Air Level Master - Dim Suspension Dump Light
05-17-2007, 04:56
What is the "Air Level Master" as labeled on the dash? Mine has a flat
plastic plate, not a switch. It does have the LED, but it never lights up. I aired up the suspension system this morning. Everything aired up as it should. I've used my leak detector tools and have not found a leak one. I'll let it stand for a couple hours to see if it settles any. When I turn the ignition key to on I get a very dim suspension dump light. Any thoughts on why the dim light? -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
05-17-2007, 11:41
Curt:
I don't have an Air Level Master that I know of. I would like to know what it does. I did have a ghost monitor light on the marker light switch and found a dirty ground. Could it possibly be the main ground in the lower load center. The main ground bus bar connection? Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Curt Sprenger To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com Sent: Thursday, May 17, 2007 11:56 AM Subject: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light What is the "Air Level Master" as labeled on the dash? Mine has a flat plastic plate, not a switch. It does have the LED, but it never lights up. I aired up the suspension system this morning. Everything aired up as it should. I've used my leak detector tools and have not found a leak one. I'll let it stand for a couple hours to see if it settles any. When I turn the ignition key to on I get a very dim suspension dump light. Any thoughts on why the dim light? -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
05-17-2007, 11:48
I was wondering if it was supposed to be "Air Compressor Master"?
On 5/17/2007 at 6:41 PM Leroy Eckert wrote: >Curt: >I don't have an Air Level Master that I know of. I would like to know >what it does. I did have a ghost monitor light on the marker light switch >and found a dirty ground. Could it possibly be the main ground in the >lower load center. The main ground bus bar connection? > >Leroy Eckert >1990 WB-40 "Smoke N Mirrors" >Niceville, FL > ----- Original Message ----- > From: Curt Sprenger > To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com > Sent: Thursday, May 17, 2007 11:56 AM > Subject: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light > > > What is the "Air Level Master" as labeled on the dash? Mine has a flat > plastic plate, not a switch. It does have the LED, but it never lights >up. > > I aired up the suspension system this morning. Everything aired up as it > should. I've used my leak detector tools and have not found a leak one. > I'll let it stand for a couple hours to see if it settles any. When I > turn the ignition key to on I get a very dim suspension dump light. Any > thoughts on why the dim light? > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > |
05-17-2007, 12:42
Leroy,
Bluebird offered an Air Leveling system instead of the jack system. I believe my dash has the place holder for the air leveling switch, if it had the system. I have the jack leveling system. Could be the main ground, good thought. If I understand the Lower Load Center, it's in the generator fan/control bay, up top in that bay. Right? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: > Curt: > I don't have an Air Level Master that I know of. I would like to know > what it does. I did have a ghost monitor light on the marker light > switch and found a dirty ground. Could it possibly be the main ground > in the lower load center. The main ground bus bar connection? > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: Curt Sprenger > To: wanderlodge@yahoogroups.com > ; WanderlodgeForum@yahoogroups.com > > Sent: Thursday, May 17, 2007 11:56 AM > Subject: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light > > What is the "Air Level Master" as labeled on the dash? Mine has a flat > plastic plate, not a switch. It does have the LED, but it never lights up. > > I aired up the suspension system this morning. Everything aired up as it > should. I've used my leak detector tools and have not found a leak one. > I'll let it stand for a couple hours to see if it settles any. When I > turn the ignition key to on I get a very dim suspension dump light. Any > thoughts on why the dim light? > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] > > |
05-17-2007, 12:44
I have an "air compressor master" switch on my dash that's similarly
