. Paint the muffler, wrap it, clamp it, paint the wrap to seal it from the elements and install on coach, Sounds easy, TOO EASY! Somebody with some experience with this needs to chime in here. Another idea is a smaller diameter muffle with a heat blank from ATP, Firwin or Kolb. The Fleetgaurde muffler # 82132M would do nicely. It has almost the same flow rate within 100 CFM and it's 9" in diameter, that would increase the clearance from the tunnel walls to the muffler by 100%. 2" VS 1" The downside is 5" diameter opening VS the 6" for the original equipment muffler and pipes. May be a better option, but more expensive. If you get this far through this post I still have 20+ CD's of the `95 - `96 PT 42 and `97 PT 43 Diagrams & Blueprints available. If you want one send e-mail to kguns@... Kurt Horvath 95 pt 42 wlwb 10AC |
09-29-2008, 00:54
Two comments: Regarding your refrigerator not cooling when underway:
You should verify that the white thermocouple that is fastened on the right side of your reefer coils is securely attached. It's just a friction fit. (I had a similar problem and that was the solution.) I have not changed the muffler on my rig. I understand that it is challenging to drop the new muffler in and hold it in position so you can secure it. When you paint the muffler with the very high temperature paint be aware that this type of paint has a very high silicone content that sloughs off on your hands easily. I had a problem with my turbo charger tubes coming apart after painting them with the high silicone paint. I would mask the clamping area with tape and remove the masking tape just before clamping. Another thought: I wonder if adding insulation to the box or the muffler will improve things? Keeping a large air space around your hot muffler will promote convection air currents that may be desirable. Just a thought. Good luck on your projects. Eric Perplies 96' 42' WBWL |
09-29-2008, 01:44
Kurt,
I would recommend you *not* insulate the muffler. Even BB removed the insulation they used to use from existing BBs to prevent heat buildup and fires, as there were a few stack fires and closet fires. If you don't mind a loud stack, you could also consider a straight pipe rather than a muffler. When I had my muffler changed, I didn't notice an appreciable noise reduction from the previous burned out/rusted out muffler. I'm still pretty loud (the bus as well as me, lol). If you wouldn't mind, I'd like one CD of each that you have available, both the 95-96 and the 97. I could get them from you at Maxton since I see you are signed up to be there or RATS if you are going. Thanks. Paul 97wb43 --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Work finished, Refrigerator & Muffler Fix & Replace > > Well most of this go around for upgrades/fixes are done. Lil_Stankes > are in and working, some new rocker switches, relocate wiring for > VMSpc Silverleaf & upgrade new 2.4 software, it has a new engine file > for the Series 60 @ 470 HP, I'm wondering how that will compare to > the 500hp setting they told me use. New water pumps and plumbing, new > water outlet on curb side, Gay water tank overflow plumbimg, Fresh > water system sanitized, cleaned out behind Splendid 2000 > washer/dryer, disassemble, clean, polish & reassemble air horns. > Fixed air purge fresh water flush system and rerouted airlines into > pump bay for easy access. Quick coupler for LP Gas replaced and > copper pipe cut and a inserted union for future disassembly. Jake > Brake troubleshooting. Checked Cannon plug for burnt pins and found > none. I used a 10X loupe to examine the pins and then photographed > them from both sides at 3264 X 2176 resolution and magnified them on > the computer and found no burnt or discoloration on the Cannon plugs > male or female sides, gave them a good shot of electronic contact > cleaner and some di-electric grease and reassembled. I'll have the > spare DDEC IV scanned and checked for the Jake program then > installed to see if that solves the Jake Brake problem, The present > DDEC may have been deactivated by previous owners. Anyway I need to > try out the spare to make sure it will work when I really need it. If > you need or think you'll need a DDEC ECM look on e-bay, good used and > refurbished unit at much less than you'll pay at D.D.. I got one Mfg > in '07 it was used as test unit for a few months and programmed to my > engine for under $600. D.D. want $2500plus for a reman and $'s