New Member
04-13-2005, 13:25
New Member
Hi Ernie,
Had to support you in this venture!!
Bob,Dixie & Harley
92 WBSA (Black and Stainless)
Jefferson,NC
04-14-2005, 10:48
New Member
Mike- glad you are here. Just start asking away! Ernie-83PT40 in Texas
04-14-2005, 14:44
New Member
Ernie: I just joined the group, i am mainly a lurker waiting to buy but
learning alot about bluebirds. Mike Sickles
03-11-2007, 14:34
New Member
Hello group. My name is Jimmy Harvie, a new member. I purchased an 82 FC35, last
week. It's in great shape, been sitting for a few years. I have a few minor
problems to address, (sucking some air in the fuel, small leak under the air
filter. It may be the governor seals, in the pump, I haven't taken off the air
filter housing yet) Michelin xza's all around, 1124.5. They look brand new, no
dry rot, but the production date on the rears are 390, so I'm going to replace
those. I have repaired a lot of other things already, thanks to all of your help
on this forum. I have 30 years of diesel expierience, (UPS Journeyman/ Penske
tech1.Plenty of expierience on Detroit 71/92/series60-DDECV Mack Factory
training. I hope I can help anyone that needs it I'm planning on heading to Fla
in a few weeks,(I'm just west of Boston), looking forward to meeting bird owners
thanks.( Curt, not sure if this will help, but those 92 series had a restricted
fitting, somewhere on the return side of the
system,That fitting influences pump pressure. Just a thought, did you use all
of the old fittings, when you replaced the pump?, I haven't seen too many
problems with those 2 stroke pumps, most of the time, they're good for the life
of the engine,
TV dinner still cooling?
Check out "Tonight's Picks" on Yahoo! TV.
03-11-2007, 15:49
New Member
James,
Welcome to the forum!
Thank you for your input about the restriction fitting. I know where it
is, at the start of the hard line return to the fuel tank. I can remove
it, and I expect to find a small hole in it which should be good to go.
Is there something else about the fitting that I should be aware of?
Curt Sprenger
Anaheim Hills, Calif.
> FC35, last week. It's in great shape, been sitting for a few years. I
> have a few minor problems to address, (sucking some air in the fuel,
> small leak under the air filter. It may be the governor seals, in the
> pump, I haven't taken off the air filter housing yet) Michelin xza's
> all around, 1124.5. They look brand new, no dry rot, but the
> production date on the rears are 390, so I'm going to replace those. I
> help on this forum. I have 30 years of diesel expierience, (UPS
> Journeyman/ Penske tech1.Plenty of expierience on Detroit
> 71/92/series60-DDECV Mack Factory training. I hope I can help anyone
> that needs it I'm planning on heading to Fla in a few weeks,(I'm just
> west of Boston), looking forward to meeting bird owners thanks.( Curt,
> use all of the old fittings, when you replaced the pump?, I haven't
> seen too many problems with those 2 stroke pumps, most of the time,
> they're good for the life of the engine,
03-11-2007, 16:24
New Member
Curt, nothing more to know about the fitting, It's a fixed restriction,with no
adjustments.I thought I'd pass the thought to you seeing as you may have removed
them, when you replaced the parts. The idea of isolating the fuel system, by
running the lines into a gallon of diesel was a good one. not to get ahead of
things but after looking at the areoquip fuel lines on the one I just bought,
I'd say it's possible that some of the rubber hose that lines the inside could
desinergrate causing a blockage. One other idea would be to make up a clear
hose, add that inline and you can watch for air bubbles. I do know those tiny
fuel pumps won't suck one drop if they're not primed but once they are, they'll
blow fuel from here to the Moon
Curt Sprenger wrote: James,
Curt Sprenger
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
03-11-2007, 16:26
New Member
Welcome to the forum. Since you have a lot of experience with DD and DDEC, I
have a ton of questions. I am not in a hurry, all systems are go, but when you
get time please e-mail me at http://www.jwasneski@...
Leroy Eckert
1990 WB-40"Smoke N Mirrors'
Niceville, Fl
Sent: Sunday, March 11, 2007 8:34 PM
Subject: [WanderlodgeForum] New member
last week. It's in great shape, been sitting for a few years. I have a few minor
of the engine,
03-12-2007, 01:21
New Member
James- welcome to the group. Whose coach did you purchase?
83PT40
Livingston,Montana
"POO-DOO-EXPRESS"
Sent: Sunday, March 11, 2007 6:34 PM
of the engine,
03-12-2007, 16:44
New Member
Ernie The name next to the door says Fred and Louise Staiger. Not sure who they
are, or where they are from though. I bought this from a dealer in NH. It was on
consignment. I'm either the third or fourth owner I believe. The FMCA# on the
plate is 22658. So far from what I've checked, everything seems to be there,
except for the side awning. It dosen't have the instant hot water dispenser but
I may put one in. It has the ice maker, with looks to be an inverter over the
passengers head. I may update my alternator (get rid of that 160 amp Motorola),
and go with a Delco 320 amp, maybe change the inverterto 3500 watts, so I can
run the ice maker, the hot water dispenser and one roof a/c going down the road
without having to run the generator. It has 4 electric fans on the engine
radiator. I thought this was stock untill I got it home, climbed on the roof,
opened the rear storage pod and found a hub with an electric clutch a fan blade
with the shaft missing and a shroud. I
figured it out. It has the swing radiator, new belts/ hoses .along with a spare
set of belts, and a complete set of spare filters for both the main engine and
th generator ( Kohler 12.5- 600 hrs) I also got the screen house that you add
water too. Had an exhust leak, I installed a new muffler, and although the
tailpipe was recent I had a 5" chrome set of stacks off an old Peterbuilt, that
was in good shape, so I threw one on for my tailpipe.This is my first motorhome,
and although I have always thought about buying one I thought about this deal
for about 20 minutes and snagged it. Today I started buffing it out, the paint's
comming back like it's new. Ok I don't want to flood the forum too much, but I'm
like a kid in a candy store, right now. Oh one more thing. I got what I'll say
the main blue print ( it's one sheet covered in hard see through plastic), but I
also got about 40 other detailed blueprints about 3'x5' in size, Did these come
with the coach, or were these
copied later?
ernieekberg@... wrote: James- welcome to the group. Whose
83PT40
Livingston,Montana
"POO-DOO-EXPRESS"
system,That fitting influences pump pressure. Just a thought, did you use all of
the old fittings, when you replaced the pump?, I haven't seen too many problems
with those 2 stroke pumps, most of the time, they're good for the life of the
engine,
Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
06-10-2007, 02:29
New Member
Hi to all-
A few of you in South Florida know me, thought I'd make myself
available online.
Eric LaCruze
ASE Master Truck tech
