Water Fill Value Problem (PT-40)
06-10-2007, 02:40
Kevin, i had my switch go bad on mine. Its an easy fix, if that is your
problem.
83PT40
Livingston, Mt
06-10-2007, 04:04
All:
Need help with water fill valve on a 1982 PT-40. When I filled the tank
yesterday the valve is now stuck in the "Fill Tank" position. I other
words with the city water supplied, it keep overflowing and the onboard
water pump will not presurize. Can someone tell me where the valve is
located and any other troubleshooting tips would be appreciated.
Kevin Ford
Richmond TX
1982 PT-40
06-10-2007, 04:20
Mine is under the bed near the water pump. The Sporlan valve is probably stuck
with some crud inside.
Leroy Eckert
1990 WB-40 "Smoke N Mirrors"
Niceville, FL
Sent: Sunday, June 10, 2007 11:04 AM
Subject: [WanderlodgeForum] Water Fill Value Problem (PT-40)
All:
Kevin Ford
Richmond TX
1982 PT-40
06-10-2007, 04:24
Kevin,
I've experience the same issue. Sounds like the Sporlan Valve, located
near the water tank. The valve is controlled by the "fill tank" switch.
Our coach has the walk-around bed, water tank is under the bed, the
sporlan valve is on the drivers side of the water tank.
Remove the four screws around the electro-magnet. Remove the rubber
diaphragm. Using a screw driver, stuff a small rag into the opening to
stop the water flow. Clean out any foreign matter, usually white stuff.
Carefully remove any foreign matter from the diaphragm. Reassemble and
all should be good.
One small piece of crud will stop these valves from working.
About a 20 minute project.
Curt Sprenger
Anaheim Hills, Calif.
Kevin Ford wrote:
> All:
> Kevin Ford
> Richmond TX
> 1982 PT-40
06-10-2007, 04:34
Ok thanks I will open up the bed and have a look.
Thanks for your help!
Kevin
Richmond TX
'82 PT-40
probably stuck with some crud inside.
> Leroy Eckert
> Niceville, FL
> From: Kevin Ford
> All:
the tank
other
onboard
valve is
> Kevin Ford
> Richmond TX
> 1982 PT-40
06-10-2007, 04:40
This is the infamous Sporlan Valve. Locations vary (mine is in the
last compartment on the wall toward the rear of the coach on the curb
side (opposite side from where the fill switch is).
In some older coaches, it's under the bed. Perhaps someone with a
year closer to yours will know.
Pete Masterson
aeonix1@...
On the road near Evergreen Colorado
On Jun 10, 2007, at 10:04 AM, Kevin Ford wrote:
> All:
> tank
> onboard
> Kevin Ford
> Richmond TX
> 1982 PT-40
06-10-2007, 06:14
I found the valve and removed the diaphram and cleaned it up as Curt
described, but still no affect. I did check the voltage from the
outside switch -- it is good. I need some value 101. It appears that
the voltage is applied to fill the tank, but I don't understand how
this valve directs the water flow, and with no voltage (switch in off
position) what should happen? And any other ideas?
Again thanks.
Kevin
Richmond TX
'82 PT-40
> Kevin,
located
switch.
to
stuff.
> all should be good.
> Curt Sprenger
> Kevin Ford wrote:
> > All:
the tank
other
onboard
valve is
> > Kevin Ford
> > Richmond TX
> > 1982 PT-40
06-10-2007, 06:37
Kevin,
Put your fingers around that Sporlan valve, as someone flips the
switch On/Off/On/Off. You should be able to feel and hear the
solenoid activate the valve diaphram.
Bill 88 Fc Michigan
--- In WanderlodgeForum@yahoogroups.com, "Kevin Ford"
Curt
that
off
> Again thanks.
> Kevin
> Richmond TX
> '82 PT-40
> > Kevin,
> located
> switch.
rubber
opening
> to
> stuff.
Reassemble
> and
> > all should be good.
> > Curt Sprenger
> > Kevin Ford wrote:
> > > All:
> the tank
> other
> onboard
> valve is
> > > Kevin Ford
> > > Richmond TX
> > > 1982 PT-40
06-10-2007, 06:55
Kevin,
Have you looked in the files section of the forum at document named
Sporlan Valve 30-11.pdf ? It describes the Sporlan Valve parts,
sequence of operation and lists common causes of failures.
FWIW,
1991 WB40 "Texas Minivan"
> Again thanks.
> Kevin
> Richmond TX
> '82 PT-40
> > Kevin,
> located
> switch.
> to
> stuff.
> and
> > all should be good.
> > Curt Sprenger
> > Kevin Ford wrote:
> > > All:
> the tank
> other
> onboard
> valve is
> > > Kevin Ford
> > > Richmond TX
> > > 1982 PT-40
06-10-2007, 07:16
I looked at the drawing mentioned by Mike and found I had put the
plunger upside down. So it appears to be fixed now with the cleaning
and putting it back together correctly.
Thanks everyone!
Kevin
Richomnd, TX
'82 PT-40
> Kevin,
> FWIW,
> Mike Bulriss
> San Antonio, TX
Curt
that
how
off
> > Again thanks.
> > Kevin
> > Richmond TX
> > '82 PT-40
> > wrote:
> > > Kevin,
> > located
> > switch.
rubber
opening
> > to
white
> > stuff.
Reassemble
> > and
> > > all should be good.
> > > Curt Sprenger
> > > Kevin Ford wrote:
> > > > All:
filled
> > the tank
I
> > other
> > onboard
> > valve is
appreciated.
> > > > Kevin Ford
> > > > Richmond TX
> > > > 1982 PT-40