for > programming. > > I still have a problem with the refrigerator not cooling well while > underway. Some of you have tested your coaches with ribbons taped on > and around the sides of the coach and radiator area and have > discovered that there are unique air patterns around the body. > Notably the lack of air flowing into the radiator. I would surmise > that this is true on the roof as well. I'm thinking that this applies > to the refrigerator exhaust vent on the roof and it's relationship to > the vent on the side of the body. I have installed 5 - 130cfm > computer fans in the exhaust vent they will draw 650 CFM. So I think > that would overcome any adverse air flow caused by the effects of > air passing across the coach. Well it still isn't functioning well > while underway, Works great while parked. I'm at a loss as to where > to go from here. Any ideas would be helpful. > > The next major task is replacing the muffler. While installing the > Lil-Stanker powered tank vents I stopped to look at the exhaust > stack and reached down to give it a little shake and the chromes > elbow is only held on by the mounting clamp. It's hollow inside, the > baffels are gone it's just a tube. I have one ordered, they are hard > to get. Cummins has a 45 to 60 day back order on the > Donaldson/Nelson/Fleetgaurd muffler part # 86610M. Found one from > Fleetpride, under $250 delivered to the farm. BB wanted $900 + > > I would like to insulate the muffler and or the muffler tunnel. I > don't really have a heat issue . But since I'm there doing it anyway > might as well improve it if practical. There is only about 1" > clearance on each side, the tunnel measures 13" X 13.5 on my coach > and the muffler is 11.10 in diameter so you can see there isn't much > clearance to do much of anything. I am considering Thermo Tec exhaust > insulating wrap. It is rated at 2000 degrees continuos use and 3000 > degrees intermittent use. It comes in 6" wide rolls and shouldn't be > too hard to install, it's only 1/16th of an inch thick so clearance > isn't a problem. Paint the pipe with some sort of high temp > paint/coating to slow down corrosion. I've read that the first few > runs will cause some smoke/smell but once it's "cured" that will > stop. Paint the muffler, wrap it, clamp it, paint the wrap to seal it > from the elements and install on coach, Sounds easy, TOO EASY! > Somebody with some experience with this needs to chime in here. > > Another idea is a smaller diameter muffle with a heat blank from ATP, > Firwin or Kolb. The Fleetgaurde muffler # 82132M would do nicely. It > has almost the same flow rate within 100 CFM and it's 9" in diameter, > that would increase the clearance from the tunnel walls to the > muffler by 100%. 2" VS 1" The downside is 5" diameter opening VS the > 6" for the original equipment muffler and pipes. May be a better > option, but more expensive. > > If you get this far through this post I still have 20+ CD's of > the `95 - `96 PT 42 and `97 PT 43 Diagrams & Blueprints available. If > you want one send e-mail to kguns@... > > Kurt Horvath > 95 pt 42 wlwb > 10AC > |
09-29-2008, 02:02
I had to get the BB muffler -- not cheap! but it wasn't practical for
me to have left my coach at CCW. (If I had it to do over, I might have dropped the coach off at CCW, then come back for it in 2 or 3 weeks...) I'm not sure what you're trying to accomplish with the insulation, wrapping, etc. As installed, there's an inch or so space around the muffler as it runs up the back corner to the roof. This allows air flow to carry away the heat through the perforated "grill" at the roof. It seems like a reasonable design to me. I'd be concerned that the insulation would cause the internal muffler parts to get excessively hot. I understand the desire to paint the muffler to control corrosion -- but isn't the major problem the corrosive effect of the diesel exhaust on the inside? When my old muffler was pulled out, it was (as you say) an empty tube. All the internal baffles had vanished. In my case, the muffler body (tube) was not eroded through except for a beginning of a hole at the bottom -- probably due to rain water accumulation. Indeed, I suspect the major culprit is rain water entering the muffler from the exhaust port at the top. I attempted to get a true 90 degree stack-end that would tend to keep rain water from entering the muffler. The (presumably OEM) stack-end was very slightly turned, but was still mostly open to falling rain. (The replacement that CCW installed is better, but still will allow wind-driven rain to enter the muffler, if the wind is blowing the right way.) I plan to put a bucket or other cover over the exhaust-stack end during storage to keep the rain water out. I note that the newest BBs have a 90 degree bend stack-end that has a foot or so of horizontal pipe, thereby eliminating nearly all chance of significant rain water collection. The biggest challenge was finding components in the large diameter used. Almost all generally available heavy duty diesel exhaust components max out at 5" diameter. