					Anyone ever use POR-15?
					07-21-2007, 15:07
					Did u use the etcher the POR company sells?
			--- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Not that I'm aware of. The phosphoric acid etcher does do a > number on aluminum. > > David Brady > '02 LXi, Smokey > NC > > Scott Forman wrote: > > > > Is there anything to keep it away from (electrical, etc)? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > Definitely brush it on, just wear gloves and don't get any on your > > > hands. After it self-levels it'll look like you sprayed it. The > > final > > > finish is very similar to powder coating in appearance and > > toughness. > > > Those foam/sponge brushes are best, cheap bristle brushes leave > > > bristles in the paint. > > > > > > David Brady > > > '02 LXi, Smokey > > > NC > > > > > > Scott Forman wrote: > > > > > > > > Did u spray or brush it on? Is it very messy or about like any > > other > > > > paint? > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > <MHOHNSTEIN@> wrote: > > > > > > > > > > Yup, it's good stuff. Used it many times to fix on older truck > > > > frames, resulting in serious value adding to the end product. > > > > > MH > > > > > ----- Original Message ----- > > > > > From: Leroy Eckert > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Sent: Saturday, July 21, 2007 8:25 PM > > > > > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > > > > > > > > I have used POR-15 for years. It is a great product. It flows > > out > > > > nicely. You can paint over rust ( POR )or paint without the rust > > if > > > > you Ospho, sandblast or etch steel. It needs something to bite. > > If it > > > > is exposed to sunlight, it needs to be topcoated. I'll guarantee > > it > > > > will never rust again if applied properly. > > > > > Leroy Eckert > > > > > 1990 WB-40"Smoke N Mirrors" > > > > > Niceville, FL > > > > > Royale Conversion > > > > > ----- Original Message ----- > > > > > From: Scott Forman > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Sent: Saturday, July 21, 2007 8:07 PM > > > > > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > > > Seems like a good product in design, wondering if it works. > > > > Wanting to > > > > > address surface oxidation under my bus. Anyone use it or know > > > > another > > > > > better product? > > > > > > > > > > Scott Forman > > > > > 86 PT38 > > > > > With a cruddy underside > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > ------ > > > > > > > > No virus found in this incoming message. > > > > Checked by AVG Free Edition. > > > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: > > 7/20/2007 4:39 PM > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007 4:39 PM > > > > > > [Non-text portions of this message have been removed] >  |
					07-21-2007, 15:09
			number on aluminum. David Brady '02 LXi, Smokey NC Scott Forman wrote: > > Is there anything to keep it away from (electrical, etc)? > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > Definitely brush it on, just wear gloves and don't get any on your > > hands. After it self-levels it'll look like you sprayed it. The > final > > finish is very similar to powder coating in appearance and > toughness. > > Those foam/sponge brushes are best, cheap bristle brushes leave > > bristles in the paint. > > > > David Brady > > '02 LXi, Smokey > > NC > > > > Scott Forman wrote: > > > > > > Did u spray or brush it on? Is it very messy or about like any > other > > > paint? > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > <MHOHNSTEIN@> wrote: > > > > > > > > Yup, it's good stuff. Used it many times to fix on older truck > > > frames, resulting in serious value adding to the end product. > > > > MH > > > > ----- Original Message ----- > > > > From: Leroy Eckert > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > Sent: Saturday, July 21, 2007 8:25 PM > > > > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > > > > > I have used POR-15 for years. It is a great product. It flows > out > > > nicely. You can paint over rust ( POR )or paint without the rust > if > > > you Ospho, sandblast or etch steel. It needs something to bite. > If it > > > is exposed to sunlight, it needs to be topcoated. I'll guarantee > it > > > will never rust again if applied properly. > > > > Leroy Eckert > > > > 1990 WB-40"Smoke N Mirrors" > > > > Niceville, FL > > > > Royale Conversion > > > > ----- Original Message ----- > > > > From: Scott Forman > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > Sent: Saturday, July 21, 2007 8:07 PM > > > > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > Seems like a good product in design, wondering if it works. > > > Wanting to > > > > address surface oxidation under my bus. Anyone use it or know > > > another > > > > better product? > > > > > > > > Scott Forman > > > > 86 PT38 > > > > With a cruddy underside > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > ---------------------------------------------------------- > ------ > > > > > > No virus found in this incoming message. > > > Checked by AVG Free Edition. > > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: > 7/20/2007 4:39 PM > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007 4:39 PM > [Non-text portions of this message have been removed]  |
					07-21-2007, 15:14
					Yup, Good night already!