a 'blank' instead of a switch. Indeed, I do not have a _supplemental_ air compressor that is an option (at least on my year bird). Instead, a previous owner installed a Microphor compressor that provides air for the toilet. One annoyance is that they didn't hook up the dump valves to the Microphor compressor -- an oversight that I plan to remedy when I have the time... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas On May 17, 2007, at 6:48 PM, Don Bradner wrote: > I was wondering if it was supposed to be "Air Compressor Master"? > > On 5/17/2007 at 6:41 PM Leroy Eckert wrote: > >> Curt: >> I don't have an Air Level Master that I know of. I would like to >> know >> what it does. I did have a ghost monitor light on the marker >> light switch >> and found a dirty ground. Could it possibly be the main ground in >> the >> lower load center. The main ground bus bar connection? >> >> Leroy Eckert >> 1990 WB-40 "Smoke N Mirrors" >> Niceville, FL >> ----- Original Message ----- >> From: Curt Sprenger >> To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com >> Sent: Thursday, May 17, 2007 11:56 AM >> Subject: [WanderlodgeForum] Air Level Master - Dim Suspension >> Dump Light >> >> >> What is the "Air Level Master" as labeled on the dash? Mine has a >> flat >> plastic plate, not a switch. It does have the LED, but it never >> lights >> up. >> >> I aired up the suspension system this morning. Everything aired >> up as it >> should. I've used my leak detector tools and have not found a >> leak one. >> I'll let it stand for a couple hours to see if it settles any. >> When I >> turn the ignition key to on I get a very dim suspension dump >> light. Any >> thoughts on why the dim light? |
05-17-2007, 12:51
Don,
No, I have one of those too. It turns on/off the 120V compressor. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Don Bradner wrote: > I was wondering if it was supposed to be "Air Compressor Master"? > > On 5/17/2007 at 6:41 PM Leroy Eckert wrote: > > >Curt: > >I don't have an Air Level Master that I know of. I would like to know > >what it does. I did have a ghost monitor light on the marker light switch > >and found a dirty ground. Could it possibly be the main ground in the > >lower load center. The main ground bus bar connection? > > > >Leroy Eckert > >1990 WB-40 "Smoke N Mirrors" > >Niceville, FL > > ----- Original Message ----- > > From: Curt Sprenger > > To: wanderlodge@yahoogroups.com > > WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, May 17, 2007 11:56 AM > > Subject: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light > > > > > > What is the "Air Level Master" as labeled on the dash? Mine has a flat > > plastic plate, not a switch. It does have the LED, but it never lights > >up. > > > > I aired up the suspension system this morning. Everything aired up > as it > > should. I've used my leak detector tools and have not found a leak one. > > I'll let it stand for a couple hours to see if it settles any. When I > > turn the ignition key to on I get a very dim suspension dump light. Any > > thoughts on why the dim light? > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > >Yahoo! Groups Links > > > > > > > > |
05-17-2007, 13:20
Huh> Didn't know about the early air leveler. It's always good to learn
something new. My lower load center is behind the large removable plate attached with Camloc fasteners in the nose of the coach. At least that is how it is described on my prints. It is where I have a major ground bus bar and three(I think) power bus bars. Constant, Ignition and Filtered power. It is where numerous relays reside. Leroy Eckert 1990 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 17, 2007 7:42 PM Subject: Re: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light Leroy, Bluebird offered an Air Leveling system instead of the jack system. I believe my dash has the place holder for the air leveling switch, if it had the system. I have the jack leveling system. Could be the main ground, good thought. If I understand the Lower Load Center, it's in the generator fan/control bay, up top in that bay. Right? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: > Curt: > I don't have an Air Level Master that I know of. I would like to know > what it does. I did have a ghost monitor light on the marker light > switch and found a dirty ground. Could it possibly be the main ground > in the lower load center. The main ground bus bar connection? > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: Curt Sprenger > To: wanderlodge@yahoogroups.com > ; WanderlodgeForum@yahoogroups.com > > Sent: Thursday, May 17, 2007 11:56 AM > Subject: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light > > What is the "Air Level Master" as labeled on the dash? Mine has a flat > plastic plate, not a switch. It does have the LED, but it never lights up. > > I aired up the suspension system this morning. Everything aired up as it > should. I've used my leak detector tools and have not found a leak one. > I'll let it stand for a couple hours to see if it settles any. When I > turn the ignition key to on I get a very dim suspension dump light. Any > thoughts on why the dim light? > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
05-17-2007, 17:34
Curt,
