Temps
06-18-2008, 23:16
Post: #31
Temps
I guess having the radiator in front is one of the nicer points of an FC Smile
Dorn Hetzel
77FC35
Hogansville, GA
On Thu, Jun 19, 2008 at 3:23 AM, Glenn Allen <"RAGster@bellsouth.net"> wrote:
Thanks Steve. I talked with Leroy tonight. He and Ralph have given me a few good ideas
to investigate.
Glenn
1986 PT40
--- In "WanderlodgeForum%40yahoogroups.com", "patticake592000" <sgureasko@...> wrote:
> Glenn,
> If you have already added fluid to the rear end, then you probably
> don't need servicing. On mine, you could smell the fluid(when being
> drained), from 5-10 feet away. It was really burned!!
> When checking the speed of the fan, you will know if it's on low
> speed, because you can almost count the blades(something like 300
> to 500 rpms). Call Leroy, he's close and is good at diagnosing these
> problems, plus he likes doing these things.
> Steve Gureasko
> 90WBWL40 Jus Chillin
> Ponchatoula, La.