			David Brady '02 LXi, Smokey NC David Brady wrote: > > Not that I'm aware of. The phosphoric acid etcher does do a > number on aluminum. > > David Brady > '02 LXi, Smokey > NC > > Scott Forman wrote: > > > > Is there anything to keep it away from (electrical, etc)? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > wrote: > > > > > > Definitely brush it on, just wear gloves and don't get any on your > > > hands. After it self-levels it'll look like you sprayed it. The > > final > > > finish is very similar to powder coating in appearance and > > toughness. > > > Those foam/sponge brushes are best, cheap bristle brushes leave > > > bristles in the paint. > > > > > > David Brady > > > '02 LXi, Smokey > > > NC > > > > > > Scott Forman wrote: > > > > > > > > Did u spray or brush it on? Is it very messy or about like any > > other > > > > paint? > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > <MHOHNSTEIN@> wrote: > > > > > > > > > > Yup, it's good stuff. Used it many times to fix on older truck > > > > frames, resulting in serious value adding to the end product. > > > > > MH > > > > > ----- Original Message ----- > > > > > From: Leroy Eckert > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > Sent: Saturday, July 21, 2007 8:25 PM > > > > > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > > > > > > > > I have used POR-15 for years. It is a great product. It flows > > out > > > > nicely. You can paint over rust ( POR )or paint without the rust > > if > > > > you Ospho, sandblast or etch steel. It needs something to bite. > > If it > > > > is exposed to sunlight, it needs to be topcoated. I'll guarantee > > it > > > > will never rust again if applied properly. > > > > > Leroy Eckert > > > > > 1990 WB-40"Smoke N Mirrors" > > > > > Niceville, FL > > > > > Royale Conversion > > > > > ----- Original Message ----- > > > > > From: Scott Forman > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > Sent: Saturday, July 21, 2007 8:07 PM > > > > > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > > > Seems like a good product in design, wondering if it works. > > > > Wanting to > > > > > address surface oxidation under my bus. Anyone use it or know > > > > another > > > > > better product? > > > > > > > > > > Scott Forman > > > > > 86 PT38 > > > > > With a cruddy underside > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > ------ > > > > > > > > No virus found in this incoming message. > > > > Checked by AVG Free Edition. > > > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: > > 7/20/2007 4:39 PM > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ---------------------------------------------------------- > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: > 7/20/2007 4:39 PM > > > > [Non-text portions of this message have been removed] > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007 4:39 PM > [Non-text portions of this message have been removed]  |
					07-21-2007, 15:14
					What can I say, I like the nightlife!
			--- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Yup, Good night already! > > David Brady > '02 LXi, Smokey > NC > > David Brady wrote: > > > > Not that I'm aware of. The phosphoric acid etcher does do a > > number on aluminum. > > > > David Brady > > '02 LXi, Smokey > > NC > > > > Scott Forman wrote: > > > > > > Is there anything to keep it away from (electrical, etc)? > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > wrote: > > > > > > > > Definitely brush it on, just wear gloves and don't get any on your > > > > hands. After it self-levels it'll look like you sprayed it. The > > > final > > > > finish is very similar to powder coating in appearance and > > > toughness. > > > > Those foam/sponge brushes are best, cheap bristle brushes leave > > > > bristles in the paint. > > > > > > > > David Brady > > > > '02 LXi, Smokey > > > > NC > > > > > > > > Scott Forman wrote: > > > > > > > > > > Did u spray or brush it on? Is it very messy or about like any > > > other > > > > > paint? > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Hohnstein" > > > > > <MHOHNSTEIN@> wrote: > > > > > > > > > > > > Yup, it's good stuff. Used it many times to fix on older truck > > > > > frames, resulting in serious value adding to the end product. > > > > > > MH > > > > > > ----- Original Message ----- > > > > > > From: Leroy Eckert > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > Sent: Saturday, July 21, 2007 8:25 PM > > > > > > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > > > > > > > > > > > I have used POR-15 for years. It is a great product. It flows > > > out > > > > > nicely. You can paint over rust ( POR )or paint without the rust > > > if > > > > > you Ospho, sandblast or etch steel. It needs something to bite. > > > If it > > > > > is exposed to sunlight, it needs to be topcoated. I'll guarantee > > > it > > > > > will never rust again if applied properly. > > > > > > Leroy Eckert > > > > > > 1990 WB-40"Smoke N Mirrors" > > > > > > Niceville, FL > > > > > > Royale Conversion > > > > > > ----- Original Message ----- > > > > > > From: Scott Forman > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > Sent: Saturday, July 21, 2007 8:07 PM > > > > > > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > > > > > Seems like a good product in design, wondering if it works. > > > > > Wanting to > > > > > > address surface oxidation under my bus. Anyone use it or know > > > > > another > > > > > > better product? > > > > > > > > > > > > Scott Forman > > > > > > 86 PT38 > > > > > > With a cruddy underside > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > > ------ > > > > > > > > > > No virus found in this incoming message. > > > > > Checked by AVG Free Edition. > > > > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: > > > 7/20/2007 4:39 PM > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > No virus found in this incoming message. > > > Checked by AVG Free Edition. > > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: > > 7/20/2007 4:39 PM > > > > > > > [Non-text portions of this message have been removed] > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007 4:39 PM > > > > > > [Non-text portions of this message have been removed] >  |
					07-21-2007, 15:44
					Yup, it's good stuff.  Used it many times to fix on older truck frames,
