Sunroof
03-09-2007, 10:12
Sunroof
How common were sunroofs? Anybody ever replace the gasket?
Mine is cracked in a few places and is leaking. In the short run I've fixed it
with liquid neoprene rubber sealant, but in the long run I need to replace the
gasket. One of the two locking arms is also broken.
Called BB Parts today and left a message, but didn't get a callback (my phone
was fairly busy today, so it could have simply been that Earl couldn't reach
me).
The first problem is in identifying the unit. There are no distinguishing marks
on the latch, and the glass says "Blindex Supercool" and measures about 13-5/8 x
28-1/2 inches.
I've found one place on the net that sells parts, Sunroof Doctor. If you go to
http://www.sunroofdoctor.com then click on Sunroof Parts, then Parts for
Aftermarket Installed Sunroofs (because BB is not in the factory installs), none
of the latch types shown match what I have.
Click on SFC/Webasto and I think it might be the "First Design" model 1530. I
think the latch they show is for the "Second Design."
So, anybody have any further input?
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
03-09-2007, 11:53
Sunroof
I looked and was unable to find the proper gasket for the sunroof on
my 87FC. I got to the point where I thought I would just replace the
sunroof with a new one that would fit into the cut out, but they were
a bit pricey.
So I took the old one out, cleaned all of the old sealant off, and
then reinstalled using new sealant(the white stuff used for sealing
things on the roof). I sealed it in a way that that the sealant
overlapes the glass just a bit all the way around(use masking tape
here) and down onto the roof.
It is now air and water tight, I don't open it do to the fact that it
will break the sill. In an emergency you can use the sunroof, but I
like the fact that I know there are no water leaks and while driving
I don't have the air leaks that were common to the sunroof.
If you would like me to e-mail some photos to you let me know.
Robert Britton
87FC
Hollister, California
I've fixed it with liquid neoprene rubber sealant, but in the long
run I need to replace the gasket. One of the two locking arms is also
broken.
(my phone was fairly busy today, so it could have simply been that
Earl couldn't reach me).
distinguishing marks on the latch, and the glass says "Blindex
Supercool" and measures about 13-5/8 x 28-1/2 inches.
If you go to http://www.sunroofdoctor.com then click on Sunroof
Parts, then Parts for Aftermarket Installed Sunroofs (because BB is
not in the factory installs), none of the latch types shown match
what I have.
model 1530. I think the latch they show is for the "Second Design."
> Don Bradner
> Eureka, CA
03-09-2007, 12:10
Sunroof
Don: I haven't replaced any but I have found the skylite will leak if
it has even the smallest amount of dirt on the gasket. Keep it clean.
I've fixed it with liquid neoprene rubber sealant, but in the long run
I need to replace the gasket. One of the two locking arms is also broken.
you go to http://www.sunroofdoctor.com then click on Sunroof Parts,
then Parts for Aftermarket Installed Sunroofs (because BB is not in
the factory installs), none of the latch types shown match what I have.
> Don Bradner
> Eureka, CA
03-09-2007, 15:53
Sunroof
Doesn't sound good on the gasket, but I agree that opening other than
emergencies is unimportant. Was the "white stuff" Dicor? I don't think I would
need pictures - I've sealed enough things on RV roofs!
>a bit pricey.
>Robert Britton
>87FC
>broken.
>what I have.
>> Don Bradner
>> Eureka, CA
>Yahoo! Groups Links
Don Bradner
Eureka, CA
03-10-2007, 13:49
Sunroof
It's been a couple of years since I did the job, so can"t remember
all the details.
I reset the sunroof using 1" putty tape, this creates the seal. I
then coated with Kool Seal elastomeric roof coating. (purchased from
camping world). Now every few years I'll reseal with the roof coating
when I'm up there sealing other things that need to be resealed.
Robert Britton
87FC
than emergencies is unimportant. Was the "white stuff" Dicor? I don't
think I would need pictures - I've sealed enough things on RV roofs!
on
were
> >a bit pricey.
sealing
it
I
driving
> >Robert Britton
> >87FC
also
> >broken.
callback
Doctor.
is
> >what I have.
> >> Don Bradner
> >> Eureka, CA
> >Yahoo! Groups Links
> Don Bradner
> Eureka, CA
