Update - Thermostat and radiator service, with 6,000 pound in tow.
03-19-2007, 04:44
Update...The past few days I ran the bus about 400 miles, 6,000 pounds
in tow, outside temperature in the 80's. On the flat the coolant temperature run 180-185, oil temperature 220. Climbing Whitewater Grade out of Palm Springs, 40 mph head wind, the coolant temperature got up to 190 degrees, oil just over 230. I'd say changing the thermostats and clean/rodding the radiator was a good thing to do. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
03-19-2007, 12:35
Sounds like you did the right thing replacing all of those parts.
That's what I did on mine too. Plus new water pump & new rad core (increased cooling capacity 15%). When it warms up some, will take it out on I90 to see what it runs at now. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Curt Sprenger wrote: > Update...The past few days I ran the bus about 400 miles, 6,000 pounds > in tow, outside temperature in the 80's. On the flat the coolant > temperature run 180-185, oil temperature 220. Climbing Whitewater Grade > out of Palm Springs, 40 mph head wind, the coolant temperature got up to > 190 degrees, oil just over 230. I'd say changing the thermostats and > clean/rodding the radiator was a good thing to do. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] |
03-19-2007, 12:56
Terry,
Please keep us posted. How many miles on your engine? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Terry Neal wrote: > Sounds like you did the right thing replacing all of those parts. > That's what I did on mine too. Plus new water pump & new rad core > (increased cooling capacity 15%). When it warms up some, will take it > out on I90 to see what it runs at now. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > Curt Sprenger wrote: > > > Update...The past few days I ran the bus about 400 miles, 6,000 pounds > > in tow, outside temperature in the 80's. On the flat the coolant > > temperature run 180-185, oil temperature 220. Climbing Whitewater Grade > > out of Palm Springs, 40 mph head wind, the coolant temperature got up to > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > clean/rodding the radiator was a good thing to do. > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > [Non-text portions of this message have been removed] > > |
03-19-2007, 13:33
Curt, it has 171,000 on it which appears pretty close from the Hobbs
hour meter. Went through all the upper part of the engine. Rebuilt or replaced the blower, turbo, water pump, fuel pump, Charge air cooler, etc. Resetting the fuel rails now & putting it all back together. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Curt Sprenger wrote: > Terry, > Please keep us posted. > How many miles on your engine? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Terry Neal wrote: > > > Sounds like you did the right thing replacing all of those parts. > > That's what I did on mine too. Plus new water pump & new rad core > > (increased cooling capacity 15%). When it warms up some, will take it > > out on I90 to see what it runs at now. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Curt Sprenger wrote: > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 pounds > > > in tow, outside temperature in the 80's. On the flat the coolant > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > Grade > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > up to > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > clean/rodding the radiator was a good thing to do. > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] |
03-19-2007, 14:04
Terry,
I wonder if a correlation could be established between engine miles and the coolant/fuel hose, pump, maintenance requirements. Would be useful to other 'Bird owners for sure. You are doing a lot of work on your engine. What is the rational for the blower and turbo work? Do you have the maintenance history on your coach? You must have a shop to park your bus and work on it. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Terry Neal wrote: > Curt, it has 171,000 on it which appears pretty close from the Hobbs > hour meter. Went through all the upper part of the engine. Rebuilt or > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > etc. Resetting the fuel rails now & putting it all back together. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > Curt Sprenger wrote: > > > Terry, > > Please keep us posted. > > How many miles on your engine? > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > Terry Neal wrote: > > > > > Sounds like you did the right thing replacing all of those parts. > > > That's what I did on mine too. Plus new water pump & new rad core > > > (increased cooling capacity 15%). When it warms up some, will take it > > > out on I90 to see what it runs at now. > > > > > > Terry Neal > > > Bozeman, MT > > > 82PT40 6V92TA > > > 74FC34 6V53T > > > > > > Curt Sprenger wrote: > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > pounds > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > Grade > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > up to > > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > |
03-19-2007, 15:10
I doubt there is any correlation between maintenance on an engine