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road near Scranton, PA On Sep 29, 2008, at 1:03 AM, Kurt Horvath wrote: > <snip> > The next major task is replacing the muffler. While installing the > Lil-Stanker powered tank vents I stopped to look at the exhaust > stack and reached down to give it a little shake and the chromes > elbow is only held on by the mounting clamp. It's hollow inside, the > baffels are gone it's just a tube. I have one ordered, they are hard > to get. Cummins has a 45 to 60 day back order on the > Donaldson/Nelson/Fleetgaurd muffler part # 86610M. Found one from > Fleetpride, under $250 delivered to the farm. BB wanted $900 + > > I would like to insulate the muffler and or the muffler tunnel. I > don't really have a heat issue . But since I'm there doing it anyway > might as well improve it if practical. There is only about 1" > clearance on each side, the tunnel measures 13" X 13.5 on my coach > and the muffler is 11.10 in diameter so you can see there isn't much > clearance to do much of anything. I am considering Thermo Tec exhaust > insulating wrap. It is rated at 2000 degrees continuos use and 3000 > degrees intermittent use. It comes in 6" wide rolls and shouldn't be > too hard to install, it's only 1/16th of an inch thick so clearance > isn't a problem. Paint the pipe with some sort of high temp > paint/coating to slow down corrosion. I've read that the first few > runs will cause some smoke/smell but once it's "cured" that will > stop. Paint the muffler, wrap it, clamp it, paint the wrap to seal it > from the elements and install on coach, Sounds easy, TOO EASY! > Somebody with some experience with this needs to chime in here. > > Another idea is a smaller diameter muffle with a heat blank from ATP, > Firwin or Kolb. The Fleetgaurde muffler # 82132M would do nicely. It > has almost the same flow rate within 100 CFM and it's 9" in diameter, > that would increase the clearance from the tunnel walls to the > muffler by 100%. 2" VS 1" The downside is 5" diameter opening VS the > 6" for the original equipment muffler and pipes. May be a better > option, but more expensive. > > If you get this far through this post I still have 20+ CD's of > the `95 - `96 PT 42 and `97 PT 43 Diagrams & Blueprints available. If > you want one send e-mail to kguns@... > > Kurt Horvath > 95 pt 42 wlwb > 10AC > > |
09-29-2008, 03:33
I was pretty sure most views would be against the insulation wrap. It
doesn't seem to have a good reputation in respect to corrosion issues. Pete is correct it did corrode from the inside out. I thought about ceramic coating before insulating with wrap,the cost is not in the budget. The people I spoke with asked if I could get to the inner parts and that it would be a better application if they could coat the interior as well as the exterior of the muffler. Doesn't look like that will happen. Several people have recommended a straight stack. What are the positive & negative aspects of a straight stack? It would be the best as far as getting the most clearance in the tunnel and would greatly increase the area for convection to occur. I would think that with a small modification to the mounts it would be easier to install than the huge muffle that's in there now. The fact that the muffler is just a tube at this point noise is not very much an issue. Kurt Horvath 95 PT 42 10AC |
09-29-2008, 03:40
Paul & David,
