Winter & electric heaters
08-19-2007, 07:57
Thanks folks for all of the replies to my winter living questions.
I'll post some follow-ups in that thread, but I wanted to start a new one on the electric heaters. My coach has the Fasco model 2450 toe heaters. All three of 'em are shot as far as I'm concerned. They produce heat but the blowers are weak and very noisy. Lots of buzzing and very little air movement. I'd like to replace all three, but I'm not finding them for sale. In other brands, I'm not finding anything with 2000 watts @ 120 volt like these. Are these still for sale anywhere, or is there a cross reference? The PerfectToe heaters mentioned might work, but they're half the wattage and smaller in size so I'd have to rig up some framing and that doesn't sound like fun. Thanks for any advice! At least my propane heaters all work fine, so I won't be SOL if I don't get these electrics replaced, but I'd rather not be driving out to buy propane every week if I can help it. -Ryan '86 PT-40 8V92 Tri-Cities, WA |
08-19-2007, 09:55
Ryan, those heaters have a screw on them that allow for a thermostat change.
That might enable them to run longer. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-19-2007, 13:48
Ryan,
I'd pull out one of the electric heaters and fiddle with it. You might find they can be brought back to life. Keep in mind that they do not put out high air flow, actually a slight air flow seems about right. Others that have fiddeled with these heaters will chime in. Good luck. On 8/19/07, Ryan Wright > > Thanks folks for all of the replies to my winter living questions. > I'll post some follow-ups in that thread, but I wanted to start a new > one on the electric heaters. > > My coach has the Fasco model 2450 toe heaters. All three of 'em are > shot as far as I'm concerned. They produce heat but the blowers are > weak and very noisy. Lots of buzzing and very little air movement. I'd > like to replace all three, but I'm not finding them for sale. In other > brands, I'm not finding anything with 2000 watts @ 120 volt like > these. > > Are these still for sale anywhere, or is there a cross reference? The > PerfectToe heaters mentioned might work, but they're half the wattage > and smaller in size so I'd have to rig up some framing and that > doesn't sound like fun. > > Thanks for any advice! At least my propane heaters all work fine, so I > won't be SOL if I don't get these electrics replaced, but I'd rather > not be driving out to buy propane every week if I can help it. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
08-20-2007, 08:55
When I was researching the toe heaters, I only found the Perfect Toe
and (I memory isn't that clear) perhaps another brand with very similar specs. I didn't see any as high as 2000 watts. I can say that the 1000 watts from the Perfect Toe was able to provide plenty of heat on cool mornings, even in very cool temperatures (20s and 30s). The volume of air moving is quite evident. (Our cat likes to sit across from it when it's on.) While we also have the AquaHot for heat, when in an RV park we prefer to maximize use of electricity instead of the diesel used for the AquaHot. At worst, we'd run the AquaHot, to bring up the temperature of the forward area, then shut it off leaving the single Perfect Toe under the galley to maintain the temperature -- which it did reasonably well. I will say that the fan in the Perfect Toe is noticeable -- it's a miniature squirrel cage -- and there's plenty of "whooshing" noise when it is running. (Then, again, the AquaHot unit fan under the kitchen (next to the Perfect Toe) is pretty noisy, too...) I'll note that I've not seen many 120 vac electric heaters of any type much above 1500-1600 watts. Higher wattage units tend to be 230 vac. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 19, 2007, at 1:57 PM, Ryan Wright wrote: > Thanks folks for all of the replies to my winter living questions. > I'll post some follow-ups in that thread, but I wanted to start a new > one on the electric heaters. > > My coach has the Fasco model 2450 toe heaters. All three of 'em are > shot as far as I'm concerned. They produce heat but the blowers are > weak and very noisy. Lots of buzzing and very little air movement. I'd > like to replace all three, but I'm not finding them for sale. In other > brands, I'm not finding anything with 2000 watts @ 120 volt like > these. > > Are these still for sale anywhere, or is there a cross reference? The > PerfectToe heaters mentioned might work, but they're half the wattage > and smaller in size so I'd have to rig up some framing and that > doesn't sound like fun. > > Thanks for any advice! At least my propane heaters all work fine, so I > won't be SOL if I don't get these electrics replaced, but I'd rather > not be driving out to buy propane every week if I can help it. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > > > Yahoo! Groups Links > > > |
08-21-2007, 05:01
From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 20, 2007 3:55 PM Subject: Re: [WanderlodgeForum] Winter & electric heaters ----- Original Message ----- Grainger have about any toe heater or wall heater that you will need Bob Loomas 1985 PT 36 When I was researching the toe heaters, I only found the Perfect Toe and (I memory isn't that clear) perhaps another brand with very similar specs. I didn't see any as high as 2000 watts. I can say that the 1000 watts from the Perfect Toe was able to provide plenty of heat on cool mornings, even in very cool temperatures (20s and 30s). The volume of air moving is quite evident. (Our cat likes to sit across from it when it's on.) While we also have the AquaHot for heat, when in an RV park we prefer to maximize use of electricity instead of the diesel used for the AquaHot. At worst, we'd run the AquaHot, to bring up the temperature of the forward area, then shut it off leaving the single Perfect Toe under the galley to maintain the temperature -- which it did reasonably well. I will say that the fan in the Perfect Toe is noticeable -- it's a miniature squirrel cage -- and there's plenty of "whooshing" noise when it is running. (Then, again, the AquaHot unit fan under the kitchen (next to the Perfect Toe) is pretty noisy, too...) I'll note that I've not seen many 120 vac electric heaters of any type much above 1500-1600 watts. Higher wattage units tend to be 230 vac. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 19, 2007, at 1:57 PM, Ryan Wright wrote: > Thanks folks for all of the replies to my winter living questions. > I'll post some follow-ups in that thread, but I wanted to start a new > one on the electric heaters. > > My coach has the Fasco model 2450 toe heaters. All three of 'em are > shot as far as I'm concerned. They produce heat but the blowers are > weak and very noisy. Lots of buzzing and very little air movement. I'd > like to replace all three, but I'm not finding them for sale. In other > brands, I'm not finding anything with 2000 watts @ 120 volt like > these. > > Are these still for sale anywhere, or is there a cross reference? The > PerfectToe heaters mentioned might work, but they're half the wattage > and smaller in size so I'd have to rig up some framing and that > doesn't sound like fun. > > Thanks for any advice! At least my propane heaters all work fine, so I > won't be SOL if I don't get these electrics replaced, but I'd rather > not be driving out to buy propane every week if I can help it. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
08-22-2007, 07:31
Thanks for the replies, folks. I dug into the heaters and the heating
elements & fans are actually working fine now that they've been vacuumed out. The thermostats on two of them are flaky, though. I'm going to see about bypassing the cheap, built in thermostats with a relay and putting together a zoned HVAC control system where I can use setpoints, etc from a proper thermostat. It does look like these are it as far as high wattage heaters go. These aren't made anymore and nobody else makes 120 volt heaters anywhere near 2000w, not that I can find, anyway. So, for those of us with the eighties coaches, take care of these heaters, because when you have to replace 'em you're going to lose 500-1000 watts of heating potential per heater. -Ryan '86 PT-40 8V92 Tri-Cities, WA On 8/19/07, Curt Sprenger > > Ryan, > > I'd pull out one of the electric heaters and fiddle with it. You might find > they can be brought back to life. Keep in mind that they do not put out high > air flow, actually a slight air flow seems about right. Others that have > fiddeled with these heaters will chime in. Good luck. > |
