					water heater replacment
					10-14-2007, 12:59
					I've replaced my water heater with a Seaward...they are local here in So  Cal
			(Whittier), and easy to deal with. Their heater is a 11 gallon replacement, unlike the 10 gallon original, but the same size. High quality, marine grade.... _www.seawardproducts.com_ (http://www.seawardproducts.com) Good luck.... Kevin McKeown Yorba Linda, CA 1986 38' PT (For Sale) ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed]  |
					10-14-2007, 15:03
					I was able to get back to the water heater and check for leaks. It is
			not leaking out of the pressure relief valve and there is no leaking at any of the pipes. It is a little wet way back at the corner back there which must be directly above the hole where the water is dripping out. I turned the water heater off a few days ago and water is still dripping slowly out of the hole in the engine compartment. So the water heater must be rusted out and the leak is coming from below it. Where is the best place to buy one of these heaters and what is the best way to remove it? It looks like it is going to be quite a chore to get it out of there. Robert Rahn Kalispell, Mt. 1988 PT 40  |
					10-14-2007, 15:15
					When I had to replace my Seaward I chose a Force Ten because they copied the
			basic Seaward design and improved upon it (larger diameter piping, stainless cover). I found the pricing good also. Google Force Ten for sales and here's their site address http://www.force10.com/heater.html On 14/10/2007, Robert & Teri Rahn > > I was able to get back to the water heater and check for leaks. It is > not leaking out of the pressure relief valve and there is no leaking at > any of the pipes. It is a little wet way back at the corner back there > which must be directly above the hole where the water is dripping out. > I turned the water heater off a few days ago and water is still > dripping slowly out of the hole in the engine compartment. So the water > heater must be rusted out and the leak is coming from below it. Where > is the best place to buy one of these heaters and what is the best way > to remove it? It looks like it is going to be quite a chore to get it > out of there. > > Robert Rahn > Kalispell, Mt. > 1988 PT 40 > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed]  |
					10-14-2007, 15:46
					Or dupreeproducts.com
			Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > When I had to replace my Seaward I chose a Force Ten because they copied the > basic Seaward design and improved upon it (larger diameter piping, stainless > cover). I found the pricing good also. Google Force Ten for sales and here's > their site address http://www.force10.com/heater.html > > On 14/10/2007, Robert & Teri Rahn > > > > I was able to get back to the water heater and check for leaks. It is > > not leaking out of the pressure relief valve and there is no leaking at > > any of the pipes. It is a little wet way back at the corner back there > > which must be directly above the hole where the water is dripping out. > > I turned the water heater off a few days ago and water is still > > dripping slowly out of the hole in the engine compartment. So the water > > heater must be rusted out and the leak is coming from below it. Where > > is the best place to buy one of these heaters and what is the best way > > to remove it? It looks like it is going to be quite a chore to get it > > out of there. > > > > Robert Rahn > > Kalispell, Mt. > > 1988 PT 40 > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] >  |
					10-14-2007, 15:51
					Opps sorry Stephen . I didn't know you  handled Force Ten
			On 14/10/2007, Stephen Birtles > > Or dupreeproducts.com > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > When I had to replace my Seaward I chose a Force Ten because they > copied the > > basic Seaward design and improved upon it (larger diameter piping, > stainless > > cover). I found the pricing good also. Google Force Ten for sales > and here's > > their site address http://www.force10.com/heater.html > > > > On 14/10/2007, Robert & Teri Rahn > > > > > > I was able to get back to the water heater and check for leaks. > It is > > > not leaking out of the pressure relief valve and there is no > leaking at > > > any of the pipes. It is a little wet way back at the corner back there > > > which must be directly above the hole where the water is dripping out. > > > I turned the water heater off a few days ago and water is still > > > dripping slowly out of the hole in the engine compartment. So the > water > > > heater must be rusted out and the leak is coming from below it. Where > > > is the best place to buy one of these heaters and what is the best way > > > to remove it? It looks like it is going to be quite a chore to get it > > > out of there. > > > > > > Robert Rahn > > > Kalispell, Mt. > > > 1988 PT 40 > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed]  |
