Battery charging
06-28-2007, 10:20
Battery charging
My (original) battery chargers seem to always be putting out 13.2v.
One of the links posted recenty about batteries seemed to say that the batteries won't be charged fully unless they get more than 14v put to them. Is this the case? If I keep using these 13.2v output chargers, are my batts never going to charge? Scott Forman 86 PT38 Memphis |
06-28-2007, 11:06
Battery charging
Scott,
You can spend the rest of the night watching responses to a question on battery-charging, but... without getting into actual numbers, here's what I've found in the last two weeks going through a battery replacement. Traditional flooded batteries can be charged to just over 14 volts. AGM's can also be charged at or above 14 volts without fear of overcharging or burning them out or shortening their life. But gel cell batteries need to be charged to a slightly lower voltage. Most inverters can be adjusted to account for the differences. The main advantage of gels and agm's is that their electrolyte media can be sealed to avoid evaporation, boil out and gassing which can cause corrosion to the battery terminals and battery compartments. And because they are sealed..and the media are not purely liquid, the electroyltes can stay in consistent contact with the plates, etc., they handle heat and vibration better. They're not generally any more powerful than traditional batteries, they just overcome the heat, vibration and maintenance issues we don't like. The main thing is..buy deep cycle house batteries if money permits..no matter what kind you get. For starting batteries, the more cold-cranking-amps..the better.Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: sforman@...: Thu, 28 Jun 2007 22:20:38 +0000Subject: [WanderlodgeForum] Battery charging My (original) battery chargers seem to always be putting out 13.2v. One of the links posted recenty about batteries seemed to say that the batteries won't be charged fully unless they get more than 14v put to them. Is this the case? If I keep using these 13.2v output chargers, are my batts never going to charge?Scott Forman86 PT38Memphis _________________________________________________________________ Live Earth is coming. Learn more about the hottest summer event - only on MSN. http://liveearth.msn.com?source=msntaglineliveearthwlm [Non-text portions of this message have been removed] |
06-28-2007, 11:17
Battery charging
Thanks for the comments, but it doesn't really address my question.
I am asking if a charger that puts out 13.2v will fully charge my golf car batteries or if they need to have 14v+ to get charged. Thanks --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> wrote: > > > Scott, > You can spend the rest of the night watching responses to a question on battery-charging, but... > without getting into actual numbers, here's what I've found in the last two weeks going through a battery replacement. Traditional flooded batteries can be charged to just over 14 volts. AGM's can also be charged at or above 14 volts without fear of overcharging or burning them out or shortening their life. But gel cell batteries need to be charged to a slightly lower voltage. > Most inverters can be adjusted to account for the differences. The main advantage of gels and agm's is that their electrolyte media can be sealed to avoid evaporation, boil out and gassing which can cause corrosion to the battery terminals and battery compartments. And because they are sealed..and the media are not purely liquid, the electroyltes can stay in consistent contact with the plates, etc., they handle heat and vibration better. They're not generally any more powerful than traditional batteries, they just overcome the heat, vibration and maintenance issues we don't like. > The main thing is..buy deep cycle house batteries if money permits..no matter what kind you get. For starting batteries, the more cold-cranking-amps..the better.Brad Barton 00LXiDFW bbartonwx@... > > > To: WanderlodgeForum@...: sforman@...: Thu, 28 Jun 2007 22:20:38 +0000Subject: [WanderlodgeForum] Battery charging > > > > > My (original) battery chargers seem to always be putting out 13.2v. One of the links posted recenty about batteries seemed to say that the batteries won't be charged fully unless they get more than 14v put to them. Is this the case? If I keep using these 13.2v output chargers, are my batts never going to charge?Scott Forman86 PT38Memphis > > > _________________________________________________________________ > Live Earth is coming. Learn more about the hottest summer event - only on MSN. > http://liveearth.msn.com?source=msntaglineliveearthwlm > > [Non-text portions of this message have been removed] > |
06-28-2007, 11:34
Battery charging
Scott,
I don't own a Bird, but I would have to say 13.2v as the charge voltage is too low. My Magnum Energy inverter/charger is set from the factory to charge flooded cell batteries (like your golf cart batteries) to 14.2v initially, then float charges at 13.3v. Of course, the technology is 20 years newer than your PT, and intelligent charging (4 stage) does things lots differently than before. Gary SOB ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 28, 2007 5:17 PM Subject: [WanderlodgeForum] Re: Battery charging Thanks for the comments, but it doesn't really address my question. I am asking if a charger that puts out 13.2v will fully charge my golf car batteries or if they need to have 14v+ to get charged. Thanks --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> wrote: > > > Scott, > You can spend the rest of the night watching responses to a question on battery-charging, but... > without getting into actual numbers, here's what I've found in the last two weeks going through a battery replacement. Traditional flooded batteries can be charged to just over 14 volts. AGM's can also be charged at or