used in RV service on one coach relative to any other coach and/or on an RV engine versus one used in over the road class 8 truck service. After talking to diesel mechanics, coach owners and truck owners there appears to be a vast difference in the way the engines are regularly driven and serviced which I believe is the main reason so many of our engines are overhauled or replaced at such low mileages. From what I have seen it is not unusual for our coaches to sit for months at a time between uses which is not good. If you look over the various internet sites where RVs are sold it is not unusual to see engines replaced long before the average service life of the engines detailed in the manufacturers manuals. The same appears to be consistent with transmissions, radiators etc. Two things you can do to minimize the problems with your coach, first use it as much as possible, and/or start it up and drive it a few miles at least once a month EXCEPT if it is stored for the winter. Secondly do the regularly scheduled maintenance, including filters, air dryers etc and dont over stress the engine by lugging it. tom warner now in florida 1985 PT 40 running perfectly because of the --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Terry, > I wonder if a correlation could be established between engine miles and > the coolant/fuel hose, pump, maintenance requirements. Would be useful > to other 'Bird owners for sure. > > You are doing a lot of work on your engine. What is the rational for the > blower and turbo work? Do you have the maintenance history on your coach? > > You must have a shop to park your bus and work on it. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Terry Neal wrote: > > > Curt, it has 171,000 on it which appears pretty close from the Hobbs > > hour meter. Went through all the upper part of the engine. Rebuilt or > > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > > etc. Resetting the fuel rails now & putting it all back together. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Curt Sprenger wrote: > > > > > Terry, > > > Please keep us posted. > > > How many miles on your engine? > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > Terry Neal wrote: > > > > > > > Sounds like you did the right thing replacing all of those parts. > > > > That's what I did on mine too. Plus new water pump & new rad core > > > > (increased cooling capacity 15%). When it warms up some, will take it > > > > out on I90 to see what it runs at now. > > > > > > > > Terry Neal > > > > Bozeman, MT > > > > 82PT40 6V92TA > > > > 74FC34 6V53T > > > > > > > > Curt Sprenger wrote: > > > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > > pounds > > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > > Grade > > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > > up to > > > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > |
03-19-2007, 15:57
Curt Smart move with addressing your cooling system on your 92. I learned years
ago, that you just can't overheat a two stroke Detroit, you may luck out and do it once, but you'll never get away with it, twice. What you did was the cheapest insurance, one can buy. Good luck! Jimmy Harvie 82FC35 Boston Ma Curt Sprenger I wonder if a correlation could be established between engine miles and the coolant/fuel hose, pump, maintenance requirements. Would be useful to other 'Bird owners for sure. You are doing a lot of work on your engine. What is the rational for the blower and turbo work? Do you have the maintenance history on your coach? You must have a shop to park your bus and work on it. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Terry Neal wrote: > Curt, it has 171,000 on it which appears pretty close from the Hobbs > hour meter. Went through all the upper part of the engine. Rebuilt or > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > etc. Resetting the fuel rails now & putting it all back together. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > Curt Sprenger wrote: > > > Terry, > > Please keep us posted. > > How many miles on your engine? > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > Terry Neal wrote: > > > > > Sounds like you did the right thing replacing all of those parts. > > > That's what I did on mine too. Plus new water pump & new rad core > > > (increased cooling capacity 15%). When it warms up some, will take it > > > out on I90 to see what it runs at now. > > > > > > Terry Neal > > > Bozeman, MT > > > 82PT40 6V92TA > > > 74FC34 6V53T > > > > > > Curt Sprenger wrote: > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > pounds > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > Grade > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > up to > > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > --------------------------------- 8:00? 8:25? 8:40? Find a flick in no time with theYahoo! Search movie showtime shortcut. [Non-text portions of this message have been removed] |
03-19-2007, 16:45
Terry, I'd say change your hoses every other year, If you drive it or not. Also
don't be afraid to use a nutdriver and go over your hose clamps often. Those Detriots vibrate a lot so I used to throw a wrench on all of the engine bolts, on the ones I used to own, expecially the oil cooler. I use Permetex #2 non hardening goo goo on all of my connections. One thing to remember is always put it on the male end, so none gets inside Good luck! Jimmy Harvie Curt Sprenger Terry, I wonder if a correlation could be established between engine miles and the coolant/fuel hose, pump, maintenance requirements. Would be useful to other 'Bird owners for sure. You are doing a lot of work on your engine. What is the rational for the blower and turbo work? Do you have the maintenance history on your coach? You must have a shop to park your bus and work on it. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Terry Neal wrote: > Curt, it has 171,000 on it which appears pretty close from the Hobbs > hour meter. Went through all the upper part of the engine. Rebuilt or > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > etc. Resetting the fuel rails now & putting it all back together. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > Curt Sprenger wrote: > > > Terry, > > Please keep us posted. > > How many miles on your engine? > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > Terry Neal wrote: > > > > > Sounds like you did the right thing replacing all of those parts. > > > That's what I did on mine too. Plus new water pump & new rad core > > > (increased cooling capacity 15%). When it warms up some, will take it > > > out on I90 to see what it runs at now. > > > > > > Terry Neal > > > Bozeman, MT > > > 82PT40 6V92TA > > > 74FC34 6V53T > > > > > > Curt Sprenger wrote: > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > pounds > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > Grade > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > up to > > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > --------------------------------- We won't tell. Get more on shows you hate to love (and love to hate): Yahoo! TV's Guilty Pleasures list. [Non-text portions of this message have been removed] |
03-19-2007, 17:05
Jimmy:
I think your recommendation to change coolant hoses every two years is a bit of overkill. I am running my hoses now in excess of 6 years with absolutely no problems. I inspect the hoses regularly and do check clamps on a regular basis. R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, James Harvie > > Terry, I'd say change your hoses every other year, If you drive it or not. Also don't be afraid to use a nutdriver and go over your hose clamps often. Those Detriots vibrate a lot so I used to throw a wrench on all of the engine bolts, on the ones I used to own, expecially the oil cooler. I use Permetex #2 non hardening goo goo on all of my connections. One thing to remember is always put it on the male end, so none gets inside Good luck! > Jimmy Harvie > Curt Sprenger Terry, > I wonder if a correlation could be established between engine miles and > the coolant/fuel hose, pump, maintenance requirements. Would be useful > to other 'Bird owners for sure. > > You are doing a lot of work on your engine. What is the rational for the > blower and turbo work? Do you have the maintenance history on your coach? > > You must have a shop to park your bus and work on it. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Terry Neal wrote: > > > Curt, it has 171,000 on it which appears pretty close from the Hobbs > > hour meter. Went through all the upper part of the engine. Rebuilt or > > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > > etc. Resetting the fuel rails now & putting it all back together. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Curt Sprenger wrote: > > > > > Terry, > > > Please keep us posted. > > > How many miles on your engine? > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > Terry Neal wrote: > > > > > > > Sounds like you did the right thing replacing all of those parts. > > > > That's what I did on mine too. Plus new water pump & new rad core > > > > (increased cooling capacity 15%). When it warms up some, will take it > > > > out on I90 to see what it runs at now. > > > > > > > > Terry Neal > > > > Bozeman, MT > > > > 82PT40 6V92TA > > > > 74FC34 6V53T > > > > > > > > Curt Sprenger wrote: > > > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > > pounds > > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > > Grade > > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > > up to > > > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > --------------------------------- > We won't tell. Get more on shows you hate to love > (and love to hate): Yahoo! TV's Guilty Pleasures list. > > [Non-text portions of this message have been removed] > |
03-19-2007, 18:09
Terry, I have missed some posts here. What happened that you had to go into a
DD6V92TA with only 171000 miles. Those engines are barely broken in at that point. I have not known of many failing with what would be considered low milage for that engine. On my part, since joining this forum in Dec., I have been more alarmed at the failure rate of the Cats, at fairly low milage. Good luck with the repairs, George Burke, 1977FC31 Charlotte ----- Original Message ----- From: Terry Neal To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 19, 2007 8:33 PM Subject: Re: [WanderlodgeForum] Update - Thermostat and radiator service, with 6,000 pound in tow. Curt, it has 171,000 on it which appears pretty close from the Hobbs hour meter. Went through all the upper part of the engine. Rebuilt or replaced the blower, turbo, water pump, fuel pump, Charge air cooler, etc. Resetting the fuel rails now & putting it all back together. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Curt Sprenger wrote: > Terry, > Please keep us posted. > How many miles on your engine? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Terry Neal wrote: > > > Sounds like you did the right thing replacing all of those parts. > > That's what I did on mine too. Plus new water pump & new rad core > > (increased cooling capacity 15%). When it warms up some, will take it > > out on I90 to see what it runs at now. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Curt Sprenger wrote: > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 pounds > > > in tow, outside temperature in the 80's. On the flat the coolant > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > Grade > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > up to > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > clean/rodding the radiator was a good thing to do. > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
User(s) browsing this thread: 18 Guest(s)