					10-14-2007, 20:38
					Having R&R'd my hot water heater too many times to mention (I'm trying  to
			forget), I bet a round water heater would sure be a lot easier to install. Even though I've done mine a few times, I get heart palpitations when I think about having to do it again....for me, it's like trying to solve a Rubik Cube, or trying to put 50 lbs of sand into a 5 pound bag. You have my sympathy.... Kevin Mc YL CA 1986 38' PT (For Sale) ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed]  |
					10-14-2007, 23:27
					And Raritan
			the difference between the 2 is Force ten is square and Raritan is round to cover all the coaches through out the years Stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Opps sorry Stephen . I didn't know you handled Force Ten > > On 14/10/2007, Stephen Birtles > > > > Or dupreeproducts.com > > Stephen 77fc35 > > > > --- In WanderlodgeForum@yahoogroups.com > > "Rob Robinson" > > > > > > > > When I had to replace my Seaward I chose a Force Ten because they > > copied the > > > basic Seaward design and improved upon it (larger diameter piping, > > stainless > > > cover). I found the pricing good also. Google Force Ten for sales > > and here's > > > their site address http://www.force10.com/heater.html > > > > > > On 14/10/2007, Robert & Teri Rahn > > > > > > > > I was able to get back to the water heater and check for leaks. > > It is > > > > not leaking out of the pressure relief valve and there is no > > leaking at > > > > any of the pipes. It is a little wet way back at the corner back there > > > > which must be directly above the hole where the water is dripping out. > > > > I turned the water heater off a few days ago and water is still > > > > dripping slowly out of the hole in the engine compartment. So the > > water > > > > heater must be rusted out and the leak is coming from below it. Where > > > > is the best place to buy one of these heaters and what is the best way > > > > to remove it? It looks like it is going to be quite a chore to get it > > > > out of there. > > > > > > > > Robert Rahn > > > > Kalispell, Mt. > > > > 1988 PT 40 > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Rob, Sue & Merlin Robinson > > > 94 WLWB > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] >  |
					10-15-2007, 03:38
					Kevin:
			You should have a FC, mine was very easy to replace, well depends what you call easy, I took out the water tank, furnace and then the hot water tank, See it was simple. LOL Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: "krminyl@..." To: WanderlodgeForum@yahoogroups.com Sent: Monday, October 15, 2007 5:38:57 AM Subject: Re: [WanderlodgeForum] Re: water heater replacment Having R&R'd my hot water heater too many times to mention (I'm trying to forget), I bet a round water heater would sure be a lot easier to install. Even though I've done mine a few times, I get heart palpitations when I think about having to do it again....for me, it's like trying to solve a Rubik Cube, or trying to put 50 lbs of sand into a 5 pound bag. You have my sympathy.... Kevin Mc YL CA 1986 38' PT (For Sale) ************ ********* ********* ******** See what's new at http://www.aol. com [Non-text portions of this message have been removed] Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail at http://mrd.mail.yahoo.com/try_beta?.intl=ca [Non-text portions of this message have been removed]  |
					10-15-2007, 05:26
					Robert,
			One of the first projects on my PT-40 after purchasing last July was to replace the leaking water heater. While I knew there was a leak, the damage was hidden and not easy to identify. When I pulled apart the water heater shelf area, there was softness in the wood below. So it was clear that it had been sitting wet for a long time. In my case, I decided to do a total bed/rear decking replacement. I spread the work out over a week. My queen bed is centered and against the rear cabinets. I used the Atwood EHM11SST tank to replace the original. It has all the connections on one side and stainless steel housing. You can find them for around $425 if you shop. On the '86 PT-40, there are two pieces of wood on top of the engine housing. One goes from the queen all the way to the rear under the cabinets. It has a cut out for an access door to the engine compartment. The wood is on top of a small felt pad which is on top of the steel engine housing. You should pull the wood over the engine access door to determine if the felt pad underneath has any moisture. If it does, it will be trapped between the wood and the steel and never escape. Eventually you will have mold and dry-rot. If this pad is dry...you are a step ahead. I removed all the rear cabinets below the overhead. The overhead is self supporting and can remain. There is a heat exchange