Updating holding tank sensors
02-17-2008, 09:52
Hi group,
Just to let you know about an upgrade I did to my holding tank
sensors. Took maybe 3-4 hrs total to do this.
Like most of us, the sensors (probes) that our rigs came with are
prone to getting fouled. I found in the first 4 years of ownership
that I couldn't rely on the sensors to give me an accurate reading.
I found the Micropulse system while looking around in the Prevost and
Newell sites.
What these are, are sensors that are mounted as low in the sidewall
of the tank as possible using a 3/4 spin in or the flat sensor
adaptor. The flat adaptor is the one I used. The adaptor required
drilling a 5/8 hole in the sidewall of the tank. Put some silicone
glue to the bottom of the adaptor. Also used #10 x 1/2" stainless
steel self tapping screws to attach the adaptor to the sidewall. I
then wrapped the threads of the sensor using Teflon tape and
installed the sensor by screwing it in the adaptor. Just tighten by
hand.
The sensor is connected to the monitor using a 4 conductor flat
modular phone cable supplied.
I put the monitor alongside the fridge inside. Had to run the wire
down behind the fridge and thru the floor to the sensors.
I put a sensor in the grey and one in the black tank. The monitor can
also handle fresh water and LP sensors. I didn't feel the need for
these.
My findings after using this system fulltime for over 8 months now
are great!! When I push the buttons (or can leave on fulltime),after
calibration it has proved to be very accurate. We love it!!
To calibrate after install, you of course have an empty tank (better
before you drilled the holes LOL!!)you push a button for the empty
reading for each tank. Then you fill the tanks and take another
reading. The minicomputer in the monitor calculates the areas in
between and registers on the display.
The unit has a 5 year warrenty and are used on the high end rigs now.
Their web site is
catconproducts.com
The nice thing about these sensors is they use liquid pressure to get
a reading so there is no probe to foul. Never need cleaning.
Finally an accurate reading!!
Any questions, please ask...
Bob Lawrence
84 PT36
Fulltiming-presently in Boulder City, Nv
02-17-2008, 12:00
Bob,
Does it retain the calibration if the power is interupted? (like
when I disconnect the batteries for storage)
Gardner
78FC33
> Hi group,
> Newell sites.
sidewall
by
> hand.
can
> these.
fulltime),after
(better
now.
> Their web site is
> catconproducts.com
get
> Bob Lawrence
> 84 PT36
02-17-2008, 12:28
Yes, it retains info. This was one of my questions also when checking
them out.
By the way, my cost was approx $150 for the monitor and $50 ea. for
the sensors.
Bob
> Bob,
> Gardner
> 78FC33
> > Hi group,
ownership
reading.
> and
> > Newell sites.
> sidewall
silicone
I
> by
> > hand.
wire
> can
for
> > these.
now
> fulltime),after
> (better
empty
> now.
> > Their web site is
> > catconproducts.com
> get
> > Bob Lawrence
> > 84 PT36
02-17-2008, 14:17
Bob,
Where did you get them from?
Gardner
78FC33
checking
> them out.
for
> the sensors.
> Bob
> > Bob,
(like
> > Gardner
> > 78FC33
> > wrote:
> > > Hi group,
are
> ownership
> reading.
Prevost
> > and
> > > Newell sites.
> > sidewall
required
> silicone
stainless
sidewall.
> I
tighten
> > by
> > > hand.
flat
> wire
monitor
> > can
> for
> > > these.
> now
> > fulltime),after
> > (better
> empty
another
in
rigs
> > now.
> > > Their web site is
> > > catconproducts.com
to
> > get
> > > Bob Lawrence
> > > 84 PT36
02-18-2008, 04:29
http://www.catconproducts.com
Bob
> Gardner
> 78FC33
> checking
> > them out.
> for
> > the sensors.
> > Bob
> > > Bob,
> (like
> > > Gardner
> > > 78FC33
> > > wrote:
> > > > Hi group,
tank
> are
> > ownership
> > reading.
> Prevost
> > > and
> > > > Newell sites.
> > > sidewall
sensor
> required
> > silicone
> stainless
> sidewall.
> > I
> tighten
> > > by
> > > > hand.
> flat
> > wire
> monitor
> > > can
need
> > for
> > > > these.
months
> > now
> > > fulltime),after
> > > (better
> > empty
> another
> in
> rigs
> > > now.
> > > > Their web site is
> > > > catconproducts.com
pressure
> to
> > > get
> > > > Bob Lawrence
> > > > 84 PT36
02-18-2008, 05:07
Bob,
Please provide us with the part descriptions/numbers that you used. Thanks.
Bob
> Gardner
> 78FC33
> --- In "WanderlodgeForum%40yahoogroups.com", "Bob Lawrence"
> checking
> > them out.
> for
> > the sensors.
> > Bob
> > > Bob,
> (like
> > > Gardner
> > > 78FC33
> > > wrote:
> > > > Hi group,
tank
> are
> > ownership
> > reading.
> Prevost
> > > and
> > > > Newell sites.
> > > sidewall
sensor
> required
> > silicone
> stainless
> sidewall.
> > I
> tighten
> > > by
> > > > hand.
> flat
> > wire
> monitor
> > > can
need
> > for
> > > > these.
months
> > now
> > > fulltime),after
> > > (better
> > empty
> another
> in
> rigs
> > > now.
> > > > Their web site is
> > > > catconproducts.com
pressure
> to
> > > get
> > > > Bob Lawrence
> > > > 84 PT36
Curt Sprenger
Anaheim Hills, CA
02-18-2008, 06:07
Hi,
Item # 500-00050-35 Micropulse System monitor without voice
Item # 500-10050-05 Micropulse tank sensor
> Bob
Thanks.
> > Bob
> > > Gardner
> > > 78FC33
> > > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Bob Lawrence"
> > > checking
> > > > them out.
ea.
> > > for
> > > > the sensors.
> > > > Bob
> > > > > Bob,
> > > (like
> > > > > Gardner
> > > > > 78FC33
> > "Bob Lawrence"
> > > > > wrote:
> > > > > > Hi group,
> > tank
with
> > > are
> > > > ownership
> > > > reading.
> > > Prevost
> > > > > and
> > > > > > Newell sites.
> > > > > sidewall
> > sensor
> > > required
> > > > silicone
> > > stainless
> > > sidewall.
> > > > I
> > > tighten
> > > > > by
> > > > > > hand.
> > > flat
> > > > wire
> > > monitor
> > > > > can
> > need
> > > > for
> > > > > > these.
> > months
> > > > now
> > > > > fulltime),after
it!!
tank
> > > > > (better
> > > > empty
> > > another
areas
> > > in
end
> > > rigs
> > > > > now.
> > > > > > Their web site is
> > > > > > catconproducts.com
> > pressure
> > > to
> > > > > get
cleaning.
> > > > > > Bob Lawrence
> > > > > > 84 PT36
> Curt Sprenger
> Anaheim Hills, CA
