					Anyone ever use POR-15?
					07-21-2007, 11:30
					Scott     I've used it on my coach frame & I  just finished putting it on a
			truck frame. I used the flat black on the first coat & then the Chass's Coat Black on the second. They say two coats are better that one & you can put the second one on in 3 to 5 hrs. Be sure to follow the directions & don't get any on you or leave it dry on your skin as you will have it on you for a few days. Lacquer thinner will take it off you if you get any on you.The Chass's Coat Black is shinny & not sensitive to UV. Don 89 SP 36' Butler, PA Seems like a good product in design, wondering if it works. Wanting to address surface oxidation under my bus. Anyone use it or know another better product? Scott Forman 86 PT38 With a cruddy underside ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed]  |
					07-21-2007, 11:42
					Scott
			You can spray it with real good results but I brushed it on for big areas as the frames. I have spray ed small things that you could take off & not have to mask off. I made a new battery tray last year & sprayed it. Comes out like glass when dry. Don 89 SP 36' Butler, PA Did u spray or brush it on? Is it very messy or about like any other paint? ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed]  |
					07-21-2007, 13:07
			address surface oxidation under my bus. Anyone use it or know another better product? Scott Forman 86 PT38 With a cruddy underside  |
					07-21-2007, 13:42
					I've used it with good results. It's a self leveling epoxy
			paint, requires surface rust for adhesion, but I've found that it bonds well to non-rusted metal also. Rusted metal requires a small amount of prep work - degreaser, and phosphoric acid based etcher, then POR it on. I found that the gloss black finish is better than the flat black finish. Flat black gave me a very blotched appearance with sections appearing shiny and others appearing flat - stick with the gloss. Top coating is unnecessary for engine compartment or undercarriage work. POR can be top coated immediately, but if you wait too long, a self etching primer will be required. Top coating is required for UVA/UVB protection. David Brady '02 LXi, Smokey NC Scott Forman wrote: > > Seems like a good product in design, wondering if it works. Wanting to > address surface oxidation under my bus. Anyone use it or know another > better product? > > Scott Forman > 86 PT38 > With a cruddy underside > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007 4:39 PM > [Non-text portions of this message have been removed]  |
					07-21-2007, 14:25
					I have used POR-15 for years. It is a great product. It flows out nicely. You
			can paint over rust ( POR )or paint without the rust if you Ospho, sandblast or etch steel. It needs something to bite. If it is exposed to sunlight, it needs to be topcoated. I'll guarantee it will never rust again if applied properly. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 21, 2007 8:07 PM Subject: [WanderlodgeForum] Anyone ever use POR-15? Seems like a good product in design, wondering if it works. Wanting to address surface oxidation under my bus. Anyone use it or know another better product? Scott Forman 86 PT38 With a cruddy underside [Non-text portions of this message have been removed]  |
					07-21-2007, 14:29
					Is prep required to go over a rusty surface?
			--- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > I have used POR-15 for years. It is a great product. It flows out nicely. You can paint over rust ( POR )or paint without the rust if you Ospho, sandblast or etch steel. It needs something to bite. If it is exposed to sunlight, it needs to be topcoated. I'll guarantee it will never rust again if applied properly. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 21, 2007 8:07 PM > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > Seems like a good product in design, wondering if it works. Wanting to > address surface oxidation under my bus. Anyone use it or know another > better product? > > Scott Forman > 86 PT38 > With a cruddy underside > > > > > > [Non-text portions of this message have been removed] >  |
					07-21-2007, 14:48
					In my opinion, yes. The phosphoric acid neutralizes the rust
			and turns it into a hard protective coating, similar to naval jelly or any of the other off-the-shelf neutralizers. David Brady '02 LXi, Smokey NC Scott Forman wrote: > > Is prep required to go over a rusty surface? > > --- In WanderlodgeForum@yahoogroups.com > > > > > > I have used POR-15 for years. It is a great product. It flows out > nicely. You can paint over rust ( POR )or paint without the rust if > you Ospho, sandblast or etch steel. It needs something to bite. If it > is exposed to sunlight, it needs to be topcoated. I'll guarantee it > will never rust again if applied properly. > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > Royale Conversion > > ----- Original Message ----- > > From: Scott Forman > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, July 21, 2007 8:07 PM > > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > Seems like a good product in design, wondering if it works. > Wanting to > > address surface oxidation under my bus. Anyone use it or know > another > > better product? > > > > Scott Forman > > 86 PT38 > > With a cruddy underside > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007 4:39 PM > [Non-text portions of this message have been removed]  |