in the center-bottom of the cabinets that is used for bedroom heat. I did not remove the heat-exchanger, but I did remove the screws holding it down and removed the wood from under it. This kept me from having to undo the hot water hoses from the engine. I might be easier to remove it if you have to. Hopefully, when you remove the HWH, you will not have had any water get under the wood. If you did, and it is contained to just one local area, you could possibly cut out the damaged section and leave the remaining. In my case, I wanted to be sure I got out all the moisture so I removed everything. I touched up the steel housing (a few scratches). Sealed all the existing screw holes from the old plywood mount holes. Put down a thin foil insulation pad. Then put down the plywood. I pre-drilled each hole through the wood / engine housing and attached the new wood with stainless steel screws. Take plenty of pictures to remember how it goes back together if you have to disassemble anything. There are a lot of very similar parts in removing the cabinets, that took me a few extra minutes to remember how to get it back together...however it will only go back one way. The best choice for wood in my opinion is a Marine Grade Plywood. Expensive, but it has glues that will not break down to water exposure. You can special order it through Lowes here in my town. Another choice that might be OK would be to use a copper based pressure treated plywood. Do not use the arsenic based wood, unless you want to expose someone to the arsenic  .When I put the wood back down, I did it in three sections. One section was the width of the coach, and went from the back wall to about one inch forward of the rear cabinet wall (just about 1/2 inch to the rear of the engine access door). Then I put a piece to the left of the access door and another piece to the right of the access door. I used 3/4" plywood. I also put down new wood for the access door. For it, I used a 1/2" piece because the steel access door is raised about 1/4" from the rest of the housing. Hopefully in your case, you won't have to remove any of the decking. Be sure that no water has gotten between the wood and the steel housing. If that happens, it will not be apparent by looking at the top of the wood, but hidden problems will arise over time. If you don't have to replace any wood and not remove the cabinets, 1 day should be no problem. It will be tight getting the HWH out and the new one back in, but it will fit through the door opening. You will need to remove the door and the shelving/panel above, in the rear, and to the driver's side of the HWH to make it easier. I tried to find a pan to put under the HWH but could not find one to fit. I still would like to custom make a pan and set it under the HWH and have a drain out the rear through the engine compartment in case of a leak. I did use 3M 4200 marine caulking to seal the seams to prevent water penetration. The biggest thing you will need is moral support if you have to pull it all apart. My old body complained for a few days afterwards from all the bending and weird positions required to remove the rear cabinets. Glenn Allen 1986 PT-40 Marietta, GA --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > I was able to get back to the water heater and check for leaks. It is > not leaking out of the pressure relief valve and there is no leaking at > any of the pipes. It is a little wet way back at the corner back there > which must be directly above the hole where the water is dripping out. > I turned the water heater off a few days ago and water is still > dripping slowly out of the hole in the engine compartment. So the water > heater must be rusted out and the leak is coming from below it. Where > is the best place to buy one of these heaters and what is the best way > to remove it? It looks like it is going to be quite a chore to get it > out of there. > > Robert Rahn > Kalispell, Mt. > 1988 PT 40 >  |
					10-15-2007, 05:38
					Glen, nice write up. Please add this to the forum so others can locate it
			when in need. On 10/15/07, ragster_ga > > Robert, > > One of the first projects on my PT-40 after purchasing last July was > to replace the leaking water heater. While I knew there was a leak, > the damage was hidden and not easy to identify. When I pulled apart > the water heater shelf area, there was softness in the wood below. > So it was clear that it had been sitting wet for a long time. > > In my case, I decided to do a total bed/rear decking replacement. I > spread the work out over a week. My queen bed is centered and > against the rear cabinets. > > I used the Atwood EHM11SST tank to replace the original. It has all > the connections on one side and stainless steel housing. You can > find them for around $425 if you shop. > > On the '86 PT-40, there are two pieces of wood on top of