			resulting in serious value adding to the end product. MH ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 21, 2007 8:25 PM Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? I have used POR-15 for years. It is a great product. It flows out nicely. You can paint over rust ( POR )or paint without the rust if you Ospho, sandblast or etch steel. It needs something to bite. If it is exposed to sunlight, it needs to be topcoated. I'll guarantee it will never rust again if applied properly. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 21, 2007 8:07 PM Subject: [WanderlodgeForum] Anyone ever use POR-15? Seems like a good product in design, wondering if it works. Wanting to address surface oxidation under my bus. Anyone use it or know another better product? Scott Forman 86 PT38 With a cruddy underside [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]  |
					07-21-2007, 16:51
					Done it both wayz, spray requires masking, somewhat.  Brush works  OK too.  Keep
			in mind my experience has been on vintage dump trucks. However, it makes them look impressive and I usually get top buck when selling time comes. MH ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 21, 2007 8:54 PM Subject: [WanderlodgeForum] Re: Anyone ever use POR-15? Did u spray or brush it on? Is it very messy or about like any other paint? --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Yup, it's good stuff. Used it many times to fix on older truck frames, resulting in serious value adding to the end product. > MH > ----- Original Message ----- > From: Leroy Eckert > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 21, 2007 8:25 PM > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? > > > I have used POR-15 for years. It is a great product. It flows out nicely. You can paint over rust ( POR )or paint without the rust if you Ospho, sandblast or etch steel. It needs something to bite. If it is exposed to sunlight, it needs to be topcoated. I'll guarantee it will never rust again if applied properly. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 21, 2007 8:07 PM > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > Seems like a good product in design, wondering if it works. Wanting to > address surface oxidation under my bus. Anyone use it or know another > better product? > > Scott Forman > 86 PT38 > With a cruddy underside > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]  |
					07-21-2007, 16:56
			wrote: > > Seems like a good product in design, wondering if it works. Wanting to > address surface oxidation under my bus. Anyone use it or know another > better product? > > Scott Forman > 86 PT38 > With a cruddy underside I used it on my Thunderbird under the rocker area's and inside on the floor pan. It works great and I even used it to patch a couple of rust out holes using fiber glass screening material. This stuff is a little expensive but works great! But if you are going to do the whole underneath of your rig than I would suggest you might spray on some type of rust inhibitor and then spray with a good undercoating! I did this with my Dodge and it worked out just fine. >  |
					07-21-2007, 19:55
					I always remove the flaky rust before treating although I do not believe it is
			required. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 21, 2007 9:29 PM Subject: [WanderlodgeForum] Re: Anyone ever use POR-15? Is prep required to go over a rusty surface? --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > I have used POR-15 for years. It is a great product. It flows out nicely. You can paint over rust ( POR )or paint without the rust if you Ospho, sandblast or etch steel. It needs something to bite. If it is exposed to sunlight, it needs to be topcoated. I'll guarantee it will never rust again if applied properly. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 21, 2007 8:07 PM > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > Seems like a good product in design, wondering if it works. Wanting to > address surface oxidation under my bus. Anyone use it or know another > better product? > > Scott Forman > 86 PT38 > With a cruddy underside > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]  |
					07-21-2007, 22:52
					I have used POR-15 for several projects on the bus. It is an exceptional
			product that produces a hard glossy finish that is very chip resistant and easy to clean. BUT... in order to get the results that are possible from it requires a lot of preparatory work. All loose rust must be removed requiring scrappin g wire brushing etc. Then the metal preparatory solution, actually an acid etcher, needs to be applied, allowed to work and then thoroughly rinsed off in order to stop the acid action. The surface to be painted must be dry. Make sure that you wear gloves as POR -15 is difficult to remove from your skin. Your results will be great with if you follow the directions. POR 15 is not an inexpensive product for large projects like an entire bus chassis. I have been painting/repainting the chassis of my bus small sections and have had good results from a product called Hammerite. The preparation process is far less complicated. I have been removing all the loose rust, cleaning all the grease and oil from the surface to be covered with solvents then brush painting it on. The product has shown excellent adherence to the chassis and has been holding up well. The acid etching process required for POR-15 is not required. The best part is that Hammerite costs about one forth as much as POR-15. I am not suggesting that Hammerite is a better product than POR-15. In fact it is not. But to be practical, if you are repainting an entire chassis as it sits, that is, with the all the electrical, wiring, hoses and accessories still attached, and are working under the bus. Then acid etching and complete rust removal is not possible. I recommend the less expensive, easier route. I think you will probably be satisfied with the results. Steve Anderson 79 FC 35 Poulsbo, Wa. In a message dated 7/21/2007 6:08:13 PM Pacific Daylight Time, sforman@... writes: Seems like a good product in design, wondering if it works. Wanting to address surface oxidation under my bus. Anyone use it or know another better product? Scott Forman 86 PT38 With a cruddy underside ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed]  |
					07-22-2007, 01:07
					Where can you buy this? A regular paint store or does it have to be bought?
			Does Home Depot or Lowe's handle it? Ron Thompson -Waller, Tx. 1995 WLWB 42'Blue Bird (cockyfox@...) [Non-text portions of this message have been removed]  |