I need your address for the CD Paul probably going to miss out on Maxton, not sure yet. e-mail me at kguns@... Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Hmmm, my muffler and angled up-pipe are insulated with a wire-tied, > wrap around jacket. The jacket on the base of the muffler definitely > blocks vertical air passage. Do you guys recommend that I remove > this insulation? Paul, when did BB cease installing this insulation, and > did they ever remove it from the LXi's? > > Thanks, > David Brady > '02 LXi, NC (home at last!) > > p_a_lazar wrote: > > > > Kurt, > > > > I would recommend you *not* insulate the muffler. Even BB removed the > > insulation they used to use from existing BBs to prevent heat buildup > > and fires, as there were a few stack fires and closet fires. > > > > If you don't mind a loud stack, you could also consider a straight > > pipe rather than a muffler. When I had my muffler changed, I didn't > > notice an appreciable noise reduction from the previous burned > > out/rusted out muffler. I'm still pretty loud (the bus as well as me, > > lol). > > > > If you wouldn't mind, I'd like one CD of each that you have available, > > both the 95-96 and the 97. I could get them from you at Maxton since I > > see you are signed up to be there or RATS if you are going. > > > > Thanks. > > Paul > > 97wb43 > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Work finished, Refrigerator & Muffler Fix & Replace > > > > > > Well most of this go around for upgrades/fixes are done. Lil_Stankes > > > are in and working, some new rocker switches, relocate wiring for > > > VMSpc Silverleaf & upgrade new 2.4 software, it has a new engine file > > > for the Series 60 @ 470 HP, I'm wondering how that will compare to > > > the 500hp setting they told me use. New water pumps and plumbing, new > > > water outlet on curb side, Gay water tank overflow plumbimg, Fresh > > > water system sanitized, cleaned out behind Splendid 2000 > > > washer/dryer, disassemble, clean, polish & reassemble air horns. > > > Fixed air purge fresh water flush system and rerouted airlines into > > > pump bay for easy access. Quick coupler for LP Gas replaced and > > > copper pipe cut and a inserted union for future disassembly. Jake > > > Brake troubleshooting. Checked Cannon plug for burnt pins and found > > > none. I used a 10X loupe to examine the pins and then photographed > > > them from both sides at 3264 X 2176 resolution and magnified them on > > > the computer and found no burnt or discoloration on the Cannon plugs > > > male or female sides, gave them a good shot of electronic contact > > > cleaner and some di-electric grease and reassembled. I'll have the > > > spare DDEC IV scanned and checked for the Jake program then > > > installed to see if that solves the Jake Brake problem, The present > > > DDEC may have been deactivated by previous owners. Anyway I need to > > > try out the spare to make sure it will work when I really need it. If > > > you need or think you'll need a DDEC ECM look on e-bay, good used and > > > refurbished unit at much less than you'll pay at D.D.. I got one Mfg > > > in '07 it was used as test unit for a few months and programmed to my > > > engine for under $600. D.D. want $2500plus for a reman and $'s for > > > programming. > > > > > > I still have a problem with the refrigerator not cooling well while > > > underway. Some of you have tested your coaches with ribbons taped on > > > and around the sides of the coach and radiator area and have > > > discovered that there are unique air patterns around the body. > > > Notably the lack of air flowing into the radiator. I would surmise > > > that this is true on the roof as well. I'm thinking that this applies > > > to the refrigerator exhaust vent on the roof and it's relationship to > > > the vent on the side of the body. I have installed 5 - 130cfm > > > computer fans in the exhaust vent they will draw 650 CFM. So I think > > > that would overcome any adverse air flow caused by the effects of > > > air passing across the coach. Well it still isn't functioning well > > > while underway, Works great while parked. I'm at a loss as to where > > > to go from here. Any ideas would be helpful. > > > > > > The next major task is replacing the muffler. While installing the > > > Lil-Stanker powered tank vents I stopped to look at the exhaust > > > stack and reached down to give it a little shake and the chromes > > > elbow is only held on by the mounting clamp. It's hollow inside, the > > > baffels are gone it's just a tube. I have one ordered, they are hard > > > to get. Cummins has a 45 to 60 day back order on the > > > Donaldson/Nelson/Fleetgaurd muffler part # 86610M. Found one from > > > Fleetpride, under $250 delivered to the farm. BB wanted $900 + > > > > > > I would like to insulate the muffler and or the muffler tunnel. I > > > don't really