above 14 volts without fear of overcharging or burning them out or shortening their life. But gel cell batteries need to be charged to a slightly lower voltage. > Most inverters can be adjusted to account for the differences. The main advantage of gels and agm's is that their electrolyte media can be sealed to avoid evaporation, boil out and gassing which can cause corrosion to the battery terminals and battery compartments. And because they are sealed..and the media are not purely liquid, the electroyltes can stay in consistent contact with the plates, etc., they handle heat and vibration better. They're not generally any more powerful than traditional batteries, they just overcome the heat, vibration and maintenance issues we don't like. > The main thing is..buy deep cycle house batteries if money permits..no matter what kind you get. For starting batteries, the more cold-cranking-amps..the better.Brad Barton 00LXiDFW bbartonwx@... > > > To: WanderlodgeForum@...: sforman@...: Thu, 28 Jun 2007 22:20:38 +0000Subject: [WanderlodgeForum] Battery charging > > > > > My (original) battery chargers seem to always be putting out 13.2v. One of the links posted recenty about batteries seemed to say that the batteries won't be charged fully unless they get more than 14v put to them. Is this the case? If I keep using these 13.2v output chargers, are my batts never going to charge?Scott Forman86 PT38Memphis > > > __________________________________________________________ > Live Earth is coming. Learn more about the hottest summer event - only on MSN. > http://liveearth.msn.com?source=msntaglineliveearthwlm > > [Non-text portions of this message have been removed] > |
06-28-2007, 13:53
Battery charging
Sorry I didn't understand your question properly. I think you do need to get
them up to 14V to get 100% of your power out of the batteries, but you can still get 85-90% with the lesser charge. If you're not expecting the absolute maximum you'll probably not notice much difference.Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: sforman@...: Thu, 28 Jun 2007 23:17:57 +0000Subject: [WanderlodgeForum] Re: Battery charging _________________________________________________________________ Hotmail to go? Get your Hotmail, news, sports and much more! Check out the New MSN Mobile! http://mobile.msn.com [Non-text portions of this message have been removed] |
06-28-2007, 15:25
Battery charging
Scott, 13.2 is the "float" charging rate for most flooded lead acid
batteries. If you run your bird regularly you would probably not have a problem at 13.2vdc. The alternator will charge them somewhere between 13.8 and 14.5 depending on the temperature. If they are the original BB units I am surprised that they are not charging more unless a battery isolator has been added to the circuit. You will get a .6 -.7 v drop across the isolator this would put you at about 13.8v which would be about perfect under average conditions. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Thursday, June 28, 2007 5:21 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Battery charging My (original) battery chargers seem to always be putting out 13.2v. One of the links posted recenty about batteries seemed to say that the batteries won't be charged fully unless they get more than 14v put to them. Is this the case? If I keep using these 13.2v output chargers, are my batts never going to charge? Scott Forman 86 PT38 Memphis [Non-text portions of this message have been removed] |
06-29-2007, 07:19
Battery charging
Scott,
I had the same problem you describe. My old chargers charged about 13.2v and I always had wet batteries. I changed over to 2 - 45amp Iota chargers with one IQ4 smart charger tying the two chargers together and they seem to be working fine. Do a search on the forum website for Iota Chargers. Tom Warner has a very nice set up on his coach. He has 120v to all outlets and appliances supplied by the alternator thru a 2500 watt inverter. I'm electrically challenged so I just went with the Iota's. Howard Truitt Camilla, Ga. 86 PT40 > > From: "Scott Forman" <sforman@...> > Date: 2007/06/28 Thu PM 07:17:57 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Battery charging > > Thanks for the comments, but it doesn't really address my question. > I am asking if a charger that puts out 13.2v will fully charge my > golf car batteries or if they need to have 14v+ to get charged. > > Thanks > |
06-29-2007, 08:00
Battery charging
Scott,
I forget to tell you where I ordered mine. I purchased them from John Drake Services Inc. call John at 562-423-4879 he is very knowledgeable. Or go to his web site solarseller dot com. I said in my earlier post I installed 45amp but I actually ordered 55amp. 2- DLS 55amp chargers $150.00 each. 1- IQ4 Parallel smart charge control $35.00 Shipping and handling $15.00 Howard, Camilla, Ga., 86 PT40 > > From: > To: > Subject: Re: [WanderlodgeForum] Re: Battery charging > > Scott, > I had the same problem you describe. My old chargers charged about 13.2v and I always had wet batteries. I changed over to 2 - 45amp Iota chargers with one IQ4 smart charger tying the two chargers together and they seem to be working fine. Do a search on the forum website for Iota Chargers. Tom Warner has a very nice set up on his coach. He has 120v to all outlets and appliances > supplied by the alternator thru a 2500 watt inverter. I'm electrically challenged so I just went with the Iota's. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > > From: "Scott Forman" <sforman@...> > > Date: 2007/06/28 Thu PM 07:17:57 EDT > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Battery charging > > > > Thanks for the comments, but it doesn't really address my question. > > I am asking if a charger that puts out 13.2v will fully charge my > > golf car batteries or if they need to have 14v+ to get charged. > > > > Thanks > > > > > |