That blank position, complete with blue light, on our dashes is for an option that I don't have and neither do you apparently. I would suppose that BB was anticipating offering air leveling but either didn't or didn't want to list it is Section XI for what ever reason. Makes sense to me. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 17, 2007 4:41 PM Subject: Re: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light Curt: I don't have an Air Level Master that I know of. I would like to know what it does. I did have a ghost monitor light on the marker light switch and found a dirty ground. Could it possibly be the main ground in the lower load center. The main ground bus bar connection? Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Curt Sprenger To: wanderlodge@yahoogroups.com WanderlodgeForum@yahoogroups.com Sent: Thursday, May 17, 2007 11:56 AM Subject: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light What is the "Air Level Master" as labeled on the dash? Mine has a flat plastic plate, not a switch. It does have the LED, but it never lights up. I aired up the suspension system this morning. Everything aired up as it should. I've used my leak detector tools and have not found a leak one. I'll let it stand for a couple hours to see if it settles any. When I turn the ignition key to on I get a very dim suspension dump light. Any thoughts on why the dim light? -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
05-18-2007, 14:06
> Curt... I have the Air Level System in my 89sp and dont know how to use it. A rocker switch with "level" on one side and "Ride" on the other side. Middle position is off. All i have done is put it in "ride" when in motion. Any body else use this option?? And how?? Thanks Ed Gardels 89sp Arlington Texas > Leroy, > Bluebird offered an Air Leveling system instead of the jack system. I > believe my dash has the place holder for the air leveling switch, if it > had the system. I have the jack leveling system. > > Could be the main ground, good thought. If I understand the Lower Load > Center, it's in the generator fan/control bay, up top in that bay. Right? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Leroy Eckert wrote: > > > Curt: > > I don't have an Air Level Master that I know of. I would like to know > > what it does. I did have a ghost monitor light on the marker light > > switch and found a dirty ground. Could it possibly be the main ground > > in the lower load center. The main ground bus bar connection? > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > ----- Original Message ----- > > From: Curt Sprenger > > To: wanderlodge@yahoogroups.com > > ; WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, May 17, 2007 11:56 AM > > Subject: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light > > > > What is the "Air Level Master" as labeled on the dash? Mine has a flat > > plastic plate, not a switch. It does have the LED, but it never lights up. > > > > I aired up the suspension system this morning. Everything aired up as it > > should. I've used my leak detector tools and have not found a leak one. > > I'll let it stand for a couple hours to see if it settles any. When I > > turn the ignition key to on I get a very dim suspension dump light. Any > > thoughts on why the dim light? > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > [Non-text portions of this message have been removed] > > > > > |
05-19-2007, 02:33
Ed,
What does it do when in the "level" setting? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Ed Gardels wrote: > --- In WanderlodgeForum@yahoogroups.com > > > > > > Curt... I have the Air Level System in my 89sp and dont know how to > use it. A rocker switch with "level" on one side and "Ride" on the > other side. Middle position is off. All i have done is put it > in "ride" when in motion. > Any body else use this option?? And how?? > Thanks > Ed Gardels 89sp > Arlington Texas > > > Leroy, > > Bluebird offered an Air Leveling system instead of the jack system. > I > > believe my dash has the place holder for the air leveling switch, > if it > > had the system. I have the jack leveling system. > > > > Could be the main ground, good thought. If I understand the Lower > Load > > Center, it's in the generator fan/control bay, up top in that bay. > Right? > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > Leroy Eckert wrote: > > > > > Curt: > > > I don't have an Air Level Master that I know of. I would like to > know > > > what it does. I did have a ghost monitor light on the marker > light > > > switch and found a dirty ground. Could it possibly be the main > ground > > > in the lower load center. The main ground bus bar connection? > > > > > > Leroy Eckert > > > 1990 WB-40 "Smoke N Mirrors" > > > Niceville, FL > > > ----- Original Message ----- > > > From: Curt Sprenger > > > To: wanderlodge@yahoogroups.com > > > > ; WanderlodgeForum@yahoogroups.com > > > > > > > Sent: Thursday, May 17, 2007 11:56 AM > > > Subject: [WanderlodgeForum] Air Level Master - Dim Suspension > Dump Light > > > > > > What is the "Air Level Master" as labeled on the dash? Mine has a > flat > > > plastic plate, not a switch. It does have the LED, but it never > lights up. > > > > > > I aired up the suspension system this morning. Everything aired > up as it > > > should. I've used my leak detector tools and have not found a > leak one. > > > I'll let it stand for a couple hours to see if it settles any. > When I > > > turn the ignition key to on I get a very dim suspension dump > light. Any > > > thoughts on why the dim light? > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > |
User(s) browsing this thread: 11 Guest(s)
