88 pt 40 how many alternators?
11-17-2007, 10:29
I was just cleaning up the engine after my recent coolant valve repairs
and noticed a belt hanging way up in front of the engine. It appears
that the alternator belt or belts are broken and off. This alternator
is up high in front of the motor and although easy to see looks quite
difficult to access for the belt repair. Are there two alternators?
What is the best method for this repair?
Robert Rahn
1988 pt 40
Warner Robins, Ga
11-17-2007, 10:40
Should be a metal plate under the bed, directly above that alternator. About a
zillion screws around the outside - oh the joys of modern power screwdrivers!
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
>Robert Rahn
>1988 pt 40
>Warner Robins, Ga
11-17-2007, 10:43
Robert, My 89 PT 40 had two alternators. The one you are seeing on
top of the motor can be accessed easily from a trap door under the
bed. The other alternator is on the passenger side of the coach at the
back of the bus. Look to the inside of the frame rail and you will see
it roughly under the ac compressor. It is actually harder to service
that the upper unit. Mike Mcmahan 96 PT 42
--- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn"
repairs
> Robert Rahn
> 1988 pt 40
> Warner Robins, Ga
11-17-2007, 18:57
Mike and Don have given you the spoken truth. I and Randy Dupree have done
this several times. As Don says the trap door is there so go for it. Cover
all surfaces, especially the bed OK. While in there replace the lines to the
compressor. Curt will chime in here with more expertise. He and Randy are
the experienced guys on these two lines. Believe me when I say those two
lines are failing and this is your chance to save yourself $20K.
> About a zillion screws around the outside - oh the joys of modern power
> screwdrivers!
> Don Bradner
> Eureka, CA
> >Robert Rahn
> >1988 pt 40
> >Warner Robins, Ga
Rob, Sue & Merlin Robinson
94 WLWB
11-17-2007, 19:11
The way I read Randy's post about the compressor coolant line, I thought it was
necessary to access from below. You are saying it is accessible from above?
Where should I look, in relation to looking down right above the alternator?
Having replaced that alternator I have no problems with accessing things through
that hole.
>the
>> screwdrivers!
>> Don Bradner
>> Eureka, CA
>> >Robert Rahn
>> >1988 pt 40
>> >Warner Robins, Ga
>94 WLWB
>Yahoo! Groups Links
11-17-2007, 19:27
Don first of all I'm fwding your email directly to Randy OK. Secondly there
are two lines to the compressor. The end of one is easily accessible from
the trap door we are talking about. The rest of the story is another
question. The second line comes from below and over the top of the engine.
Both Randy and Curt Sprenger have done this job and it is not for the
layman. I don't want the scare you but this is a real concern for any BB
over ten years old. Last week Randy had a fellow drop by and while he
pointed out the two problem hoses (gentle nudge) the whole f$#king thing
fell apart, coolant shower and Randy had a two day job instead of the planed
3 hour tune up. Everyone of you out there should be checking these coolant
lines.
> it was necessary to access from below. You are saying it is accessible from
> above? Where should I look, in relation to looking down right above the
> alternator? Having replaced that alternator I have no problems with
> accessing things through that hole.
> done
> Cover
> >the
> >> screwdrivers!
> >> Don Bradner
> >> Eureka, CA
> repairs
> >> >Robert Rahn
> >> >1988 pt 40
> >> >Warner Robins, Ga
> >94 WLWB
> >Yahoo! Groups Links
94 WLWB
11-17-2007, 21:12
Robert my mistake on identities. My apologies. The info I provided stands
and if it was my rig I'd replace them both. I am not fooling with you or
anyone on this issue. We are warning you about a possible major engine
failure so please, as a minimum, check the lines, or better replace them..
> Robert Rahn
> 1988 pt 40
> Warner Robins, Ga
94 WLWB
11-17-2007, 22:04
Mike...can you describe how you replaced these coolant lines on the road.
Did you remove the starter? etc. thanks Jim Barone 1991WLWB in Tubac AZ.
************************************** See what's new at http://www.aol.com
11-18-2007, 01:58
Okay so I access the alternator from the hole under the bed. Sounds
great. What are the compressor lines? There is a compressor in the
cooling system? Sounds like the lines will fail and cause the engine
problems then that is the 20 thousand dollars? Im sold for sure, but
where do I get these lines, coachworks?
Robert Rahn
1988 pt 40
Warner Robins. Ga.
In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
Secondly there
accessible from
engine.
any BB
he
thing
the planed
coolant
> lines.
I thought
accessible from
above the
with
have
> > done
it.
> > Cover
lines to
> > >the
Randy are
those two
> > >On 17/11/2007, Don Bradner 40arcatapet.com>>
alternator.
modern power
> > >> screwdrivers!
> > >> Don Bradner
> > >> Eureka, CA
valve
> > repairs
appears
alternator
looks quite
alternators?
> > >> >Robert Rahn
> > >> >1988 pt 40
> > >> >Warner Robins, Ga
> > >94 WLWB
> > >Yahoo! Groups Links
> 94 WLWB
11-18-2007, 02:51
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
wrote
When I replace the cooling lines on the air compressor I was not
able to reach them from the top.Had to do the job from below and
under the coach useing a off set 7/8 open end wrench.Yes it is a
nasty dirty job one that needs to be done on the older birds.
Bob Loomas 1985 PT 36
have done
it. Cover
lines to the
Randy are
those two
alternator.
modern power
> > screwdrivers!
> > Don Bradner
> > Eureka, CA
repairs
appears
alternator
quite
alternators?
> > >Robert Rahn
> > >1988 pt 40
> > >Warner Robins, Ga
> 94 WLWB
User(s) browsing this thread: 10 Guest(s)