					07-21-2007, 14:54
			paint? --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Yup, it's good stuff. Used it many times to fix on older truck frames, resulting in serious value adding to the end product. > MH > ----- Original Message ----- > From: Leroy Eckert > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 21, 2007 8:25 PM > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? > > > I have used POR-15 for years. It is a great product. It flows out nicely. You can paint over rust ( POR )or paint without the rust if you Ospho, sandblast or etch steel. It needs something to bite. If it is exposed to sunlight, it needs to be topcoated. I'll guarantee it will never rust again if applied properly. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 21, 2007 8:07 PM > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > Seems like a good product in design, wondering if it works. Wanting to > address surface oxidation under my bus. Anyone use it or know another > better product? > > Scott Forman > 86 PT38 > With a cruddy underside > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] >  |
					07-21-2007, 15:01
					Definitely brush it on, just wear gloves and don't get any on your
			hands. After it self-levels it'll look like you sprayed it. The final finish is very similar to powder coating in appearance and toughness. Those foam/sponge brushes are best, cheap bristle brushes leave bristles in the paint. David Brady '02 LXi, Smokey NC Scott Forman wrote: > > Did u spray or brush it on? Is it very messy or about like any other > paint? > > --- In WanderlodgeForum@yahoogroups.com > > <MHOHNSTEIN@...> wrote: > > > > Yup, it's good stuff. Used it many times to fix on older truck > frames, resulting in serious value adding to the end product. > > MH > > ----- Original Message ----- > > From: Leroy Eckert > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, July 21, 2007 8:25 PM > > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > I have used POR-15 for years. It is a great product. It flows out > nicely. You can paint over rust ( POR )or paint without the rust if > you Ospho, sandblast or etch steel. It needs something to bite. If it > is exposed to sunlight, it needs to be topcoated. I'll guarantee it > will never rust again if applied properly. > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > Royale Conversion > > ----- Original Message ----- > > From: Scott Forman > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, July 21, 2007 8:07 PM > > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > > Seems like a good product in design, wondering if it works. > Wanting to > > address surface oxidation under my bus. Anyone use it or know > another > > better product? > > > > Scott Forman > > 86 PT38 > > With a cruddy underside > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007 4:39 PM > [Non-text portions of this message have been removed]  |
					07-21-2007, 15:04
					Is there anything to keep it away from (electrical, etc)?
			--- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Definitely brush it on, just wear gloves and don't get any on your > hands. After it self-levels it'll look like you sprayed it. The final > finish is very similar to powder coating in appearance and toughness. > Those foam/sponge brushes are best, cheap bristle brushes leave > bristles in the paint. > > David Brady > '02 LXi, Smokey > NC > > Scott Forman wrote: > > > > Did u spray or brush it on? Is it very messy or about like any other > > paint? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > <MHOHNSTEIN@> wrote: > > > > > > Yup, it's good stuff. Used it many times to fix on older truck > > frames, resulting in serious value adding to the end product. > > > MH > > > ----- Original Message ----- > > > From: Leroy Eckert > > > To: WanderlodgeForum@yahoogroups.com > > > > > Sent: Saturday, July 21, 2007 8:25 PM > > > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > > > > I have used POR-15 for years. It is a great product. It flows out > > nicely. You can paint over rust ( POR )or paint without the rust if > > you Ospho, sandblast or etch steel. It needs something to bite. If it > > is exposed to sunlight, it needs to be topcoated. I'll guarantee it > > will never rust again if applied properly. > > > Leroy Eckert > > > 1990 WB-40"Smoke N Mirrors" > > > Niceville, FL > > > Royale Conversion > > > ----- Original Message ----- > > > From: Scott Forman > > > To: WanderlodgeForum@yahoogroups.com > > > > > Sent: Saturday, July 21, 2007 8:07 PM > > > Subject: [WanderlodgeForum] Anyone ever use POR-15? > > > > > > Seems like a good product in design, wondering if it works. > > Wanting to > > > address surface oxidation under my bus. Anyone use it or know > > another > > > better product? > > > > > > Scott Forman > > > 86 PT38 > > > With a cruddy underside > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007 4:39 PM > > > > > > [Non-text portions of this message have been removed] >  |
