Quick braking question.
05-24-2007, 09:17
New guy here again. I purchased a 35' 78FC 3208NA. I would like to know
if you experienced guys think that engine braking/compression in 1st gear would hold back this motorhome with a 6000# trailer behind it going down a 6-7% grade? I am guessing not. Thanks in advance and for the other advice as well. |
05-24-2007, 09:34
NO,
The torque converter doesn't lock up in first or second gear, also you do not want to overspeed the engine, that would result in valve breakage and destroy the engine. The 3208 doesn't provide much back presure anyway so even in 3rd or 4th you will need the brakes. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" wrote: > > New guy here again. I purchased a 35' 78FC 3208NA. I would like to know > if you experienced guys think that engine braking/compression in 1st > gear would hold back this motorhome with a 6000# trailer behind it > going down a 6-7% grade? I am guessing not. Thanks in advance and for > the other advice as well. > |
05-24-2007, 10:29
Come on guys you are scaring people that have Bluebirds without a
retarder. Any Bluebird can go down the steepest hill without a retarder if you know how to drive it and learn how to do it right. Truckers for many many years drove log trucks in the adirondaks where I live here in New York without a retarder and they did it daily and got to the bottom of the steepest hills without brown spots on their shorts. Were there accidents? Yep..for the fools that took chances and drove to fast. The Bluebird coaches have very good brakes and while a 6000# trailer will surely slow you down going up hill, it will surely speed you up going downhill IF you dont select the right speed and use the brakes correctly. In the case you describe I would use 1st or 2nd gear and when the speed gets close to its maximum in that range I would stab the brakes hard and slow it down 5-10 MPH and hour then let off the brakes and let them cool down until the speed got up to close to its maximum and then hit the brakes hard again and bring the speed back down 5-10 MPH, and keep doing that until you get to the bottom of the hill. This is the method that professional drivers have used for well over 75 years. I would caution you however to start in the lowest gear and only when you are confident you can handle it go to a higher gear and try that also. Shouldnt take long before you are confident to go down any hill (thats what they are called out west, and mountains in the east) .................................................ducking now! The Cat 3208NA is a fine engine and if it breathes right (it doesnt the way bluebird installed it in the coach), the valve lash properly done and the engine serviced per the cat manual will outlast you and I. Sure there are people that will tell you not to buy any bluebird that does not have a turbo charger but just remember that every engine has its stong and weak points. For the Cat 3208NA it is understressed and bulletproof if properly serviced. If you want to go up hills at 65MPH then dont buy any bluebird buy a corvette tom warner vernon center,ny 1985 PT 40 At 05:17 PM 5/24/2007, you wrote: >New guy here again. I purchased a 35' 78FC 3208NA. I would like to know >if you experienced guys think that engine braking/compression in 1st >gear would hold back this motorhome with a 6000# trailer behind it >going down a 6-7% grade? I am guessing not. Thanks in advance and for >the other advice as well. > |
05-24-2007, 11:37
Commercial drivers manual states that you go down the hill the same speed as
which you came up or think you would come up the hill, that way you should always be in control. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: kingmtpg To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 24, 2007 2:17:30 PM Subject: [WanderlodgeForum] Quick braking question. New guy here again. I purchased a 35' 78FC 3208NA. I would like to know if you experienced guys think that engine braking/compression in 1st gear would hold back this motorhome with a 6000# trailer behind it going down a 6-7% grade? I am guessing not. Thanks in advance and for the other advice as well. Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail at http://mrd.mail.yahoo.com/try_beta?.intl=ca [Non-text portions of this message have been removed] |
05-24-2007, 23:17
Additional braking would be required to maintain a slow descent and to keep
the engine RPMs down. Steve Anderson 79 FC 35 Poulsbo, Wa. In a message dated 5/24/2007 2:23:35 PM Pacific Daylight Time, kingmtpg@... writes: New guy here again. I purchased a 35' 78FC 3208NA. I would like to know if you experienced guys think that engine braking/compression in 1st gear would hold back this motorhome with a 6000# trailer behind it going down a 6-7% grade? I am guessing not. Thanks in advance and for the other advice as well. ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