have a heat issue . But since I'm there doing it anyway > > > might as well improve it if practical. There is only about 1" > > > clearance on each side, the tunnel measures 13" X 13.5 on my coach > > > and the muffler is 11.10 in diameter so you can see there isn't much > > > clearance to do much of anything. I am considering Thermo Tec exhaust > > > insulating wrap. It is rated at 2000 degrees continuos use and 3000 > > > degrees intermittent use. It comes in 6" wide rolls and shouldn't be > > > too hard to install, it's only 1/16th of an inch thick so clearance > > > isn't a problem. Paint the pipe with some sort of high temp > > > paint/coating to slow down corrosion. I've read that the first few > > > runs will cause some smoke/smell but once it's "cured" that will > > > stop. Paint the muffler, wrap it, clamp it, paint the wrap to seal it > > > from the elements and install on coach, Sounds easy, TOO EASY! > > > Somebody with some experience with this needs to chime in here. > > > > > > Another idea is a smaller diameter muffle with a heat blank from ATP, > > > Firwin or Kolb. The Fleetgaurde muffler # 82132M would do nicely. It > > > has almost the same flow rate within 100 CFM and it's 9" in diameter, > > > that would increase the clearance from the tunnel walls to the > > > muffler by 100%. 2" VS 1" The downside is 5" diameter opening VS the > > > 6" for the original equipment muffler and pipes. May be a better > > > option, but more expensive. > > > > > > If you get this far through this post I still have 20+ CD's of > > > the `95 - `96 PT 42 and `97 PT 43 Diagrams & Blueprints available. If > > > you want one send e-mail to kguns@ > > > > > > Kurt Horvath > > > 95 pt 42 wlwb > > > 10AC > > > > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG. > > Version: 7.5.526 / Virus Database: 270.7.5/1696 - Release Date: 9/28/2008 1:30 PM > > > |
09-29-2008, 04:03
Kurt,
What,, Whitewalls ? try running the refer on the inverter when you travel. (may have to run an extension cord to the refer mechanical compartment) running it 110volts with good result (cold beer) would rule out airmovement and point issue at lpg heater or the flame its self. you may have so much air flow going down the road that the gradual cooling necessary for amonia evaporation is compramised, or the flame turns white and heat gets sucked past the boiler???? Or the flame constantly requires relighting with all the turbulance. maybe 110 and no fan will work better while traveling?? I wonder if the hotbedroom is not mostly the heat from the tranny and tires being trapped up against the bell end of the engine?? the stack may be a minimal issue and more tolerable if there was a way to vent the tire tranny area?? Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" wrote: > > I was pretty sure most views would be against the insulation wrap. It > doesn't seem to have a good reputation in respect to corrosion > issues. Pete is correct it did corrode from the inside out. > > I thought about ceramic coating before insulating with wrap,the cost > is not in the budget. The people I spoke with asked if I could get to > the inner parts and that it would be a better application if they > could coat the interior as well as the exterior of the muffler. > Doesn't look like that will happen. > > Several people have recommended a straight stack. What are the > positive & negative aspects of a straight stack? It would be the > best as far as getting the most clearance in the tunnel and would > greatly increase the area for convection to occur. I would think that > with a small modification to the mounts it would be easier to install > than the huge muffle that's in there now. The fact that the muffler > is just a tube at this point noise is not very much an issue. > > Kurt Horvath > 95 PT 42 > 10AC > |
09-29-2008, 04:06
David,
