					ISO Wiring Diagram - Electric Step
					05-14-2005, 11:41
					Anyone else have an electric step at the entrance instead of an air
			step? If so, do you have a wiring diagram for it? The control wiring in mine has developed a problem and it would sure be nice to see a diagram instead of doing the ol' hand trace. Thanks - Bob Griesel '84 FC31 WLII WA  |
					05-14-2005, 13:05
					Yeah, Bob;  Our 73 has the electric operated steps..  Our Old coach
			has no air source, so electric steps were manditory.. I dont have any diagrams, they Chisled would be on Stone Tablets, anyway... Jack Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > Anyone else have an electric step at the entrance instead of an air > step? If so, do you have a wiring diagram for it? The control wiring > in mine has developed a problem and it would sure be nice to see a > diagram instead of doing the ol' hand trace. > > Thanks > - Bob Griesel '84 FC31 WLII WA  |
					05-16-2005, 05:20
					Bob:
			The WLII electric step wiring diagram is #3764768. Mostly unique to the WLII, but there are a few regular Wanderlodges with electric steps. I have that drawing if you have any specific questions, or if you wish to get a complete copy you can try calling Bennie and requesting one. Also, if you have access to the air-step wiring drawing, I expect there are similarities (same switches and wiring used), I can compare the two and you could work from the air-step wiring drawing. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > Anyone else have an electric step at the entrance instead of an air > step? If so, do you have a wiring diagram for it? The control wiring > in mine has developed a problem and it would sure be nice to see a > diagram instead of doing the ol' hand trace. > > Thanks > - Bob Griesel '84 FC31 WLII WA  |
					05-16-2005, 06:59
					Jeff -
			Bennie is going to send a copy of the diagram (thanks for the number!) but I'm open to any suggestions if you've seen this particular failure before. My step has a relay that reverses the step motor. When the relay coil is energized, the step advances; when the coil is relaxed, the step retracts. When the door closes, the door switch opens and should cause the coil to relax. Suddenly the only way to relax the coil is to pull the coil wire at the relay. The relay, socket, door switch, and limit switches test good, so something may have happened to the wiring between the door switch and the relay. There is also a dashboard switch, so that wiring loop is suspect as well I suppose. Thanks, Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > Bob: > > The WLII electric step wiring diagram is #3764768. Mostly unique to > the WLII, but there are a few regular Wanderlodges with electric > steps. > > I have that drawing if you have any specific questions, or if you > wish to get a complete copy you can try calling Bennie and requesting > one. > > Also, if you have access to the air-step wiring drawing, I expect > there are similarities (same switches and wiring used), I can compare > the two and you could work from the air-step wiring drawing. > > - Jeff Miller > http://www.wanderlodge.net > http://www.millercoachworks.com > > > --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > > Anyone else have an electric step at the entrance instead of an air > > step? If so, do you have a wiring diagram for it? The control > wiring > > in mine has developed a problem and it would sure be nice to see a > > diagram instead of doing the ol' hand trace. > > > > Thanks > > - Bob Griesel '84 FC31 WLII WA  |
					05-16-2005, 07:31
					The only help I can offer is to check the tape-switch above the step.
			If it is shorted the step will not retract, snip the wires to this switch to check. The rest of the wiring is too complex to troubleshoot long-distance. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > Jeff - > > Bennie is going to send a copy of the diagram (thanks for the > number!) but I'm open to any suggestions if you've seen this > particular failure before. > > My step has a relay that reverses the step motor. When the relay > coil is energized, the step advances; when the coil is relaxed, the > step retracts. When the door closes, the door switch opens and > should cause the coil to relax. Suddenly the only way to relax the > coil is to pull the coil wire at the relay. > > The relay, socket, door switch, and limit switches test good, so > something may have happened to the wiring between the door switch and > the relay. There is also a dashboard switch, so that wiring loop is > suspect as well I suppose. > > Thanks, > Bob Griesel '84 FC31 WLII WA  |
					05-16-2005, 08:39
					Great suggestion on the tape-switch.  Thanks.  If that isn't it, I'll
			have the complete diagram to work from soon. - Bob Griesel --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > The only help I can offer is to check the tape-switch above the step. > If it is shorted the step will not retract, snip the wires to this > switch to check. > > The rest of the wiring is too complex to troubleshoot long-distance. > > - Jeff Miller > http://www.wanderlodge.net > http://www.millercoachworks.com > > > --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > > Jeff - > > > > Bennie is going to send a copy of the diagram (thanks for the > > number!) but I'm open to any suggestions if you've seen this > > particular failure before. > > > > My step has a relay that reverses the step motor. When the relay > > coil is energized, the step advances; when the coil is relaxed, the > > step retracts. When the door closes, the door switch opens and > > should cause the coil to relax. Suddenly the only way to relax the > > coil is to pull the coil wire at the relay. > > > > The relay, socket, door switch, and limit switches test good, so > > something may have happened to the wiring between the door switch > and > > the relay. There is also a dashboard switch, so that wiring loop > is > > suspect as well I suppose. > > > > Thanks, > > Bob Griesel '84 FC31 WLII WA  |
