Alt Fault flashing and solenoid clicking
04-29-2007, 16:26
Shortly after starting my WB I get a Alt fault, the person I
purchased from said it has always done this. However, just in the
last week I get the fault and relays 9 and 9A in the lower
distribution panel which are the ALT1 and ALT2 selection relays
start clicking. Also a relay, which I am not sure what it is for
which is located in the engine compartment mounted on the curb side
at the firewall where all the shunts are located starts clicking as
well. This relay in the engine compartment looks like a starter
relay, it appears to be a large high power relay.
In my troubleshooting, I disconnected both relay 9 and 9A at the
forward lower distro panel and the rear relay continues to click.
Has anyone seen this issue? Is it an alternator issue, a relay
issue, or just a ground issue?
I see one alternator in my coach, most seem to call the this lower.
It is mounted under the A/C compressor. I have seen statements
about the other one being below the bed. Is this at rear of the
engine compartment, or the front? How do I get to it, meaning, what
do I need to do in the bedroom to get to it?
My Service Parts list in the blue box shows Delco #1117920 (160 AMP)
alternator installed, but not how many.
Michael Brundridge
1992 WB40
Georgetown, TX
04-29-2007, 17:02
have you ever checked the batteries for a ground short? or bad one? I
am not up on it but the first thing I would do is to start at the
storage end
GregoryO'Connor
94ptRomolandCa
lower.
what
AMP)
> Michael Brundridge
> 1992 WB40
> Georgetown, TX
04-29-2007, 17:11
No I have not. But that is simple enough, just need to pull all the
postive cables off and verify each battery voltage to see if I have
some dead cells. I believe all the batteries in the coach require
replacement as it is. I can start the 8V92 with just the 3 main
engine batteries on a good day. If the engine is hot, I will have
to engage the ALT batteries to get it crank over fast enough to
start. So that tells me they are not holding a full charge anymore.
Michael Brundridge
1992 WB40
Georgetown, TX
one? I
> storage end
> GregoryO'Connor
> 94ptRomolandCa
for
side
as
click.
> lower.
> what
> AMP)
> > Michael Brundridge
> > 1992 WB40
> > Georgetown, TX
04-30-2007, 01:32
Mike you can also encourage a flashing alt situation and then shut
off one bank at a time ?? there are two switches in my louvered
compartment near your clicking solonoid for that purpose. A start on
weak batteries playes havoc on the starter motor. Many have also
proven computer problems start with batteries
GregoryO'Connor
94ptRomolandCa
> Michael Brundridge
> 1992 WB40
> Georgetown, TX
> one? I
> > storage end
> > GregoryO'Connor
> > 94ptRomolandCa
> the
relays
> for
> side
clicking
> as
starter
> click.
> > lower.
> > what
> > AMP)
> > > Michael Brundridge
> > > 1992 WB40
> > > Georgetown, TX