Don't know when BB changed the insulation situation, but I looked at a number of 97s prior to buying mine, and some had had fire damage (fixed) and all had the insulation removed. Paul --- In WanderlodgeForum@yahoogroups.com, David Brady > > Hmmm, my muffler and angled up-pipe are insulated with a wire-tied, > wrap around jacket. The jacket on the base of the muffler definitely > blocks vertical air passage. Do you guys recommend that I remove > this insulation? Paul, when did BB cease installing this insulation, and > did they ever remove it from the LXi's? > > Thanks, > David Brady > '02 LXi, NC (home at last!) > > p_a_lazar wrote: > > > > Kurt, > > > > I would recommend you *not* insulate the muffler. Even BB removed the > > insulation they used to use from existing BBs to prevent heat buildup > > and fires, as there were a few stack fires and closet fires. > > > > If you don't mind a loud stack, you could also consider a straight > > pipe rather than a muffler. When I had my muffler changed, I didn't > > notice an appreciable noise reduction from the previous burned > > out/rusted out muffler. I'm still pretty loud (the bus as well as me, > > lol). > > > > If you wouldn't mind, I'd like one CD of each that you have available, > > both the 95-96 and the 97. I could get them from you at Maxton since I > > see you are signed up to be there or RATS if you are going. > > > > Thanks. > > Paul > > 97wb43 > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Work finished, Refrigerator & Muffler Fix & Replace > > > > > > Well most of this go around for upgrades/fixes are done. Lil_Stankes > > > are in and working, some new rocker switches, relocate wiring for > > > VMSpc Silverleaf & upgrade new 2.4 software, it has a new engine file > > > for the Series 60 @ 470 HP, I'm wondering how that will compare to > > > the 500hp setting they told me use. New water pumps and plumbing, new > > > water outlet on curb side, Gay water tank overflow plumbimg, Fresh > > > water system sanitized, cleaned out behind Splendid 2000 > > > washer/dryer, disassemble, clean, polish & reassemble air horns. > > > Fixed air purge fresh water flush system and rerouted airlines into > > > pump bay for easy access. Quick coupler for LP Gas replaced and > > > copper pipe cut and a inserted union for future disassembly. Jake > > > Brake troubleshooting. Checked Cannon plug for burnt pins and found > > > none. I used a 10X loupe to examine the pins and then photographed > > > them from both sides at 3264 X 2176 resolution and magnified them on > > > the computer and found no burnt or discoloration on the Cannon plugs > > > male or female sides, gave them a good shot of electronic contact > > > cleaner and some di-electric grease and reassembled. I'll have the > > > spare DDEC IV scanned and checked for the Jake program then > > > installed to see if that solves the Jake Brake problem, The present > > > DDEC may have been deactivated by previous owners. Anyway I need to > > > try out the spare to make sure it will work when I really need it. If > > > you need or think you'll need a DDEC ECM look on e-bay, good used and > > > refurbished unit at much less than you'll pay at D.D.. I got one Mfg > > > in '07 it was used as test unit for a few months and programmed to my > > > engine for under $600. D.D. want $2500plus for a reman and $'s for > > > programming. > > > > > > I still have a problem with the refrigerator not cooling well while > > > underway. Some of you have tested your coaches with ribbons taped on > > > and around the sides of the coach and radiator area and have > > > discovered that there are unique air patterns around the body. > > > Notably the lack of air flowing into the radiator. I would surmise > > > that this is true on the roof as well. I'm thinking that this applies > > > to the refrigerator exhaust vent on the roof and it's relationship to > > > the vent on the side of the body. I have installed 5 - 130cfm > > > computer fans in the exhaust vent they will draw 650 CFM. So I think > > > that would overcome any adverse air flow caused by the effects of > > > air passing across the coach. Well it still isn't functioning well > > > while underway, Works great while parked. I'm at a loss as to where > > > to go from here. Any ideas would be helpful. > > > > > > The next major task is replacing the muffler. While installing the > > > Lil-Stanker powered tank vents I stopped to look at the exhaust > > > stack and reached down to give it a little shake and the chromes > > > elbow is only held on by the mounting clamp. It's hollow inside, the > > > baffels are gone it's just a tube. I have one ordered, they are hard > > > to get. Cummins has a 45 to 60 day back order on the > > > Donaldson/Nelson/Fleetgaurd muffler part # 86610M. Found one from > > > Fleetpride, under $250 delivered to the farm. BB wanted $900 + > > > > > > I would like to insulate the muffler and or the muffler tunnel. I > > > don't really have a heat issue . But since I'm there doing it anyway > > > might as well improve it if practical. There is