the engine > housing. One goes from the queen all the way to the rear under the > cabinets. It has a cut out for an access door to the engine > compartment. The wood is on top of a small felt pad which is on top > of the steel engine housing. > > You should pull the wood over the engine access door to determine if > the felt pad underneath has any moisture. If it does, it will be > trapped between the wood and the steel and never escape. Eventually > you will have mold and dry-rot. If this pad is dry...you are a step > ahead. > > I removed all the rear cabinets below the overhead. The overhead is > self supporting and can remain. There is a heat exchange in the > center-bottom of the cabinets that is used for bedroom heat. I did > not remove the heat-exchanger, but I did remove the screws holding it > down and removed the wood from under it. This kept me from having to > undo the hot water hoses from the engine. I might be easier to > remove it if you have to. > > Hopefully, when you remove the HWH, you will not have had any water > get under the wood. If you did, and it is contained to just one > local area, you could possibly cut out the damaged section and leave > the remaining. > > In my case, I wanted to be sure I got out all the moisture so I > removed everything. I touched up the steel housing (a few > scratches). Sealed all the existing screw holes from the old plywood > mount holes. Put down a thin foil insulation pad. Then put down the > plywood. I pre-drilled each hole through the wood / engine housing > and attached the new wood with stainless steel screws. > > Take plenty of pictures to remember how it goes back together if you > have to disassemble anything. There are a lot of very similar parts > in removing the cabinets, that took me a few extra minutes to > remember how to get it back together...however it will only go back > one way. > > The best choice for wood in my opinion is a Marine Grade Plywood. > Expensive, but it has glues that will not break down to water > exposure. You can special order it through Lowes here in my town. > > Another choice that might be OK would be to use a copper based > pressure treated plywood. Do not use the arsenic based wood, unless > you want to expose someone to the arsenic  .> > When I put the wood back down, I did it in three sections. One > section was the width of the coach, and went from the back wall to > about one inch forward of the rear cabinet wall (just about 1/2 inch > to the rear of the engine access door). Then I put a piece to the > left of the access door and another piece to the right of the access > door. I used 3/4" plywood. I also put down new wood for the access > door. For it, I used a 1/2" piece because the steel access door is > raised about 1/4" from the rest of the housing. > > Hopefully in your case, you won't have to remove any of the decking. > Be sure that no water has gotten between the wood and the steel > housing. If that happens, it will not be apparent by looking at the > top of the wood, but hidden problems will arise over time. > > If you don't have to replace any wood and not remove the cabinets, 1 > day should be no problem. It will be tight getting the HWH out and > the new one back in, but it will fit through the door opening. You > will need to remove the door and the shelving/panel above, in the > rear, and to the driver's side of the HWH to make it easier. > > I tried to find a pan to put under the HWH but could not find one to > fit. I still would like to custom make a pan and set it under the > HWH and have a drain out the rear through the engine compartment in > case of a leak. I did use 3M 4200 marine caulking to seal the seams > to prevent water penetration. > > The biggest thing you will need is moral support if you have to pull > it all apart. My old body complained for a few days afterwards from > all the bending and weird positions required to remove the rear > cabinets. > > Glenn Allen > 1986 PT-40 > Marietta, GA > > --- In WanderlodgeForum@yahoogroups.com > "Robert & Teri Rahn" > > > > > I was able to get back to the water heater and check for leaks. It > is > > not leaking out of the pressure relief valve and there is no > leaking at > > any of the pipes. It is a little wet way back at the corner back > there > > which must be directly above the hole where the water is dripping > out. > > I turned the water heater off a few days ago and water is still > > dripping slowly out of the hole in the engine compartment. So the > water > > heater must be rusted out and the leak is coming from below it. > Where > > is the best place to buy one of these heaters and what is the best > way > > to remove it? It looks like it is going to be quite a chore to get > it > > out of there. > > > > Robert Rahn > > Kalispell, Mt. > > 1988 PT 40 > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed]  |