only about 1" > > > clearance on each side, the tunnel measures 13" X 13.5 on my coach > > > and the muffler is 11.10 in diameter so you can see there isn't much > > > clearance to do much of anything. I am considering Thermo Tec exhaust > > > insulating wrap. It is rated at 2000 degrees continuos use and 3000 > > > degrees intermittent use. It comes in 6" wide rolls and shouldn't be > > > too hard to install, it's only 1/16th of an inch thick so clearance > > > isn't a problem. Paint the pipe with some sort of high temp > > > paint/coating to slow down corrosion. I've read that the first few > > > runs will cause some smoke/smell but once it's "cured" that will > > > stop. Paint the muffler, wrap it, clamp it, paint the wrap to seal it > > > from the elements and install on coach, Sounds easy, TOO EASY! > > > Somebody with some experience with this needs to chime in here. > > > > > > Another idea is a smaller diameter muffle with a heat blank from ATP, > > > Firwin or Kolb. The Fleetgaurde muffler # 82132M would do nicely. It > > > has almost the same flow rate within 100 CFM and it's 9" in diameter, > > > that would increase the clearance from the tunnel walls to the > > > muffler by 100%. 2" VS 1" The downside is 5" diameter opening VS the > > > 6" for the original equipment muffler and pipes. May be a better > > > option, but more expensive. > > > > > > If you get this far through this post I still have 20+ CD's of > > > the `95 - `96 PT 42 and `97 PT 43 Diagrams & Blueprints available. If > > > you want one send e-mail to kguns@ > > > > > > Kurt Horvath > > > 95 pt 42 wlwb > > > 10AC > > > > > > > > > ------------------------------------------------------------------------ > > > > No virus found in this incoming message. > > Checked by AVG. > > Version: 7.5.526 / Virus Database: 270.7.5/1696 - Release Date: 9/28/2008 1:30 PM > > > |
09-29-2008, 04:36
Hmmm, my muffler and angled up-pipe are insulated with a wire-tied, wrap around jacket. The jacket on the base of the muffler definitely blocks vertical air passage. Do you guys recommend that I remove this insulation? Paul, when did BB cease installing this insulation, and did they ever remove it from the LXi's? Thanks, David Brady '02 LXi, NC (home at last!) p_a_lazar wrote:
09-29-2008, 05:51
Gregg,
I want spokes on the wheels! :} I usually run it on LP. I'll give the 110 V a chance. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Kurt, > > What,, Whitewalls ? > > try running the refer on the inverter when you travel. (may have to > run an extension cord to the refer mechanical compartment) running > it 110volts with good result (cold beer) would rule out airmovement > and point issue at lpg heater or the flame its self. you may have so > much air flow going down the road that the gradual cooling necessary > for amonia evaporation is compramised, or the flame turns white and > heat gets sucked past the boiler???? Or the flame constantly > requires relighting with all the turbulance. maybe 110 and no fan > will work better while traveling?? > > I wonder if the hotbedroom is not mostly the heat from the tranny > and tires being trapped up against the bell end of the engine?? the > stack may be a minimal issue and more tolerable if there was a way > to vent the tire tranny area?? > > Greg94ptCa > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > wrote: > > > > I was pretty sure most views would be against the insulation wrap. > It > > doesn't seem to have a good reputation in respect to corrosion > > issues. Pete is correct it did corrode from the inside out. > > > > I thought about ceramic coating before insulating with wrap,the > cost > > is not in the budget. The people I spoke with asked if I could get > to > > the inner parts and that it would be a better application if they > > could coat the interior as well as the exterior of the muffler. > > Doesn't look like that will happen. > > > > Several people have recommended a straight stack. What are the > > positive & negative aspects of a straight stack? It would be the > > best as far as getting the most clearance in the tunnel and would > > greatly increase the area for convection to occur. I would think > that > > with a small modification to the mounts it would be easier to > install > > than the huge muffle that's in there now. The fact that the > muffler > > is just a tube at this point noise is not very much an issue. > > > > Kurt Horvath > > 95 PT 42 > > 10AC > > > |
